[PATCH rtems] dosfs: Fix memory leak on failed mounts.
Sebastian Huber
Mon Aug 3 13:57:14 UTC 2020
On 03/08/2020 15:16, Christian Mauderer wrote:
> diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
> index dc9c76437d..0649258fa7 100644
> --- a/cpukit/libfs/src/dosfs/msdos_init.c
> +++ b/cpukit/libfs/src/dosfs/msdos_init.c
> @@ -102,10 +102,12 @@ int rtems_dosfs_initialize(
> int rc = 0;
> const rtems_dosfs_mount_options *mount_options = data;
> rtems_dosfs_convert_control *converter;
> + bool converter_created = false;
> if (mount_options == NULL || mount_options->converter == NULL) {
> converter = rtems_dosfs_create_default_converter();
> + converter_created = true;
> } else {
> converter = mount_options->converter;
> @@ -116,6 +118,9 @@ int rtems_dosfs_initialize(
> &msdos_file_handlers,
> &msdos_dir_handlers,
> converter);
> + if (rc != 0 && converter_created) {
> + converter->handler->destroy(converter);
> } else {
> errno = ENOMEM;
> rc = -1;
Why can't we destroy the converter in both cases?
