[PATCH 2/2] c-user: Avoid Sphinx-specifics in appl config
Thu Aug 6 05:46:49 UTC 2020
This helps to generate Doxygen markup from the application configuration
option specification items.
Update #3994.
 c-user/config/bsp-related.rst       |  8 ++--
 c-user/config/classic-api.rst       | 63 ++++++++++++++++-------------
 c-user/config/classic-init-task.rst |  2 +-
 c-user/config/device-driver.rst     | 26 ++++++------
 c-user/config/filesystem.rst        | 28 ++++++-------
 c-user/config/general.rst           | 12 +++---
 c-user/config/mpci.rst              |  2 +-
 c-user/config/posix-api.rst         | 52 +++++++++++++-----------
 c-user/config/scheduler-general.rst |  6 +--
 9 files changed, 107 insertions(+), 92 deletions(-)
diff --git a/c-user/config/bsp-related.rst b/c-user/config/bsp-related.rst
index 5af5cc2..0b3436c 100644
--- a/c-user/config/bsp-related.rst
+++ b/c-user/config/bsp-related.rst
@@ -104,7 +104,7 @@ DEFAULT VALUE:
 VALUE CONSTRAINTS:
     The value of this configuration option shall be a list of initializers for
-    structures of type :c:type:`rtems_extensions_table`.
+    structures of type ``rtems_extensions_table``.
 DESCRIPTION:
     If
@@ -181,7 +181,7 @@ DEFAULT VALUE:
 VALUE CONSTRAINTS:
 DESCRIPTION:
     If
@@ -259,9 +259,9 @@ DESCRIPTION:
     * and :ref:`CONFIGURE_DISABLE_BSP_SETTINGS` is undefined,
     then not all memory is made available to the C Program Heap immediately at
-    system initialization time.  When :c:func:`malloc()` or other standard memory
+    system initialization time.  When ``malloc()`` or other standard memory
     allocation functions are unable to allocate memory, they will call the BSP
-    supplied :c:func:`sbrk()` function to obtain more memory.
+    supplied ``sbrk()`` function to obtain more memory.
 NOTES:
     This option should not be defined by the application. Only the BSP knows how
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index 41994e0..07c79b2 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -37,9 +37,10 @@ VALUE CONSTRAINTS:
       memory available to the application.
     * It may be defined through
-      :c:func:`rtems_resource_unlimited` the enable unlimited objects for this
-      object class, if the value passed to :c:func:`rtems_resource_unlimited`
-      satisfies all other constraints of this configuration option.
+      ``rtems_resource_unlimited()`` the enable unlimited objects for
+      this object class, if the value passed to
+      ``rtems_resource_unlimited()`` satisfies all other constraints
+      of this configuration option.
 DESCRIPTION:
     The value of this configuration option defines the maximum number of Classic
@@ -78,9 +79,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -121,9 +123,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -162,9 +165,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -203,9 +207,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -244,9 +249,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -285,9 +291,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -334,9 +341,10 @@ VALUE CONSTRAINTS:
       overflow an integer of type ``uintptr_t``.
 DESCRIPTION:
@@ -388,9 +396,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index ca300e7..66ddfb8 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -142,7 +142,7 @@ DESCRIPTION:
     initialization task.
 NOTES:
-    Use :c:func:`rtems_build_name` to define the task name.
+    Use ``rtems_build_name()`` to define the task name.
 .. index:: CONFIGURE_INIT_TASK_PRIORITY
diff --git a/c-user/config/device-driver.rst b/c-user/config/device-driver.rst
index 627c346..40f46a8 100644
--- a/c-user/config/device-driver.rst
+++ b/c-user/config/device-driver.rst
@@ -63,7 +63,7 @@ DEFAULT VALUE:
 VALUE CONSTRAINTS:
-    structures of type :c:type:`rtems_driver_address_table`.
+    structures of type ``rtems_driver_address_table``.
 DESCRIPTION:
     The value of this configuration option is used to initialize the Device
@@ -160,11 +160,11 @@ DESCRIPTION:
     initialized during system initialization.
 NOTES:
-    The Console Driver is responsible for providing the :file:`/dev/console`
+    The Console Driver is responsible for providing the ``/dev/console``
     device file.  This device is used to initialize the standard input, output,
     and error file descriptors.
-    BSPs should be constructed in a manner that allows :c:func:`printk` to work
+    BSPs should be constructed in a manner that allows ``printk()`` to work
     properly without the need for the Console Driver to be configured.
     The
@@ -251,7 +251,7 @@ DEFAULT CONFIGURATION:
     enabled.
 DESCRIPTION:
-    In case this configuration option is defined, then the :file:`/dev/null`
+    In case this configuration option is defined, then the ``/dev/null``
     Driver is initialized during system initialization.
