[PATCH 1/2] c-user: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
Thu Aug 6 09:40:54 UTC 2020
Improve formatting.
 c-user/config/filesystem.rst | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/c-user/config/filesystem.rst b/c-user/config/filesystem.rst
index b429a4f..8d1efbd 100644
--- a/c-user/config/filesystem.rst
+++ b/c-user/config/filesystem.rst
@@ -66,8 +66,8 @@ DEFAULT CONFIGURATION:
     configured filesystems are initialized during system initialization.
 DESCRIPTION:
-    In case this configuration option is defined, then **no** base filesystem is
-    initialized during system initialization and **no** filesystems are
+    In case this configuration option is defined, then **no base filesystem** is
+    initialized during system initialization and **no filesystems** are
     configured.
 NOTES:
2.26.2
