Pre-Qualified RTEMS Build
Sebastian Huber
Fri Apr 17 13:54:18 UTC 2020
Hello,
for the ESA pre-qualification activity we would like to have an RTEMS
build which includes the pre-qualified parts and in addition give
applications the option to use most of the remaining functionality
provided by a standard RTEMS (excluded are POSIX signals and timers). To
achieve this I wrote a new build system for RTEMS based on specification
items last year as a task of this ESA activity. The RTEMS Project
decided to not integrate it in RTEMS 5 and postpone this to RTEMS 6
(maybe). To avoid further delays in the ESA activity I decided to start
with the modifications for a pre-qualified build on top of the not yet
integrated new build system.
I can now build an RTEMS sparc/leon3 BSP which provides potentially
pre-qualified start.o, librtemsbsp.a, librtemscpu.a, and librtemstest.a
artifacts. It offers the full set of RTEMS header files and provides
librtemsbspextra.a, librtemscpuextra.a, librtemstestextra.a, etc.
libraries as non-pre-qualified components. In the build specification,
every header and source file belongs exactly one of two pairwise
disjoint sets (pre-qualified and non-pre-qualified). The source and
header files necessary for the pre-qualified artifacts are determined by
the new space profile validation test:
https://git.rtems.org/sebh/rtems.git/tree/testsuites/validation/ts-profile.c?h=qual
This test includes all functions of the space profile proposal (except
device drivers and the interrupt controller API).
https://ftp.rtems.org/pub/rtems/people/sebh/tn-space-profile-r2-18072019.pdf
In the pre-qualified set of files for sparc/leon3, there are 242 header
files, 255 C source files, and 8 assembler source files.
The pre-qualified set has no reference to the heap free function. To
achieve this, I wrote more than a hundred patches for RTEMS in 2019 and
2020 (thanks for reviewing all this stuff and all the help to find
better solutions). A change in the space profile is necessary for this
also. We have to replace the rtems_task_create() function with an
rtems_task_build() function. This needs to be discussed:
https://devel.rtems.org/ticket/3959
The application configuration using the pre-qualified artifacts is done
through the standard <rtems/confdefs.h> header file. To achieve this, I
had to rework a nearly 4k lines of code header file. I split it into 22
different header files:
https://git.rtems.org/rtems/tree/cpukit/include/rtems/confdefs
All 149 application configuration options are now documented and
(partly) specified:
https://git.rtems.org/sebh/rtems-qual.git/tree/spec/acfg/opt
How can we verify which source and header files are required for the
space profile? For this I added a verification build. All files of the
pre-qualified set are copied to a separate directory, then a build of
only the pre-qualified artifacts is done in this separate directory
using the build specification of the corresponding RTEMS sources. Only
the artifacts and header file in this separate directory are used to
link the space profile validation test. You can install this build and
get a BSP installation without the extras. Doing this specialized build
is done with 11 lines of Python code. Gathering the files necessary for
this build is done with 57 lines of Python code. You find it here:
The specification items are in YAML format. I am very happy with this
file format, however, the Python YAML parser is quite slow. So, I wrote
an item cache in Python pickle format. It loads the current
specification (2439 files) in about 0.2 seconds compared to several
seconds if loaded from YAML.
The code was written according to the new RTEMS Python Development
Guidelines:
https://docs.rtems.org/branches/master/eng/python-devel.html
The code is formatted by yapf and analyzed by flake8, mypy, and pylint.
It is tested with pytest. The code coverage through unit tests is:
coverage report -m
--include=rtems_spec_to_x.py,rtemsqual/util.py,rtemsqual/items.py,rtemsqual/__init__.py,rtemsqual/glossary.py,rtemsqual/content.py,rtemsqual/build.py,rtemsqual/applconfig.py
Name Stmts Miss Cover Missing
rtemsqual/__init__.py 8 0 100%
rtemsqual/applconfig.py 130 0 100%
rtemsqual/build.py 36 0 100%
rtemsqual/content.py 133 0 100%
rtemsqual/glossary.py 71 0 100%
rtemsqual/items.py 126 0 100%
rtemsqual/util.py 26 0 100%
TOTAL 530 0 100%
I found that using the analyzers helped during development and is not a
burden. I think it improves productivity. You just need to get used to it.
