[PATCH] sapi: Add param check to rtems_extension_create()
Fri Apr 17 17:31:52 UTC 2020
Thanks, push it with the doc
On Fri, Apr 17, 2020 at 2:11 AM Sebastian Huber
> Check that the extensions table is not NULL.  Change format.
> Update #3953.
>  cpukit/sapi/src/extensioncreate.c | 14 ++++++++++----
>  testsuites/sptests/sp07/init.c    |  5 +++++
>  2 files changed, 15 insertions(+), 4 deletions(-)
> diff --git a/cpukit/sapi/src/extensioncreate.c b/cpukit/sapi/src/extensioncreate.c
> index 59f41d2ec2..5751f47bef 100644
> --- a/cpukit/sapi/src/extensioncreate.c
> +++ b/cpukit/sapi/src/extensioncreate.c
> @@ -32,15 +32,21 @@ rtems_status_code rtems_extension_create(
>    Extension_Control *the_extension;
> -  if ( !id )
> +  if ( !rtems_is_name_valid( name ) ) {
> +    return RTEMS_INVALID_NAME;
> +  if ( extension_table == NULL ) {
>      return RTEMS_INVALID_ADDRESS;
> -  if ( !rtems_is_name_valid( name ) )
> -    return RTEMS_INVALID_NAME;
> +  if ( id == NULL ) {
> +    return RTEMS_INVALID_ADDRESS;
>    the_extension = _Extension_Allocate();
> -  if ( !the_extension ) {
> +  if ( the_extension == NULL ) {
>      _Objects_Allocator_unlock();
>      return RTEMS_TOO_MANY;
> diff --git a/testsuites/sptests/sp07/init.c b/testsuites/sptests/sp07/init.c
> index b44b5b967e..083fd21317 100644
> --- a/testsuites/sptests/sp07/init.c
> +++ b/testsuites/sptests/sp07/init.c
> @@ -73,6 +73,11 @@ rtems_task Init(
>    Extension_name[ 1 ] =  rtems_build_name( 'E', 'X', 'T', '1' );
>    Extension_name[ 2 ] =  rtems_build_name( 'E', 'X', 'T', '2' );
> +  puts  ( "rtems_extension_create - bad table -- RTEMS_INVALID_ADDRESS" );
> +  status = rtems_extension_create( 0xa5a5a5a5, NULL, &id );
> +  fatal_directive_status(
> +    status, RTEMS_INVALID_ADDRESS, "rtems_extension_create" );
>    puts  ( "rtems_extension_create - bad id pointer -- RTEMS_INVALID_ADDRESS" );
>    status = rtems_extension_create( 0xa5a5a5a5, &Extensions, NULL );
> 2.16.4
> devel mailing list
> devel at rtems.org