 NOTES:
@@ -307,13 +307,13 @@ DESCRIPTION:
 NOTES:
-    This device driver is responsible for providing the :file:`/dev/console`
+    This device driver is responsible for providing the ``/dev/console``
-    This device driver reads via :c:func:`getchark`.
+    This device driver reads via ``getchark()``.
-    This device driver writes via :c:func:`rtems_putc`.
+    This device driver writes via ``rtems_putc()``.
     The Termios framework is not used.  There is no support to change device
     settings, e.g. baud, stop bits, parity, etc.
@@ -350,21 +350,21 @@ DESCRIPTION:
 NOTES:
     This device driver writes into a write buffer.  The count of characters
     written into the write buffer is returned.  It might be less than the
     requested count, in case the write buffer is full.  The write is
     non-blocking and may be called from interrupt context.  A dedicated task
     reads from the write buffer and outputs the characters via
-    :c:func:`rtems_putc`.  This task runs with the least important priority.
+    ``rtems_putc()``.  This task runs with the least important priority.
     The write buffer size is 2047 characters and it is not configurable.
-    Use ``fsync(STDOUT_FILENO)`` or ``fdatasync(STDOUT_FILENO)`` to drain the
+    Use ``fsync( STDOUT_FILENO )`` or ``fdatasync( STDOUT_FILENO )`` to drain the
     write buffer.
@@ -487,7 +487,7 @@ DEFAULT CONFIGURATION:
     enabled.
 DESCRIPTION:
-    In case this configuration option is defined, then the :file:`/dev/zero`
+    In case this configuration option is defined, then the ``/dev/zero``
 NOTES:
@@ -511,7 +511,7 @@ DEFAULT VALUE:
 VALUE CONSTRAINTS:
 DESCRIPTION:
diff --git a/c-user/config/filesystem.rst b/c-user/config/filesystem.rst
index b429a4f..ca00dc6 100644
--- a/c-user/config/filesystem.rst
+++ b/c-user/config/filesystem.rst
@@ -72,7 +72,7 @@ DESCRIPTION:
 NOTES:
     Filesystems shall be initialized to support file descriptor based device
-    drivers and basic input/output functions such as :c:func:`printf`.
+    drivers and basic input/output functions such as ``printf()``.
     Filesystems can be disabled to reduce the memory footprint of an application.
 .. index:: CONFIGURE_FILESYSTEM_ALL
@@ -311,7 +311,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
     In case this configuration option is defined, then the root IMFS does not
-    support changing the mode of files (no support for :c:func:`chmod`).
+    support changing the mode of files (no support for ``chmod()``).
 NOTES:
     None.
@@ -335,7 +335,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support changing the ownership of files (no support for :c:func:`chown`).
+    support changing the ownership of files (no support for ``chown()``).
 NOTES:
     None.
@@ -359,7 +359,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support hard links (no support for :c:func:`link`).
+    support hard links (no support for ``link()``).
 NOTES:
     None.
@@ -383,7 +383,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support making files (no support for :c:func:`mknod`).
+    support making files (no support for ``mknod()``).
 NOTES:
     None.
@@ -455,7 +455,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support mounting other filesystems (no support for :c:func:`mount`).
+    support mounting other filesystems (no support for ``mount()``).
 NOTES:
     None.
@@ -479,7 +479,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support reading directories (no support for :c:func:`readdir`).  It is still
+    support reading directories (no support for ``readdir()``).  It is still
     possible to open files in a directory.
 NOTES:
@@ -504,7 +504,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support reading symbolic links (no support for :c:func:`readlink`).
+    support reading symbolic links (no support for ``readlink()``).
 NOTES:
     None.
@@ -528,7 +528,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support renaming files (no support for :c:func:`rename`).
+    support renaming files (no support for ``rename()``).
 NOTES:
     None.
@@ -552,7 +552,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support removing files (no support for :c:func:`rmnod`).
+    support removing files (no support for ``rmnod()``).
 NOTES:
     None.
@@ -576,7 +576,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support creating symbolic links (no support for :c:func:`symlink`).
+    support creating symbolic links (no support for ``symlink()``).
 NOTES:
     None.
@@ -600,7 +600,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support unmounting other filesystems (no support for :c:func:`unmount`).
+    support unmounting other filesystems (no support for ``unmount()``).
 NOTES:
     None.
@@ -624,7 +624,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
-    support changing file times (no support for :c:func:`utime`).
+    support changing file times (no support for ``utime()``).
 NOTES:
     None.
@@ -644,7 +644,7 @@ OPTION TYPE:
     If this configuration option is undefined, then the root IMFS does not
-    support making FIFOs (no support for :c:func:`mkfifo`).
+    support making FIFOs (no support for ``mkfifo()``).
