[PATCH 0/3] Source Builder: Fixes for Python 3.8
Anders Montonen
Anders.Montonen at iki.fi
Mon Apr 27 19:15:25 UTC 2020
These patches fix some issues with Python 3.8 compatibility, which I
encountered when trying out the new Ubuntu 20.04 release. There's also
fixes for a number of syntax warnings which are flagged even with older
Python versions.
The patches should not break compatibility with older Python versions,
but I have not actually tested.
I'm not sure if the Linux distro check fix is the most elegant, but I
think the whole thing should be changed to check if the required
executables are found in the runtime path, instead of assuming some
hard-coded locations.
Anders Montonen (3):
sb: Fix Python literal comparison warnings
sb/linux.py: Workaround for Python >= 3.8
source-builder/config/gdb-common-1.cfg: Fix building with Python 3.8
source-builder/config/gdb-common-1.cfg | 7 +++-
source-builder/sb/config.py | 2 +-
source-builder/sb/linux.py | 18 ++++----
source-builder/sb/macros.py | 58 +++++++++++++-------------
4 files changed, 47 insertions(+), 38 deletions(-)
2.25.1
