[PATCH v3] Tests for pthread_getcpuclockid method. Ticket:3891
Eshan dhawan eshandhawan51 at gmail.com
Fri Apr 17 14:30:58 UTC 2020
 testsuites/psxtests/Makefile.am               |  10 ++
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxgetcpuclockid01/init.c | 149 ++++++++++++++++++
 .../psxgetcpuclockid01/psxgetcpuclockid01.doc |  23 +++
 .../psxgetcpuclockid01/psxgetcpuclockid01.scn |   4 +
 5 files changed, 187 insertions(+)
 create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
 create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
 create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1f9e4233ec..ffadff16e7 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetattrnp01) \
 	$(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psxgetcpuclockid01
+psx_tests += psxgetcpuclockid01
+psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
+psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
+psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
+psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetcpuclockid01) \
+	$(support_includes)
+endif
 if TEST_psxgetrusage01
 psx_tests += psxgetrusage01
 psx_screens += psxgetrusage01/psxgetrusage01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..c509086abc 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
 RTEMS_TEST_CHECK([psxfile02])
 RTEMS_TEST_CHECK([psxfilelock01])
 RTEMS_TEST_CHECK([psxgetattrnp01])
+RTEMS_TEST_CHECK([psxgetcpuclockid01])
 RTEMS_TEST_CHECK([psxgetrusage01])
 RTEMS_TEST_CHECK([psxglobalcon01])
 RTEMS_TEST_CHECK([psxglobalcon02])
diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c b/testsuites/psxtests/psxgetcpuclockid01/init.c
new file mode 100644
index 0000000000..a2a6476d96
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
@@ -0,0 +1,149 @@
+ *  @file
+ *  @brief Test suite for getcpuclockid methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Eshan Dhawan, Vaibhav Gupta
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <pthread.h>
+#include <stdint.h>
+#include <stdio.h>
+#include <rtems/test.h>
+#include <time.h>
+#include <unistd.h>
+#include "tmacros.h"
+#include "test_support.h"
+const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
+/* Forward declaration to avoid warnings */
+void *POSIX_Init (void * argument);
+void *test_pthread(void *);
+/*structure timespec */
+/* test_pthread function begins */
+void *test_pthread(void *arg)
+  int r;
+  clockid_t cid;
+  struct timespec start_cpu, start_wall, finish;
+  long time_passed_wall, time_passed_cpu ;
+  r = pthread_getcpuclockid( pthread_self(), &cid );
+  if ( r ) {
+    printf( "pthread_getcpuclockid : %d", r );
+  rtems_test_assert( r == 0 );
+  r = clock_gettime( cid, &start_cpu );
+  if ( r ) {
+    printf( "clock_gettime : %d \n", r );
+    if ( r == EINVAL || r == ESRCH ) {
+      printf( "the clockid returned is invalid" );
+  r = clock_gettime( CLOCK_REALTIME, &start_wall );
+  if ( r ) {
+  while (1) {
+  clock_gettime( CLOCK_REALTIME, &finish );
+  time_passed_wall = finish.tv_nsec - start_wall.tv_nsec ;
+  if(time_passed >= 500000000){
+     break;
+  printf( "wall_time = %li\n", time_passed_wall );
+  clock_gettime( cid, &finish );
+  time_passed_cpu = finish.tv_nsec - start_cpu.tv_nsec ;
+  printf( "CPU_time = %li\n", time_passed );
+  pthread_exit(0);
+  return NULL;
+/* init test function begins */
+  TEST_BEGIN();
+  int r;
+  clockid_t cid;
+  pthread_t thread_id;
+  r= pthread_create( &thread_id, NULL, test_pthread, NULL );
+  if( r )
+    printf( "pthread_create : %d", r );
+  r = pthread_join( thread_id, NULL );
+  if( r )
+    printf( "pthread_join : %d", r );
+  r = pthread_getcpuclockid( thread_id, &cid );
+  if( r != ESRCH )
+  rtems_test_assert( r == ESRCH );
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_THREADS     2
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
index 0000000000..ef148182d5
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
@@ -0,0 +1,23 @@
+#  COPYRIGHT (c) 2020
+#  On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name:  psxgetcpuclockid 1
+Directives:
+  Pthread_getcpuclockid()
+Concepts:
++ This test exercises the getcpuclockid methods.
++ For pthread_getcpuclockid it created a pthread using pthread_create and
+ then finds the clockid_t of that thread then used gettime() add a pause of .5 seconds
+ and then ends the thread.
+ After the thread is ended it again tried to find the clockid_t of the thread to
+ check for ESRCH exception.
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
index 0000000000..937a908fd5
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXGETCLOCKID 1 ***
+*** END OF TEST PSXGETCPUCLOCKID 1 ***
2.17.1
