[PATCH v2] Test for clock_nanosleep() with CLOCK_MONOTONIC option.
Sebastian Huber
Wed Apr 22 18:11:16 UTC 2020
On 22/04/2020 17:53, Utkarsh Rai wrote:
> Rationale for a new test-
>> Although most of the test cases for this test have been taken from clockrealtime,
> adding it to the current test with CLOCK_MONOTONIC may break the existing cases.
>> This test has a new case which tests for no change of delay with monotonic clock when
> the realtime clock has been modified, this is easier to add in a new test.
> testsuites/psxtests/Makefile.am | 10 ++
> testsuites/psxtests/configure.ac | 1 +
> .../psxtests/psxclocknanosleep01/init.c | 155 ++++++++++++++++++
> .../psxclocknanosleep01.doc | 15 ++
> .../psxclocknanosleep01.scn | 14 ++
> 5 files changed, 195 insertions(+)
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 1f9e4233ec..ba79804be7 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -312,6 +312,16 @@ psxclock01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxclock01) \
> $(support_includes) -I$(top_srcdir)/include
> endif
> +if TEST_psxclocknanosleep01
> +psx_tests += psxclocknanosleep01
> +psx_screens += psxclocknanosleep01/psxclocknanosleep01.scn
> +psx_docs += psxclocknanosleep01/psxclocknanosleep01.doc
> +psxclocknanosleep01_SOURCES = psxclocknanosleep01/init.c
> +psxclocknanosleep01_CPPFLAGS = $(AM_CPPFLAGS) \
> + $(TEST_FLAGS_psxclocknanosleep01) $(support_includes)
> +endif
> if TEST_psxclockrealtime01
> psx_tests += psxclockrealtime01
> psx_screens += psxclockrealtime01/psxclockrealtime01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 139787cccb..9bfe8e2c0b 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -75,6 +75,7 @@ RTEMS_TEST_CHECK([psxcleanup01])
> RTEMS_TEST_CHECK([psxcleanup02])
> RTEMS_TEST_CHECK([psxclock])
> RTEMS_TEST_CHECK([psxclock01])
> +RTEMS_TEST_CHECK([psxclocknanosleep01])
> RTEMS_TEST_CHECK([psxclockrealtime01])
> RTEMS_TEST_CHECK([psxconcurrency01])
> RTEMS_TEST_CHECK([psxcond01])
> diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c b/testsuites/psxtests/psxclocknanosleep01/init.c
> new file mode 100644
> index 0000000000..c1f10b9eb9
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/init.c
> @@ -0,0 +1,155 @@
> + * Copyright (c) 2020 Utkarsh Rai.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
Please use this template for new files (BSD-2-Clause license):
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-assembler-source-file-template
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +#include <limits.h>
> +#include <rtems.h>
> +#include <time.h>
> +#include <tmacros.h>
> +typedef enum {
> + MODE_TIMEOUT_FINITE,
> + MODE_TIMEOUT_NEGATIVE_SEC,
> + MODE_TIMEOUT_NEGATIVE_NSEC,
> + MODE_TIMEOUT_NEGATIVE_SEC_NSEC,
> + MODE_TIMEOUT_HUGE_NSEC,
> + MODE_TIMEOUT_CLOCK_MODIFY
> +} test_mode;
> +static void assert_eno(const char *hint, int eno, int expected_eno)
> + const char *warn = "";
> + if ( eno != expected_eno ) {
> + warn = "WARNING: ";
> + printf(
> + "%s%s: actual '%s', expected '%s'\n",
> + warn,
> + hint,
> + strerror(eno),
> + strerror(expected_eno)
> + rtems_test_assert( eno == expected_eno );
> +static void assert_rv(const char *hint, int rv, int expected_eno)
> + int eno;
> + if ( rv != 0 ) {
> + eno = EINVAL;
> + } else {
> + eno = 0;
> + assert_eno( hint, eno, expected_eno );
I am not in favour of adding new test support code like this. The new
test framework has for example:
https://docs.rtems.org/branches/master/eng/test-framework.html#posix-error-numbers
> +static void run(test_mode mode, const char* test_name)
> + struct timespec delay_time;
> + struct timespec configure_time;
> + int rv;
> + int expected_eno;
> + printf("*******%s*********\n", test_name);
The new test framework prints stuff like this in a format easy to parse.
