FreeBSD 12 Failures - Py_Initialize: can't initialize sys standard streams
Fri Apr 17 17:25:46 UTC 2020
On 17/04/2020 18:16, Joel Sherrill wrote:
> After some Google searching and talking to Chris, I modified my nohup
> command that starts the script to add "</dev/null". It is still
> running now and reporting results.
> I don't know how to capture this info and the fact that removing gcc
> from the FreeBSD 12 test machine to improve the results.
I would add it here:
https://docs.rtems.org/branches/master/user/hosts/posix.html#freebsd
I would mention also that the GCC build should be done with the GNU sed
in the $PATH during the RSB process.
