Doorstop Issues
Sebastian Huber
Mon Apr 20 18:14:18 UTC 2020
On 20/04/2020 15:20, Joel Sherrill wrote:
> On Sun, Apr 19, 2020 at 10:14 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> I am about to add the next couple of hundred specification items
> for the
> RTEMS pre-qualification activity. Before I do this, I would like to
> present some issues that popped up during my daily work with
> Doorstop.
> Doorstop is a requirements management tool which was selected for the
> pre-qualification activity:
> https://docs.rtems.org/branches/master/eng/req-eng.html#selected-tool-doorstop
> I am quite happy that Jan Sommer suggested to use this tool. I has
> some
> pretty nice features. In particular, I think the file based
> organization
> in YAML format forming a directed acyclic graph is really the right
> thing for this project. However, it turned out that it lacks the
> required flexibility.
> 1. Its use case is requirements management. So it has some standard
> attributes useful in this domain, like derived, header, level,
> normative, ref, reviewed, and text. However, I want to use it more
> generally for specification items and these attributes make not
> always
> sense. Having them in every item is just overhead and may cause
> confusion.
> If they are documented well and their flow through the process is clear,
> there should not be huge confusion. Performance overhead maybe.
> I have seen project requirements that had schedule phase or HW/SW
> associated
> with each requirement. On those projects, it seemed to me that the
> primary
> problem was that the tooling couldn't check that parent requirement
> custom attributes had an relationship to those of the children. Schedule
> phases and HW/SW didn't match across the levels of requirements and
> there was no way to know if it was intentional or just 100s of mistakes.
> 2. The links cannot have custom attributes, e.g. role, enabled-by.
> i assume by enabled-by you are tracking to an RTEMS compile or condefs.h
> configure option.
Yes, the enabled-by stuff mostly relates to the RTEMS CPU options, e.g.
RTEMS_SMP, RTEMS_POSIX_API, etc.
> The FACE Technical Standard uses the term conditional to describe
> capabilities
> an implementation of the standard may provide. The term optional is
> also used
> in the general requirements community but these. I recall that is what
> POSIX
> calls them. Interestingly, neither standard uses will or may in those
> requirements
> as the textbooks suggest but collects them under optional feature
> categories.
> 3. Inside a document (directory) items are supposed to have a common
> type. I would like to store at a hierarchy level also distinct
> specializations.
> 4. The verification if the items is quite limited. We need
> verification
> with type-based rules.
> This sounds like you have found the problem I was referring to above.
> Parent and child should follow rules on custom attributes.
Yes, I think it is a must to verify basic things, e.g. proper
relationships, the right set of attributes, proper values for the
attributes, etc.
> 5. The UIDs in combination with the document hierarchy lead to
> duplication, e.g. a/b/c/a-b-c-d.yml. You have the path (a/b/c)
> also in
> the file name (a-b-c). You cannot have relative UIDs in links (e.g.
> ../parent-req) . The specification items may contain multiple
> requirements, e.g. min/max attributes. There is no way to identify
> them.
> This seems fixable.
> I will probably stop using Doorstop and use a custom tooling. With
> Python, this is quite easy. I already have the infrastructure for
> this in:
> https://git.rtems.org/sebh/rtems-qual.git/
> I will try this out with the new build system.
> You are indeed pushing beyond what a requirements management tool
> is usually scoped to do. Which is funny because some of the commercial
> tools have capabilities not discussed so far. They are usually metrics,
> static analysis, and/or code coverage. We address two of the three with
> custom tools.
> I agree with Chris that you should discuss this with the Doorstop project.
> RTEMS has certainly grown with odd requirements thrown at it. It would
> be rude to not give another open source project the same opportunity.
> Of course, that may not change the end result.
https://github.com/doorstop-dev/doorstop/issues/471
> If we do end up beyond Doorstop's mission, then it is worth considering
> a sibling tool to do the generation. But I also know that Doorstop is not
> a huge body of Python either.
I converted the specification of the new build system using path-like
UIDs. Python is really nice here, since you can simply use the os.path
support. The transformation to the new format was pretty easy now that
everything is contained in a machine readable format that ends up with a
bunch of Python lists, dicts, and scalars.