> + switch (mode) {
> + case MODE_TIMEOUT_FINITE:
> + rv = clock_gettime( CLOCK_MONOTONIC, &delay_time );
> + rtems_test_assert( rv == 0 );
> + delay_time.tv_sec += 1;
> + delay_time.tv_nsec += 1;
> + expected_eno = ETIMEDOUT;
> + break;
I think this switch case just make the code harder to read. What is the
benefit? In the new test framework one of the test cases could look like:
T_TEST_CASE(POSIXClockGettimeTimeoutFinite)
int eno;
eno = clock_gettime( CLOCK_MONOTONIC, &delay_time );
T_eno_success( eno );
delay_time.tv_nsec += 1; // This can result in an invalid time,
e.g. if 1.999999999 before the addition
eno = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time,
NULL );
T_eno( eno, ETIMEDOUT );
> + case MODE_TIMEOUT_HUGE_NSEC:
> + delay_time.tv_sec = 1;
> + delay_time.tv_nsec = LONG_MAX;
> + expected_eno = EINVAL;
> + break;
> + case MODE_TIMEOUT_NEGATIVE_NSEC:
> + delay_time.tv_nsec = -1;
> + break;
> + case MODE_TIMEOUT_NEGATIVE_SEC_NSEC:
> + delay_time.tv_sec = -1;
> + break;
> + case MODE_TIMEOUT_NEGATIVE_SEC:
> + delay_time.tv_nsec = 1;
> + break;
> + case MODE_TIMEOUT_CLOCK_MODIFY:
> + rv = clock_gettime( CLOCK_REALTIME, &configure_time );
> + configure_time.tv_sec += 3600;
> + rv = clock_settime( CLOCK_REALTIME, &configure_time );
> + break;
> + default:
> + rtems_test_assert(0);
> + break;
> + rv = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time, NULL );
> + if ( expected_eno == ETIMEDOUT ) {
> + assert_rv( "clock_nanosleep(clock monotonic)", rv, 0 );
> + } else {
> + assert_rv( "clock_nanosleep(clock monotonic)", rv, expected_eno );
> +const char rtems_test_name[] = "PSXCLOCKNANOSLEEP01";
> +static rtems_task Init(rtems_task_argument ignored)
> + TEST_BEGIN();
> + run( MODE_TIMEOUT_FINITE, "timeot finite" );
> + run( MODE_TIMEOUT_HUGE_NSEC, "timeout huge nsec" );
> + run( MODE_TIMEOUT_NEGATIVE_SEC_NSEC, "timeout negative sec nsec" );
> + run( MODE_TIMEOUT_NEGATIVE_NSEC, "timeout negative nsec" );
> + run( MODE_TIMEOUT_NEGATIVE_SEC, "timeout negative sec" );
> + run( MODE_TIMEOUT_CLOCK_MODIFY, "timeout clock modify" );
> + TEST_END();
> + rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_INIT
> +#include <rtems/confdefs.h>
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> index 0000000000..190748ac5a
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> @@ -0,0 +1,15 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: psxclocknanosleep01
> +directives:
> + - clock_nanosleep()
> +concepts:
> + - Test some invalid and extreme timeout values.
> + - Ensure that the CLOCK_MONOTONIC based delay is not affected by changes to
> + CLOCK_REALTIME
> diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> index 0000000000..567daea80d
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> @@ -0,0 +1,14 @@
> +*** BEGIN OF TEST PSXCLOCKNANOSLEEP01 ***
> +*******timeout finite*********
> +clock_nanosleep(clock monotonic): actual 'Success', expected 'Success'
> +*******timeout huge nsec*********
> +clock_nanosleep(clock monotonic): actual 'Invalid argument', expected 'Invalid argument'
> +*******timeout negative sec nsec*********
> +*******timeout negative nsec*********
> +*******timeout negative sec*********
> +*******timeout clock modify*********
> +*** END OF TEST PSXCLOCKNANOSLEEP01 ***
