[PATCH] score: Document _Scheduler_Try_to_schedule_node()
Richi Dubey
richidubey at gmail.com
Wed Aug 5 13:32:46 UTC 2020
Thanks for the explanation. I do not understand it right now, but I'm
hoping it'd make sense some time in the future :p
On Wed, Aug 5, 2020 at 12:50 PM Sebastian Huber <
> cpukit/include/rtems/score/schedulerimpl.h | 44 +++++++++++++++++-----
> 1 file changed, 34 insertions(+), 10 deletions(-)
> diff --git a/cpukit/include/rtems/score/schedulerimpl.h
> b/cpukit/include/rtems/score/schedulerimpl.h
> index e7fbb8b166..8f5e1ba7b8 100644
> --- a/cpukit/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/include/rtems/score/schedulerimpl.h
> @@ -929,6 +929,10 @@ RTEMS_INLINE_ROUTINE Thread_Control
> *_Scheduler_Use_idle_thread(
> return idle;
> + * @brief This enumeration defines what a scheduler should do with a node
> which
> + * could be scheduled.
> typedef enum {
> SCHEDULER_TRY_TO_SCHEDULE_DO_SCHEDULE,
> SCHEDULER_TRY_TO_SCHEDULE_DO_IDLE_EXCHANGE,
> @@ -936,21 +940,41 @@ typedef enum {
> } Scheduler_Try_to_schedule_action;
> - * @brief Tries to schedule this scheduler node.
> - * @param context The scheduler instance context.
> - * @param[in, out] node The node which wants to get scheduled.
> - * @param idle A potential idle thread used by a potential victim node.
> - * @param get_idle_thread Function to get an idle thread.
> - * @retval true This node can be scheduled.
> - * @retval false This node cannot be scheduled.
> + * @brief Tries to schedule the scheduler node.
> + * When a scheduler needs to schedule a node, it shall use this function
> to
> + * determine what it shall do with the node. The node replaces a victim
> node if
> + * it can be scheduled.
> + * This function uses the state of the node and the scheduler state of
> the owner
> + * thread to determine what shall be done. Each scheduler maintains its
> nodes
> + * independent of other schedulers. This function ensures that a thread
> is
> + * scheduled by at most one scheduler. If a node requires an executing
> thread
> + * due to some locking protocol and the owner thread is already scheduled
> by
> + * another scheduler, then an idle thread shall be attached to the node.
> + * @param[in, out] context is the scheduler instance context.
> + * @param[in, out] node is the node which could be scheduled.
> + * @param idle is an idle thread used by the victim node or NULL.
> + * @param get_idle_thread points to a function to get an idle thread.
> + * @retval SCHEDULER_TRY_TO_SCHEDULE_DO_SCHEDULE The node shall be
> scheduled.
> + * @retval SCHEDULER_TRY_TO_SCHEDULE_DO_IDLE_EXCHANGE The node shall be
> + * scheduled and the provided idle thread shall be attached to the
> node. This
> + * action is returned, if the node cannot use the owner thread and
> shall use
> + * an idle thread instead. In this case, the idle thread is provided
> by the
> + * victim node.
> + * @retval SCHEDULER_TRY_TO_SCHEDULE_DO_BLOCK The node shall be blocked.
> This
> + * action is returned, if the owner thread is already scheduled by
> another
> + * scheduler.
> RTEMS_INLINE_ROUTINE Scheduler_Try_to_schedule_action
> Scheduler_Context *context,
> Scheduler_Node *node,
> - Thread_Control *idle,
> + const Thread_Control *idle,
> Scheduler_Get_idle_thread get_idle_thread
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200805/02537195/attachment-0001.html>
