[PATCH v3] updates #3889, Added test for timer_create() using CLOCK_MONOTONIC
Eshan dhawan eshandhawan51 at gmail.com
Sun Apr 19 18:30:03 UTC 2020
>I will create a timer using timer_create() function,
and passing CLOCK_MONOTONIC in clock_id argument.
>The test will fail as there is no support for
CLOCK_MONOTONIC in cpukit/posix/src/psxtimercreate.c.
>The added code compiles successfully without any errors.
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
 testsuites/psxtests/psxtimer02/psxtimer.c     | 8 ++++++--
 testsuites/psxtests/psxtimer02/psxtimer02.scn | 3 ++-
 2 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
index 9f79d33c42..e071f98857 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer.c
+++ b/testsuites/psxtests/psxtimer02/psxtimer.c
@@ -62,9 +62,9 @@ void *POSIX_Init (
   status = timer_create( CLOCK_REALTIME, &event, NULL );
   fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
-  puts( "timer_create - OK" );
+  puts( "timer_create (CLOCK_REALTIME) - OK" );
   status = timer_create( CLOCK_REALTIME, NULL, &timer );
-  posix_service_failed( status, "timer_create OK" );
+  posix_service_failed( status, "timer_create (CLOCK_REALTIME)" );
   puts( "timer_create - too many - EAGAIN" );
   status = timer_create( CLOCK_REALTIME, NULL, &timer1 );
@@ -127,6 +127,10 @@ void *POSIX_Init (
   status = timer_delete( timer );
   fatal_posix_service_status_errno( status, EINVAL, "bad id" );
+  puts( "timer_create (CLOCK_MONOTONIC) - OK" );
+  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
+  posix_service_failed( status, "timer_create (CLOCK_MONOTONIC)" );
   TEST_END();
   rtems_test_exit (0);
diff --git a/testsuites/psxtests/psxtimer02/psxtimer02.scn b/testsuites/psxtests/psxtimer02/psxtimer02.scn
index e78425a32e..7429bcf291 100644
--- a/testsuites/psxtests/psxtimer02/psxtimer02.scn
+++ b/testsuites/psxtests/psxtimer02/psxtimer02.scn
@@ -1,7 +1,7 @@
 *** POSIX Timers Test 02 ***
 timer_create - bad clock id - EINVAL
 timer_create - bad timer id pointer - EINVAL
-timer_create - OK
+timer_create (CLOCK_REALTIME) - OK
 timer_delete - bad id - EINVAL
 timer_getoverrun - bad id - EINVAL
@@ -13,4 +13,5 @@ timer_settime - bad itimer value - negative nanosecond - EINVAL
 timer_settime - bad clock value - EINVAL
 timer_delete - OK
+timer_create (CLOCK_MONOTONIC) - OK
 *** END OF POSIX Timers Test 02 ***
2.17.1
