rtems assembler
Joel Sherrill
joel at rtems.org
Thu Apr 30 14:19:47 UTC 2020
On Thu, Apr 30, 2020 at 9:21 AM suyash singh <suyashsingh234 at gmail.com>
wrote:
> I think it doesn't support sparc backend although it does not give unknown
> target error.
> I compiled this c program with
> export PATH=$HOME/quick-start/rtems/5/bin:"$PATH"
> clang -target sparc-unknown-rtems5 test1.c
> *test1.c*
> int main(int argc, char **argv) {
> int k = 0x7fffffff;
> k += argc;
> return 0;
> same error
> /usr/bin/as: unrecognized option '-Av8'
> clang-11: error: assembler command failed with exit code 1
> If i write
> clang -target hello test1.c
> error: unknown target triple 'hello', please use -triple or -arch
You left the target name off.
clang -target sparc-unknown-rtems5 hello test1.c
> So I guess it is detecting sparc but not working with it
> On Thu, Apr 30, 2020 at 7:07 PM Hesham Almatary <heshamelmatary at gmail.com>
> wrote:
>> On Thu, 30 Apr 2020 at 14:18, suyash singh <suyashsingh234 at gmail.com>
>> wrote:
>>> I am using ubuntu 18.04 terminal
>>> Here's the python script I wrote to find all include files and run clang
>>> -fsanitize
>>> # run with python3 in terminal
>>> import subprocess
>>> import os
>>> relativedir="../bsps/sparc/erc32/btimer"
>>> directory=os.path.join(os.getcwd(),"../")
>>> file="btimer.c"
>>> root_dir="ubsan"
>>> arr=['clang','-target','sparc','-
>> target needs to be sparc-unknown-rtems5 to pick up the correct tools.
>> Does your clang support sparc backend? Can you try to compile and link some
>> simple C program with it?
>>> fsanitize=undefined',"-I../../../../../../rtems/5/sparc-rtems5/erc32/lib/include","-I../../../../../../rtems/5/sparc-rtems5/include/"]
>>> for path, subdirs, files in os.walk(directory):
>>> for subdir in subdirs:
>>> if(subdir=="include"):
>>> includepath=os.path.join(path,subdir)
>>> idx=includepath.find("..")
>>> arr.append("-I../../../../"+includepath[idx+3:])
>>> arr.append(file)
>>> subprocess.run(arr,cwd=relativedir, stdout=subprocess.PIPE)
>>> #result=subprocess.run(['./a.out'],cwd=relativedir,
>>> On Thu, Apr 30, 2020 at 6:44 PM Hesham Almatary <
>>> heshamelmatary at gmail.com> wrote:
>>>> On Thu, 30 Apr 2020 at 13:51, Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Thu, Apr 30, 2020 at 7:34 AM suyash singh <suyashsingh234 at gmail.com>
>>>>> wrote:
>>>>>> Hello,
>>>>>> I was running clang UBSan on
>>>>>> bsps/sparc/erc32/btimer/btimer.c
>>>>>> and got error
>>>>>> I am not sure but is it because clang is using wrong assembler?
>>>>> I haven't seen anyone run into this in a long time. :)
>>>>> In this case, it is likely one of two things:
>>>>> + Look at your $PATH. Make sure the RTEMS tools are first.
>>>>> + But in your case, I expect that it is because the clang didn't
>>>>> know (somehow) to put the target name in front of the as.
>>>>> Did you invoke it for sparc-rtems5? If so, then there is a
>>>>> path through clang where it isn't looking at the target name.
>>>> That’s likely to be the problem. I expect Suyash isn’t cross compiling
>>>> with clang.
>>>>> I also double checked the as manual to ensure -Av8 was in
>>>>> fact a sparc option.
>>>>> --joel
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>> Hesham
>>>> devel mailing list
>>>> devel at rtems.org
>> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200430/37e813be/attachment-0001.html>
