[PATCH v3] Tests for pthread_getcpuclockid method. Ticket:3891
Eshan Dhawan
eshandhawan51 at gmail.com
Fri Apr 17 17:48:10 UTC 2020
On Fri, Apr 17, 2020 at 9:49 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Apr 17, 2020 at 8:31 AM Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
> > testsuites/psxtests/Makefile.am | 10 ++
> > testsuites/psxtests/configure.ac | 1 +
> > testsuites/psxtests/psxgetcpuclockid01/init.c | 149 ++++++++++++++++++
> > .../psxgetcpuclockid01/psxgetcpuclockid01.doc | 23 +++
> > .../psxgetcpuclockid01/psxgetcpuclockid01.scn | 4 +
> > 5 files changed, 187 insertions(+)
> > create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
> > create mode 100644
> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> > create mode 100644
> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > index 1f9e4233ec..ffadff16e7 100755
> > --- a/testsuites/psxtests/Makefile.am
> > +++ b/testsuites/psxtests/Makefile.am
> > @@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxgetattrnp01) \
> > $(support_includes) -I$(top_srcdir)/include
> > endif
> > +if TEST_psxgetcpuclockid01
> > +psx_tests += psxgetcpuclockid01
> > +psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
> > +psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
> > +psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
> > +psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxgetcpuclockid01) \
> > + $(support_includes)
> > +endif
> extra blank
> > if TEST_psxgetrusage01
> > psx_tests += psxgetrusage01
> > psx_screens += psxgetrusage01/psxgetrusage01.scn
> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > index 139787cccb..c509086abc 100644
> > --- a/testsuites/psxtests/configure.ac
> > +++ b/testsuites/psxtests/configure.ac
> > @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
> > RTEMS_TEST_CHECK([psxfile02])
> > RTEMS_TEST_CHECK([psxfilelock01])
> > RTEMS_TEST_CHECK([psxgetattrnp01])
> > +RTEMS_TEST_CHECK([psxgetcpuclockid01])
> > RTEMS_TEST_CHECK([psxgetrusage01])
> > RTEMS_TEST_CHECK([psxglobalcon01])
> > RTEMS_TEST_CHECK([psxglobalcon02])
> > diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c
> b/testsuites/psxtests/psxgetcpuclockid01/init.c
> > new file mode 100644
> > index 0000000000..a2a6476d96
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
> > @@ -0,0 +1,149 @@
> > + * @file
> > + * @brief Test suite for getcpuclockid methods
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2020 Eshan Dhawan, Vaibhav Gupta
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in
> the
> > + * documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> extra blank
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <errno.h>
> > +#include <pthread.h>
> > +#include <stdint.h>
> > +#include <stdio.h>
> > +#include <rtems/test.h>
> > +#include <time.h>
> > +#include <unistd.h>
> > +#include "tmacros.h"
> > +#include "test_support.h"
> > +const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
> > +/* Forward declaration to avoid warnings */
> > +void *POSIX_Init (void * argument);
> > +void *test_pthread(void *);
> > +/*structure timespec */
> > +/* test_pthread function begins */
> > +void *test_pthread(void *arg)
> The fn name should reflect the job it does. This isn't testing pthread.
> test_pthread_getcpuclockid()?
> > + int r;
> > + clockid_t cid;
> > + struct timespec start_cpu, start_wall, finish;
> > + long time_passed_wall, time_passed_cpu ;
> > + r = pthread_getcpuclockid( pthread_self(), &cid );
> > + if ( r ) {
> > + printf( "pthread_getcpuclockid : %d", r );
> > + rtems_test_assert( r == 0 );
> > + r = clock_gettime( cid, &start_cpu );
> > + if ( r ) {
> > + printf( "clock_gettime : %d \n", r );
> Maybe use %s and strerror(r)? There are other examples in the psxtests of
> this.
> > + if ( r == EINVAL || r == ESRCH ) {
> > + printf( "the clockid returned is invalid" );
> I don't think this is necessary especially if you print the strerror()
> version
> > + r = clock_gettime( CLOCK_REALTIME, &start_wall );
> > + if ( r ) {
> ditto
> > + while (1) {
> > + clock_gettime( CLOCK_REALTIME, &finish );
> > + time_passed_wall = finish.tv_nsec - start_wall.tv_nsec ;
> > + if(time_passed >= 500000000){
> > + break;
> Why break a while(1) loop on a condition?
> What is this testing?
> We would like tests to finish quickly whenever possible. How long
> would this test expect to take, and is that necessary?
> Here I tried to test the clock_id provided by the pthread_getcpuclockid()
function
this test was suggested by Dr Joel in the patch V1 so I just improved it in
this version
An I wasn't able to fully understand in the previous patch.
you can read more details for the test in this mail
https://lists.rtems.org/pipermail/devel/2020-April/059292.html
> > + printf( "wall_time = %li\n", time_passed_wall );
> > + clock_gettime( cid, &finish );
> > + time_passed_cpu = finish.tv_nsec - start_cpu.tv_nsec ;
> > + printf( "CPU_time = %li\n", time_passed );
> > + pthread_exit(0);
> > + return NULL;
> dead code and not strictly correct.
> > +/* init test function begins */
> > + TEST_BEGIN();
> > + int r;
> > + clockid_t cid;
> > + pthread_t thread_id;
> > + r= pthread_create( &thread_id, NULL, test_pthread, NULL );
> Why using another pthread?
So that when I join that pthread and the thread_id becomes invalid and
could be used for
testing the ESRCH exception
> > + if( r )
> > + printf( "pthread_create : %d", r );
> > + r = pthread_join( thread_id, NULL );
> > + if( r )
> > + printf( "pthread_join : %d", r );
> > + r = pthread_getcpuclockid( thread_id, &cid );
> > + if( r != ESRCH )
> > + rtems_test_assert( r == ESRCH );
> > + TEST_END();
> > + rtems_test_exit(0);
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > +#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
> > +#define CONFIGURE_MAXIMUM_TASKS 1
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#define CONFIGURE_POSIX_INIT_THREAD_TABLE
> > +#include <rtems/confdefs.h>
> > diff --git
> a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> > index 0000000000..ef148182d5
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
> > @@ -0,0 +1,23 @@
> > +# COPYRIGHT (c) 2020
> > +# On-Line Applications Research Corporation (OAR).
> > +# SPDX-License-Identifier: BSD-2-Clause
> > +This file describes the directives and concepts tested by this test set.
> > +test set name: psxgetcpuclockid 1
> > +Directives:
> > + Pthread_getcpuclockid()
> > +Concepts:
> > ++ This test exercises the getcpuclockid methods.
> > ++ For pthread_getcpuclockid it created a pthread using pthread_create
> and
> > + then finds the clockid_t of that thread then used gettime() add a
> pause of .5 seconds
> > + and then ends the thread.
> > + After the thread is ended it again tried to find the clockid_t of the
> thread to
> > + check for ESRCH exception.
> > diff --git
> a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> > index 0000000000..937a908fd5
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
> > @@ -0,0 +1,4 @@
> > +*** BEGIN OF TEST PSXGETCLOCKID 1 ***
> > +*** END OF TEST PSXGETCPUCLOCKID 1 ***
> > 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200417/ece11e02/attachment-0001.html>
