[PATCH rtems] dosfs: Fix memory leak on failed mounts.
Gedare Bloom
gedare at rtems.org
Mon Aug 3 16:22:27 UTC 2020
On Mon, Aug 3, 2020 at 7:18 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> PS: Is this a candidate for a backport to 5? How many tickets would I
> have to create for it? One for 5 and one for 6?
One for each. Anything put on 5 at this point requires a ticket, and
good practice to add one to 6 also, especially for anything that may
affect user behavior. Then a release note should also get added.
a resource leak is a bug worth back-porting, especially with a simple fix.
> On 03/08/2020 15:16, Christian Mauderer wrote:
> > Currently if mount fails, a converter isn't destroyed. We have to take
> > care of two cases:
> > 1. The user doesn't provide a converter.
> > In this case mounting a dosfs creates a default converter. This patch
> > makes sure that the converter is destroyed again if mount failes for
> > this case.
> > 2. The user provides a converter.
> > In this case it's not sure that the dosfs specific routines are reached
> > because mount can fail before that. Therefore the user has to destroy
> > the converter himself again. This patch adds a documentation for that
> > and implements it in the media server.
> > cpukit/include/rtems/dosfs.h | 7 +++++++
> > cpukit/libblock/src/media.c | 1 +
> > cpukit/libfs/src/dosfs/msdos_init.c | 5 +++++
> > 3 files changed, 13 insertions(+)
> > diff --git a/cpukit/include/rtems/dosfs.h b/cpukit/include/rtems/dosfs.h
> > index 7691ed7e43..a79b00720a 100644
> > --- a/cpukit/include/rtems/dosfs.h
> > +++ b/cpukit/include/rtems/dosfs.h
> > @@ -214,6 +214,9 @@ typedef struct {
> > * @brief Converter implementation for new file system instance.
> > + * Note: If you pass a converter to mount, you have to destroy it yourself if
> > + * mount failed. In a good case it is destroyed at unmount.
> > * Before converters have been added to the RTEMS implementation of the FAT
> > * file system, the implementation was:
> > * - Short names were saved in code page format (as is still the case).
> > @@ -270,6 +273,10 @@ typedef struct {
> > * RTEMS_FILESYSTEM_READ_WRITE,
> > * &mount_opts
> > + * if (rv != 0) {
> > + * mount_opts.converter->handler->destroy(mount_opts.converter);
> > * } else {
> > * rv = -1;
> > * errno = ENOMEM;
> > diff --git a/cpukit/libblock/src/media.c b/cpukit/libblock/src/media.c
> > index 5b2b06b5b2..2964c19881 100644
> > --- a/cpukit/libblock/src/media.c
> > +++ b/cpukit/libblock/src/media.c
> > @@ -504,6 +504,7 @@ static rtems_status_code mount_worker(
> > if (rv != 0) {
> > rmdir(mount_path);
> > free(mount_path);
> > + mount_options.converter->handler->destroy(mount_options.converter);
> > return RTEMS_IO_ERROR;
> > diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
> > index dc9c76437d..0649258fa7 100644
> > --- a/cpukit/libfs/src/dosfs/msdos_init.c
> > +++ b/cpukit/libfs/src/dosfs/msdos_init.c
> > @@ -102,10 +102,12 @@ int rtems_dosfs_initialize(
> > int rc = 0;
> > const rtems_dosfs_mount_options *mount_options = data;
> > rtems_dosfs_convert_control *converter;
> > + bool converter_created = false;
> > if (mount_options == NULL || mount_options->converter == NULL) {
> > converter = rtems_dosfs_create_default_converter();
> > + converter_created = true;
> > } else {
> > converter = mount_options->converter;
> > @@ -116,6 +118,9 @@ int rtems_dosfs_initialize(
> > &msdos_file_handlers,
> > &msdos_dir_handlers,
> > converter);
> > + if (rc != 0 && converter_created) {
> > + converter->handler->destroy(converter);
> > } else {
> > errno = ENOMEM;
> > rc = -1;
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
