[PATCH v5 7/7] i386: Port to RTEMS
Jan Sommer
jan.sommer at dlr.de
Fri Apr 17 08:24:08 UTC 2020
- Update imported files to compile rtems-libbsd for i386 based BSPs
- Mostly commenting out parts which create compile or link errors in
RTEMS, but aren't needed
freebsd/sbin/sysctl/sysctl.c | 8 ++++++++
freebsd/sys/dev/pci/pci_pci.c | 2 ++
freebsd/sys/i386/include/machine/cpufunc.h | 2 ++
freebsd/sys/kern/subr_gtaskqueue.c | 4 ++++
rtemsbsd/i386/include/machine/clock.h | 2 ++
rtemsbsd/include/rtems/bsd/local/opt_acpi.h | 0
6 files changed, 18 insertions(+)
create mode 100644 rtemsbsd/i386/include/machine/clock.h
create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_acpi.h
diff --git a/freebsd/sbin/sysctl/sysctl.c b/freebsd/sbin/sysctl/sysctl.c
index 30ebe5fd..035c1db2 100644
--- a/freebsd/sbin/sysctl/sysctl.c
+++ b/freebsd/sbin/sysctl/sysctl.c
@@ -69,7 +69,9 @@ static const char rcsid[] =
#endif
#if defined(__amd64__) || defined(__i386__)
+#ifndef __rtems__
#include <machine/pc/bios.h>
+#endif /* __rtems__ */
#endif
#include <assert.h>
@@ -832,6 +834,7 @@ S_efi_map(size_t l2, void *p)
#endif
+#ifndef __rtems__
static int
S_bios_smap_xattr(size_t l2, void *p)
@@ -850,6 +853,7 @@ S_bios_smap_xattr(size_t l2, void *p)
(uintmax_t)smap->length);
return (0);
#endif
static int
@@ -1061,7 +1065,11 @@ show_var(int *oid, int nlen)
#endif
else if (strcmp(fmt, "S,bios_smap_xattr") == 0)
+#ifndef __rtems__
func = S_bios_smap_xattr;
+#else /* __rtems__ */
+ func = NULL;
#endif
else {
func = NULL;
diff --git a/freebsd/sys/dev/pci/pci_pci.c b/freebsd/sys/dev/pci/pci_pci.c
index 43c71461..5ba3e9a0 100644
--- a/freebsd/sys/dev/pci/pci_pci.c
+++ b/freebsd/sys/dev/pci/pci_pci.c
@@ -1593,6 +1593,7 @@ pcib_attach_common(device_t dev)
sc->flags |= PCIB_SUBTRACTIVE;
break;
+#ifndef __rtems__
#if !(defined(NEW_PCIB) && defined(PCI_RES_BUS))
/* Compaq R3000 BIOS sets wrong subordinate bus number. */
case 0x00dd10de:
@@ -1620,6 +1621,7 @@ pcib_attach_common(device_t dev)
break;
#endif
if (pci_msi_device_blacklisted(dev))
diff --git a/freebsd/sys/i386/include/machine/cpufunc.h b/freebsd/sys/i386/include/machine/cpufunc.h
index a029da3b..e50ef9d7 100644
--- a/freebsd/sys/i386/include/machine/cpufunc.h
+++ b/freebsd/sys/i386/include/machine/cpufunc.h
@@ -233,11 +233,13 @@ fls(int mask)
#define HAVE_INLINE_FLSL
+#ifndef __rtems__
static __inline __pure2 int
flsl(long mask)
return (fls((int)mask));
#endif /* _KERNEL */
diff --git a/freebsd/sys/kern/subr_gtaskqueue.c b/freebsd/sys/kern/subr_gtaskqueue.c
index c061c6b0..4ef05e0a 100644
--- a/freebsd/sys/kern/subr_gtaskqueue.c
+++ b/freebsd/sys/kern/subr_gtaskqueue.c
@@ -744,7 +744,9 @@ taskqgroup_attach(struct taskqgroup *qgroup, struct grouptask *gtask,
__func__, gtask->gt_name, error);
} else
+#ifndef __i386__
BSD_ASSERT(irq == -1);
+#endif /* __i386 */
mtx_unlock(&qgroup->tqg_lock);
@@ -776,7 +778,9 @@ taskqgroup_attach_deferred(struct taskqgroup *qgroup, struct grouptask *gtask)
+#ifndef __i386__
BSD_ASSERT(gtask->gt_irq == -1);
qgroup->tqg_queue[qid].tgc_cnt++;
LIST_INSERT_HEAD(&qgroup->tqg_queue[qid].tgc_tasks, gtask, gt_list);
diff --git a/rtemsbsd/i386/include/machine/clock.h b/rtemsbsd/i386/include/machine/clock.h
new file mode 100644
index 00000000..415e2b55
--- /dev/null
+++ b/rtemsbsd/i386/include/machine/clock.h
@@ -0,0 +1,2 @@
+extern int tsc_is_invariant;
+extern uint64_t tsc_freq;
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_acpi.h b/rtemsbsd/include/rtems/bsd/local/opt_acpi.h
index 00000000..e69de29b
2.12.3
