clang static analysis of leon2
suyash singh suyashsingh234 at gmail.com
Mon Apr 20 18:12:18 UTC 2020
I can't find any way to group by sub directories but
I can write a script/program to make a new html file in which errors are
grouped by sub directories. I have written web scrapers with organized data
output in python and JS before.
There is a --disable-checker option and using comments to ignore parts of
file. I have not tested both techniques yet.
Some of the reports look easy to fix but the issue is that I am not usually
sure about the previous programmer's intention for writing the code that
way.
The goal of my GSOC is to
integrate the clang static analyzer in rtems
and
integrate UBSan in rtems
I would also like to improve the buildbot if needed
On Mon, Apr 20, 2020 at 11:00 PM Joel Sherrill <joel at rtems.org> wrote:
> I could download the report and look through it.
> I assume that's the standard output from the analyzer.  For prioritization
> of looking at issues, it can be helpful if there is a way to group them by
> "area" which usually corresponds to the subdirectory. My scan showed
> one for a chain method in score/src. I think adding one line of code would
> fix that.
> But I also saw one in calloc.c which I think would need to be marked as
> a false report. calloc() is supposed to return a pointer so it isn't a
> leak.
> Is there a way to tell the analyzer to ignore that specific issue in that
> method?
> Have you looked through the reports for things that look legitimate
> and easy to fix?
> I'm unsure of the scope of your GSoC project so not sure other than
> to say I looked through it quickly and was able to see the issues reported
> after I unzipped the report.
> Is the goal to get this integrated into the RTEMS.org buildbot?
> --joel
> On Mon, Apr 20, 2020 at 12:14 PM suyash singh <suyashsingh234 at gmail.com>
> wrote:
>> Find the analysis here
>> https://drive.google.com/drive/folders/1FL_euXfAtlzezDf0Vwg5-WHM22z8lbFQ
>> steps here
>> https://github.com/suyashsingh234/rtems-notes
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200420/82225f6c/attachment.html>
