[PATCH rtems-libbsd 2/2] wscript: add uninstall command
Vijay Kumar Banerjee
vijay at rtems.org
Tue Aug 4 15:52:11 UTC 2020
Hi Chris,
Is this patch OK to push to the master?
On Thu, Jul 30, 2020 at 3:51 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> wscript | 5 ++++-
> 1 file changed, 4 insertions(+), 1 deletion(-)
> diff --git a/wscript b/wscript
> index 3ca9478e..74fc1f48 100644
> --- a/wscript
> +++ b/wscript
> @@ -151,7 +151,7 @@ def bsp_init(ctx, env, contexts):
> # Transform the commands to per build variant commands
> commands = []
> for cmd in waflib.Options.commands:
> - if cmd.startswith(('build', 'clean', 'install')):
> + if cmd.startswith(('build', 'clean', 'install', 'uninstall')):
> for builder in builders:
> commands += [str(cmd + '-' + builder)]
> else:
> @@ -226,6 +226,9 @@ def configure(conf):
> update_builders(conf, conf.env.BUILDSET)
> rtems.configure(conf, bsp_configure)
> +def test(bld):
> + rtems.test_uninstall(bld)
> def build(bld):
> rtems.build(bld)
> builders[bld.libbsd_buildset_name].build(bld)
> 2.21.1
