[PATCH rtems] dosfs: Fix memory leak on failed mounts.
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Aug 3 13:16:51 UTC 2020
Currently if mount fails, a converter isn't destroyed. We have to take
care of two cases:
1. The user doesn't provide a converter.
In this case mounting a dosfs creates a default converter. This patch
makes sure that the converter is destroyed again if mount failes for
this case.
2. The user provides a converter.
In this case it's not sure that the dosfs specific routines are reached
because mount can fail before that. Therefore the user has to destroy
the converter himself again. This patch adds a documentation for that
and implements it in the media server.
cpukit/include/rtems/dosfs.h | 7 +++++++
cpukit/libblock/src/media.c | 1 +
cpukit/libfs/src/dosfs/msdos_init.c | 5 +++++
3 files changed, 13 insertions(+)
diff --git a/cpukit/include/rtems/dosfs.h b/cpukit/include/rtems/dosfs.h
index 7691ed7e43..a79b00720a 100644
--- a/cpukit/include/rtems/dosfs.h
+++ b/cpukit/include/rtems/dosfs.h
@@ -214,6 +214,9 @@ typedef struct {
* @brief Converter implementation for new file system instance.
+ * Note: If you pass a converter to mount, you have to destroy it yourself if
+ * mount failed. In a good case it is destroyed at unmount.
* Before converters have been added to the RTEMS implementation of the FAT
* file system, the implementation was:
* - Short names were saved in code page format (as is still the case).
@@ -270,6 +273,10 @@ typedef struct {
* RTEMS_FILESYSTEM_READ_WRITE,
* &mount_opts
+ * if (rv != 0) {
+ * mount_opts.converter->handler->destroy(mount_opts.converter);
* } else {
* rv = -1;
* errno = ENOMEM;
diff --git a/cpukit/libblock/src/media.c b/cpukit/libblock/src/media.c
index 5b2b06b5b2..2964c19881 100644
--- a/cpukit/libblock/src/media.c
+++ b/cpukit/libblock/src/media.c
@@ -504,6 +504,7 @@ static rtems_status_code mount_worker(
if (rv != 0) {
rmdir(mount_path);
free(mount_path);
+ mount_options.converter->handler->destroy(mount_options.converter);
return RTEMS_IO_ERROR;
diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
index dc9c76437d..0649258fa7 100644
--- a/cpukit/libfs/src/dosfs/msdos_init.c
+++ b/cpukit/libfs/src/dosfs/msdos_init.c
@@ -102,10 +102,12 @@ int rtems_dosfs_initialize(
int rc = 0;
const rtems_dosfs_mount_options *mount_options = data;
rtems_dosfs_convert_control *converter;
+ bool converter_created = false;
if (mount_options == NULL || mount_options->converter == NULL) {
converter = rtems_dosfs_create_default_converter();
+ converter_created = true;
} else {
converter = mount_options->converter;
@@ -116,6 +118,9 @@ int rtems_dosfs_initialize(
&msdos_file_handlers,
&msdos_dir_handlers,
converter);
+ if (rc != 0 && converter_created) {
+ converter->handler->destroy(converter);
} else {
errno = ENOMEM;
rc = -1;
2.26.2
