Release task request for help
Niteesh G. S.
niteesh.gs at gmail.com
Tue Apr 28 01:10:34 UTC 2020
The testing method I used had a flaw. Since I don't have access to
RTEMS server, I replaced the URL with GIthub and it seems that
github keeps references to old repos because of this I wasn't getting
an error due to the wrong repo name.
On Tue, Apr 28, 2020 at 6:38 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> Sounds good. But what is the difference between an RTEMS-package
> and repo? Aren't they the same?
> On Tue, Apr 28, 2020 at 6:25 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 28/4/20 10:50 am, Niteesh G. S. wrote:
>> > The rtems-release-defaults already contains a rtems-packages
>> > variable. Can I use that instead of moving the rtems-repos variables?
>> I am not sure if the list will always match.
>> What about a repos variable that is based on the packages list so we can
>> extend it?
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200428/592aba92/attachment.html>
