Error while building realview_pbx_a9 BSP with the new build system
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Aug 3 16:17:20 UTC 2020
When I use the above branch I get the following error on './waf install ' -
Build failed
Traceback (most recent call last):
  File
"/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Task.py",
line 180, in process
    ret=self.run()
  File
"/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Build.py",
line 554, in run
    x.parent.mkdir()
  File
"/home/utkarsh/new_build/rtems/.waf-2.0.20-36f5354d605298f6a89c09e0c7ef6c1d/waflib/Node.py",
line 179, in mkdir
    self.parent.mkdir()
  File
line 179, in mkdir
    self.parent.mkdir()
  File
line 179, in mkdir
    self.parent.mkdir()
  File
line 179, in mkdir
    self.parent.mkdir()
  File
line 179, in mkdir
    self.parent.mkdir()
  File
line 188, in mkdir
    raise Errors.WafError('Could not create the directory %r'%self)
WafError: Could not create the directory /opt/rtems
On Mon, Aug 3, 2020 at 9:42 PM Sebastian Huber <
> On 03/08/2020 16:41, Utkarsh Rai wrote:
> > Hello,
> > I have been trying out the new build system. Unfortunately, while
> > building for the realview_pbx_a9 BSP I get the following error on '
> > ./waf install '  -
> > Waf: Entering directory `/home/utkarsh/new_build/rtems/build'
> > Waf: Leaving directory `/home/utkarsh/new_build/rtems/build'
> > 'install' finished successfully (0.289s)
> > `/home/utkarsh/new_build/rtems/build/arm/realview_pbx_a9_qemu'
> > source not found: 'cpukit/include/rtems/system.h' in bld(target='',
> > idx=59, install_task=
> >  {task 139909380107600: inst  -> }, dest='${BSP_INCLUDEDIR}/rtems',
> > tg_idx_count=59, meths=['process_install_task', 'process_rule',
> > 'process_source'], _name='', source=[],
> > install_to='${BSP_INCLUDEDIR}/rtems',
> > path=/home/utkarsh/new_build/rtems,
> > install_from=['cpukit/include/rtems/assoc.h'
> > My config.ini file has all the contents of  './waf bsp_defaults
> > --rtems-bsps=arm/realview_pbx_a9'. Can you please point out my mistake?
> I stopped to maintain the build branch.
> Could you please use this branch:
> https://git.rtems.org/sebh/rtems.git/log/?h=build-2
> Using the new build system in the current state is not really advisable.
> I will do forced pushes to the build-2 branch.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200803/169bba80/attachment.html>
