Traceability from specification to source code?
Sebastian Huber
Fri Apr 17 16:57:24 UTC 2020
Hello Joel,
thanks for your comment.
On 17/04/2020 16:41, Joel Sherrill wrote:
> Code annotations are a must. Sebastian is right that putting something
> above the body is the way to go. We are using a requirements comment
> block above the entry point to the method. A script integrates with the
> commercial tool. They analyse the source and provide file, line number,
> and signature (e.g. tags). From that, you can easily find those special
> comments with requirements. You do have to address the case where
> there are no requirements or an incorrectly formatted set. But that's
> the practical matter of what you have to do.
> If you put in a bad requirement tag, then it will just show up as an
> error when you process and some requirement will be uncovered
> in the traceability report.
> There are a lot of details to work out. Doxygen is slow. Would ctags
> or something similar be faster?
Since code annotations were not welcome I searched for an alternative
solution. I first had ctags in mind. Universal ctags has the ability to
produce JSON output:
https://github.com/universal-ctags/ctags
The problem is now how to teach Doxygen the links back to the
specification (without annotations in the source files)? What seems to
work is adding a generated file which contains stuff like this:
* @fn RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds
(uint32_t seconds)
* bla blub
For this you need the function signature in a way so that Doxygen is
able to find the corresponding part in the sources and add the generated
content. The problem is that ctags doesn't deliver this (at least I
don't know how). This is how I ended up using the tagfile.
You say that code annotations are a must. Do you think that there exist
some items in the code which require traceability to the specification
and cannot be found by Doxygen?
