source builder, bsp arch settings
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Apr 30 19:45:13 UTC 2020
Hello everyone!
Apologies for breaking the chain of this conversation.
I have also been working (read struggling) on adding libbsd and ntp support
for RTEMS+EPICS on xilinx_zynq_a9_qemu and trying
to figure out what files in /rtems/rtems-libbsd and
/rtems/rsb/source-builder/, I have to begin with.
In the rtems/rtems-libbsd, I am attempting to change libbsd.py file,
While in rtems/rsb/source-builder/, I have worked on ntp-4-1.cfg.
However, I will really appreciate if this beginner can get some useful
resources or past works to get on the right track to progress ahead.
Thank you so much!
On Thu, Apr 30, 2020 at 3:49 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> Hello, Chris,
> thanks for testing it right away. It was a stupid mistake on my part, of
> course.
> To get around the build error I had to define macros in the build-script.
> “-DHAVE_MKTIME -DHAVE_TIMEGM”
> Unfortunately, configure --extra-cflags does not work as expected
> So I set CFLAGS before the call to configure and forgot to append the
> existing flags ${CFLAGS} :-(
> Heinz
> > On 30. Apr 2020, at 01:33, Chris Johns <chrisj at rtems.org> wrote:
> > On 29/4/20 8:03 pm, Heinz Junkes wrote:
> >> unfortunately i can't really get along with the
> source-builder/sb-set-builder.
> > Can you build the package by manually? This is the recommended first
> step. The RSB is just a means to capture those manual steps.
> >> For example, I want to build ntp for xilinx_zynq_a9_qemu using the
> command line:
> >> (in rtems-source-builder-5.0.0-m2003/rtems)
> > This is a snapshot release which means it can break. While we try as
> best we can there is no guarantee a release snapshot will work. Having said
> that I am pleased you are testing it and reporting problems.
> >> ../source-builder/sb-set-builder —log=log_ntp_arm.txt
> —prefix=/home/h1/GSOC/RTEMS/5.0.0-m2003 \
> >> —host=arm=rtems5 —with-rtems-bsp=xilinx_zynq_a9_qemu net/ntp
> > I have attempted to build net/ntp for the same BSP from the RSB master
> and I am seeing this following error:
> > ../../ntp-4.2.6p5/libntp/mktime.c:67:2: error:
> > #error libntp supplied mktime()/timegm() do not support 64-bit time_t
> > Do you have something else you are building?
> >> I have assumed that the compiler flags for xilinx_zynq_a9_qemu are
> taken over by the specification for which BSP
> >> I want to build this.
> >> E.g. “-march-armv7-a”
> > Do you mean "-march=armv7-a"?
> >> Unfortunately, the compilation of ntp does not work, because __ARM_ARCH
> is not set to “7"
> >> but remains defined at the default value of "4”.
> >> Because of the missing CFLAGS for the xilinx_zynq_a9_qemu architecture?
> > Are you saying the compile command line flags do not have the correct
> `-march=armv7-a` option?
> > The build I just did that failed has the correct set of machine flags
> for a Zynq (Cortex-A9):
> > -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
> > And this gives me:
> > $ arm-rtems5-gcc -dM -E -march=armv7-a -mthumb -mfpu=neon \
> > -mfloat-abi=hard -mtune=cortex-a9 - < /dev/null | grep '__ARM_ARCH '
> > #define __ARM_ARCH 7
> > Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200501/9d3aa200/attachment.html>
