RTEMS examples build failed
Sebastian Huber
Mon Apr 20 17:20:05 UTC 2020
On 20/04/2020 19:04, Vijay Kumar Banerjee wrote:
> On Sun, Apr 19, 2020 at 8:16 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 19/04/2020 15:38, Gedare Bloom wrote:
>> On Sun, Apr 19, 2020 at 3:52 AM Vijay Kumar Banerjee<vijay at rtems.org> <mailto:vijay at rtems.org> wrote:
>>> Hi,
>>> While trying to build the examples with a fresh pull from upstream,
>>> I got the following build error from gccdeps:
>>> Build failed
>>> Traceback (most recent call last):
>>> File "//home/lunatic/development/rtems-examples//.waf-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py", line 190, in process
>>> self.post_run()
>>> File "/home/lunatic/development/rtems-examples/rtems_waf/gccdeps.py", line 144, in post_run
>>> raise ValueError('could not find %r for %r' % (x, self))
>>> ValueError: could not find ['filesystem', 'fat_ramdisk', 'fs-root-tar.h'] for
>> It's doing an error check to find the build dependency fs-root-tar.h,
>> which gets generated in the build directory by bin2c. This has always
>> been tricky to handle in waf. I don't grok the way Chris reworked the
>> rootfs support in the example so I don't immediately see the root
>> (hah) problem or how to try to fix it.
> Hi,
> I figured out that the tar is generating properly but the error check
> is failing
> because it's looking for the fs-root-tar.h file in the source file
> directory but the
> header file is being generated in the build directory.
> Just manually copying the header file to the source directory makes it
> happy
> and the build works fine. Do we want to generate the header file in
> the source
> directory as well and maybe add it in gitignore?
> The other approach can be to tell gccdeps to check for the files in
> the build
> directory instead. I did it with a workaround like the following, and
> it works fine:
> diff --git a/gccdeps.py b/gccdeps.py
> index bfabe72..61d9bfd 100644
> --- a/gccdeps.py
> +++ b/gccdeps.py
> @@ -141,7 +141,10 @@ def post_run(self):
> node = path_to_node(path, x, cached_nodes)
> if not node:
> - raise ValueError('could not find %r for %r' %
> (x, self))
> + x =
> os.path.relpath(str(bld.bldnode)).split('/') + x
> + node = path_to_node(path, x, cached_nodes)
> + if not node:
> + raise ValueError('could not find %r for
> %r' % (x, self))
> if id(node) == id(self.inputs[0]):
> # ignore the source file, it is already in the
> dependencies
> # this way, successful config tests may be
> retrieved from the cache
> If it doesn't look too hackish, then I'll post a patch. This shouldn't
> break anything else
> and I'll surely add comments there about the use case of taking this
> approach.
> Does it look right?
I encountered the same error while writing the new build system. I think
this issue can be fixed with a proper dependency chain in waf. Patching
the generic gccdeps.py is not the way to go if you ask me.
