[PATCH rtems] dosfs: Fix memory leak on failed mounts.
Mon Aug 3 14:16:02 UTC 2020
On 03/08/2020 15:16, Christian Mauderer wrote:
> @@ -270,6 +273,10 @@ typedef struct {
>      *       RTEMS_FILESYSTEM_READ_WRITE,
>      *       &mount_opts
> +   *     if (rv != 0) {
> +   *       mount_opts.converter->handler->destroy(mount_opts.converter);
>      *   } else {
>      *     rv = -1;
>      *     errno = ENOMEM;
I think most code uses
(*mount_opts.converter->handler->destroy)(mount_opts.converter);
for function pointer calls.
