rtems assembler
suyash singh
suyashsingh234 at gmail.com
Thu Apr 30 14:55:43 UTC 2020
after adding -v
https://hastebin.com/epijunegix.coffeescript
with sparc-unknown-elf
https://hastebin.com/ijohidofus.coffeescript
(target getting an extra unknown for some reason)
riscv64-unknown-elf
https://hastebin.com/jirusidoti.sql
different error: unknown register name (maybe because erc32 bsp with
riscv)
On Thu, Apr 30, 2020 at 8:08 PM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> On Thu, 30 Apr 2020 at 15:21, suyash singh <suyashsingh234 at gmail.com>
> wrote:
>> I think it doesn't support sparc backend although it does not give
>> unknown target error.
>> I compiled this c program with
>> export PATH=$HOME/quick-start/rtems/5/bin:"$PATH"
>> clang -target sparc-unknown-rtems5 test1.c
> Can you add -v to that command and post the output? Also try with
> sparc-unknown-elf. Last thing to try is to do the same for
> riscv64-unknown-elf
>> *test1.c*
>> int main(int argc, char **argv) {
>> int k = 0x7fffffff;
>> k += argc;
>> return 0;
>> same error
>> /usr/bin/as: unrecognized option '-Av8'
>> clang-11: error: assembler command failed with exit code 1
>> If i write
>> clang -target hello test1.c
>> error: unknown target triple 'hello', please use -triple or -arch
>> So I guess it is detecting sparc but not working with it
>> On Thu, Apr 30, 2020 at 7:07 PM Hesham Almatary <heshamelmatary at gmail.com>
>> wrote:
>>> On Thu, 30 Apr 2020 at 14:18, suyash singh <suyashsingh234 at gmail.com>
>>> wrote:
>>>> I am using ubuntu 18.04 terminal
>>>> Here's the python script I wrote to find all include files and run
>>>> clang -fsanitize
>>>> # run with python3 in terminal
>>>> import subprocess
>>>> import os
>>>> relativedir="../bsps/sparc/erc32/btimer"
>>>> directory=os.path.join(os.getcwd(),"../")
>>>> file="btimer.c"
>>>> root_dir="ubsan"
>>>> arr=['clang','-target','sparc','-
>>> target needs to be sparc-unknown-rtems5 to pick up the correct tools.
>>> Does your clang support sparc backend? Can you try to compile and link some
>>> simple C program with it?
>>>> fsanitize=undefined',"-I../../../../../../rtems/5/sparc-rtems5/erc32/lib/include","-I../../../../../../rtems/5/sparc-rtems5/include/"]
>>>> for path, subdirs, files in os.walk(directory):
>>>> for subdir in subdirs:
>>>> if(subdir=="include"):
>>>> includepath=os.path.join(path,subdir)
>>>> idx=includepath.find("..")
>>>> arr.append("-I../../../../"+includepath[idx+3:])
>>>> arr.append(file)
>>>> subprocess.run(arr,cwd=relativedir, stdout=subprocess.PIPE)
>>>> #result=subprocess.run(['./a.out'],cwd=relativedir,
>>>> On Thu, Apr 30, 2020 at 6:44 PM Hesham Almatary <
>>>> heshamelmatary at gmail.com> wrote:
>>>>> On Thu, 30 Apr 2020 at 13:51, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Thu, Apr 30, 2020 at 7:34 AM suyash singh <
>>>>>> suyashsingh234 at gmail.com> wrote:
>>>>>>> Hello,
>>>>>>> I was running clang UBSan on
>>>>>>> bsps/sparc/erc32/btimer/btimer.c
>>>>>>> and got error
>>>>>>> I am not sure but is it because clang is using wrong assembler?
>>>>>> I haven't seen anyone run into this in a long time. :)
>>>>>> In this case, it is likely one of two things:
>>>>>> + Look at your $PATH. Make sure the RTEMS tools are first.
>>>>>> + But in your case, I expect that it is because the clang didn't
>>>>>> know (somehow) to put the target name in front of the as.
>>>>>> Did you invoke it for sparc-rtems5? If so, then there is a
>>>>>> path through clang where it isn't looking at the target name.
>>>>> That’s likely to be the problem. I expect Suyash isn’t cross compiling
>>>>> with clang.
>>>>>> I also double checked the as manual to ensure -Av8 was in
>>>>>> fact a sparc option.
>>>>>> --joel
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>> Hesham
>>>>> devel mailing list
>>>>> devel at rtems.org
>>> Hesham
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200430/563e016a/attachment.html>
