[PATCH] Removes build time warning for all smp-disabled bsps
Richi Dubey
richidubey at gmail.com
Mon Apr 27 12:13:14 UTC 2020
Dear Dr. Bloom,
I set up the git-email client and I have sent the patch. Please let me
know if it looks correct.
Thanks,
Richi.
On Fri, Apr 24, 2020 at 7:43 PM Gedare Bloom <gedare at rtems.org> wrote:
> Please generate this patch as -v2 and resend to the mailing list. I'm
> not sure, but I don't see your patch emails coming through, only your
> copy-pasted versions where you prepend some additional information.
> You may want to double-check your git-send-email settings and make
> sure it is succeeding. You might need to go to Gmail Settings and
> "Enable Insecure Apps" or something like that.
> On Fri, Apr 24, 2020 at 7:28 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Dear Dr. Bloom,
> > Thanks for your suggestion. Yes, indeed this looks a little bad.
> > Please find the below attached new patch for the same. I have rebuilt
> > the leon3 bsp with this change and the build process was successful
> > without any errors. Also, I have added another patch which I had some
> > doubts on, please check it out.
> > From 4b5dc1d3dcb3319f51effeb3c9789d5e518311c0 Mon Sep 17 00:00:00 2001
> > From: Richi Dubey <richidubey at gmail.com>
> > Date: Fri, 24 Apr 2020 18:19:31 +0530
> > Subject: [PATCH 2/2] This removes the warning unused name variable warning
> > testsuites/sptests/sp37/init.c | 8 ++++----
> > 1 file changed, 4 insertions(+), 4 deletions(-)
> > diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
> > index 22c7d4f2ef..4358e9fffb 100644
> > --- a/testsuites/sptests/sp37/init.c
> > +++ b/testsuites/sptests/sp37/init.c
> > @@ -169,9 +169,9 @@ static void test_isr_level( void )
> > static void test_isr_locks( void )
> > - static const char name[] = "test";
> > ISR_Level normal_interrupt_level = _ISR_Get_level();
> > - ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( name );
> > + ISR_lock_Control initialized = ISR_LOCK_INITIALIZER( "test" );
> > ISR_lock_Control zero_initialized;
> > union {
> > ISR_lock_Control lock;
> > @@ -183,7 +183,7 @@ static void test_isr_locks( void )
> > ISR_Level interrupt_level;
> > memset( &container, 0xff, sizeof( container ) );
> > - _ISR_lock_Initialize( &container.lock, name );
> > + _ISR_lock_Initialize( &container.lock, "test" );
> > bytes = (const uint8_t *) &initialized;
> > for ( i = 0; i < sizeof( container ); ++i ) {
> > @@ -193,7 +193,7 @@ static void test_isr_locks( void )
> > memset( &zero_initialized, 0, sizeof( zero_initialized ) );
> > - _ISR_lock_Set_name( &zero_initialized, name );
> > + _ISR_lock_Set_name( &zero_initialized, "test" );
> > bytes = (const uint8_t *) &zero_initialized;
> > 2.17.1
> > On Thu, Apr 23, 2020 at 11:42 PM Gedare Bloom <gedare at rtems.org> wrote:
> > > Although this fixes the warning in the testsuite, it is hackish to
> > > require users to copy this kind of conditional compilation to their
> > > code, and I don't really like how it looks personally. I might prefer
> > > Joel's approach, but applied to the test, e.g.,
> > > (void) name;
> > > Alternatively, you might think about other approaches that might be
> > > more user-friendly. What about using ISR_LOCK_DEFINE() to declare the
> > > initializer variable?
> > > What about passing the string literal directly without a variable container?
> > > On Thu, Apr 23, 2020 at 7:23 AM Richi Dubey <richidubey at gmail.com> wrote:
> > > > Hey everyone,
> > > > I made this small change and rebuilt the leon32 bsp. It stopped
> > > > showing the earlier warnings:
> > > > log/sparc-leon3.log:../../../../../../rtems/c/src/../../testsuites/sptests/sp37/init.c:172:21:
> > > > warning: unused variable 'name' [-Wunused-variable]
> > > > warning: 'name' defined but not used [-Wunused-const-variable=]
> > > > Can someone please check and let me know if this is correct and would
> > > > work or not.
> > > > Thanks.
> > > > From c9eb205f37aa575a01ef446db3d7b4e34e1a1fae Mon Sep 17 00:00:00 2001
> > > > Date: Thu, 23 Apr 2020 18:38:56 +0530
> > > > Subject: [PATCH 2/2] Added smp check
> > > > testsuites/sptests/sp37/init.c | 2 ++
> > > > 1 file changed, 2 insertions(+)
> > > > index 22c7d4f2ef..3b79682fa1 100644
> > > > @@ -169,7 +169,9 @@ static void test_isr_level( void )
> > > > +#if defined( RTEMS_SMP )
> > > > +#endif
> > > > 2.17.1
> > > > _______________________________________________
> > > > devel mailing list
> > > > devel at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/devel
