[PATCH 2/3] sb/linux.py: Workaround for Python >= 3.8
Anders Montonen
Anders.Montonen at iki.fi
Mon Apr 27 19:15:27 UTC 2020
The platform.dist() interface has been deprecated since Python 3.5, and
has been removed in Python 3.8.
Fixes:
Traceback (most recent call last):
File "/home/anders/work/rtems/rsb/source-builder/sb/options.py", line 682, in load
overrides = linux.load()
File "/home/anders/work/rtems/rsb/source-builder/sb/linux.py", line 60, in load
distro = platform.dist()[0]
AttributeError: module 'platform' has no attribute 'dist'
Signed-off-by: Anders Montonen <Anders.Montonen at iki.fi>
source-builder/sb/linux.py | 18 +++++++++++-------
1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
index c3059a9..791bbd6 100644
--- a/source-builder/sb/linux.py
+++ b/source-builder/sb/linux.py
@@ -55,13 +55,17 @@ def load():
'__tar': ('exe', 'required', '/bin/tar')
- # Works for LSB distros
- try:
- distro = platform.dist()[0]
- distro_ver = float(platform.dist()[1])
- except ValueError:
- # Non LSB distro found, use failover"
- pass
+ # platform.dist() was removed in Python 3.8
+ if hasattr(platform, 'dist'):
+ # Works for LSB distros
+ try:
+ distro = platform.dist()[0]
+ distro_ver = float(platform.dist()[1])
+ except ValueError:
+ # Non LSB distro found, use failover"
+ pass
+ else:
+ distro = ''
# Non LSB - fail over to issue
if distro == '':
2.25.1