 DESCRIPTION:
     In case this configuration option is defined, then the root IMFS supports
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index 4fa03f9..d495c7a 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -63,7 +63,7 @@ DESCRIPTION:
 NOTES:
     You can enable this option to reduce the size of the :term:`TCB`.  Use this
     option with care, since it can lead to race conditions and undefined system
-    behaviour.  For example, :c:data:`errno` is no longer a thread-local variable
+    behaviour.  For example, ``errno`` is no longer a thread-local variable
     if this option is enabled.
 .. index:: CONFIGURE_EXECUTIVE_RAM_SIZE
@@ -159,7 +159,7 @@ DEFAULT VALUE:
 VALUE CONSTRAINTS:
 DESCRIPTION:
     The value of this configuration option is used to initialize the table of
@@ -242,7 +242,7 @@ DEFAULT CONFIGURATION:
 DESCRIPTION:
     In case this configuration option is defined, then each memory area returned
-    by C Program Heap allocator functions such as :c:func:`malloc` is dirtied
+    by C Program Heap allocator functions such as ``malloc()`` is dirtied
     with a ``0xCF`` byte pattern before it is handed over to the application.
 NOTES:
@@ -716,14 +716,14 @@ DESCRIPTION:
     If :ref:`CONFIGURE_UNLIMITED_OBJECTS` is defined, then the value of this
     configuration option defines the default objects maximum of all object
     classes supporting :ref:`ConfigUnlimitedObjects` to
-    ``rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)``.
+    ``rtems_resource_unlimited( CONFIGURE_UNLIMITED_ALLOCATION_SIZE )``.
 NOTES:
     By allowing users to declare all resources as being unlimited the user can
     avoid identifying and limiting the resources used.
     The object maximum of each class can be configured also individually using
-    the :c:func:`rtems_resource_unlimited` macro.
+    the ``rtems_resource_unlimited()`` macro.
 .. index:: CONFIGURE_UNLIMITED_OBJECTS
@@ -779,7 +779,7 @@ DESCRIPTION:
 NOTES:
     You may use this feature to debug system initialization issues.  The
-    :c:func:`printk` function is used to print the information.
+    ``printk()`` function is used to print the information.
 .. index:: CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
 .. index:: clear C Program Heap
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index 1413474..7ffb24a 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -189,7 +189,7 @@ DEFAULT VALUE:
 VALUE CONSTRAINTS:
     The value of this configuration option shall be a pointer to
-    :c:type:`rtems_mpci_table`.
+    ``rtems_mpci_table``.
 DESCRIPTION:
     The value of this configuration option initializes the MPCI Configuration
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index 6603b66..7a683d4 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -40,9 +40,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
     The value of this configuration option defines the maximum number of POSIX
@@ -84,9 +85,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
     The value of this configuration option defines the maximum number of key
@@ -96,8 +98,8 @@ NOTES:
     This object class can be configured in unlimited allocation mode, see
     :ref:`ConfigUnlimitedObjects`.
-    A key value pair is created by :c:func:`pthread_setspecific` if the value
-    is not :c:macro:`NULL`, otherwise it is deleted.
+    A key value pair is created by ``pthread_setspecific()`` if the value
+    is not NULL, otherwise it is deleted.
 .. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
@@ -132,9 +134,10 @@ VALUE CONSTRAINTS:
       not overflow an integer of type ``uintptr_t``.
 DESCRIPTION:
@@ -224,9 +227,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -236,9 +240,9 @@ NOTES:
-    Named semaphores are created with :c:func:`sem_open()`.  Semaphores
-    initialized with :c:func:`sem_init()` are not affected by this configuration
-    option since the storage space for these semaphores is user-provided.
+    Named semaphores are created with ``sem_open()``.  Semaphores initialized
+    with ``sem_init()`` are not affected by this configuration option since the
+    storage space for these semaphores is user-provided.
 .. index:: CONFIGURE_MAXIMUM_POSIX_SHMS
@@ -273,9 +277,10 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
@@ -364,9 +369,10 @@ VALUE CONSTRAINTS:
     * It shall be zero if the POSIX API is not
       enabled (e.g. RTEMS was built without the ``--enable-posix`` build
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 68e7a45..274a7cf 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -150,7 +150,7 @@ VALUE CONSTRAINTS:
       * ``RTEMS_SCHEDULER_ASSIGN( processor_index, attributes )``
-      * :c:macro:`RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER`
+      * ``RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER``
     * It shall be a list of exactly
       :ref:`CONFIGURE_MAXIMUM_PROCESSORS` elements.
@@ -303,9 +303,9 @@ NOTES:
     This scheduler configuration option is an advanced configuration option.
     Think twice before you use it.
-    Schedulers can be identified via c:func:`rtems_scheduler_ident`.
+    Schedulers can be identified via ``rtems_scheduler_ident()``.
-    Use :c:func:`rtems_build_name` to define the scheduler name.
+    Use ``rtems_build_name()`` to define the scheduler name.
 .. index:: CONFIGURE_SCHEDULER_PRIORITY
2.26.2
