[PATCH] user: Add shell environment migration aid
Sebastian Huber
Thu Aug 6 11:30:58 UTC 2020
Close #3859.
user/migration/v4_11-to-v5.rst | 27 +++++++++++++++++++++++++++
1 file changed, 27 insertions(+)
diff --git a/user/migration/v4_11-to-v5.rst b/user/migration/v4_11-to-v5.rst
index a0cab02..0e0fb46 100644
--- a/user/migration/v4_11-to-v5.rst
+++ b/user/migration/v4_11-to-v5.rst
@@ -126,3 +126,30 @@ interface name.
exit(1);
+Shell Environment
+To address resource leaks in the RTEMS shell, the management of shell
+environments changed. This change may break existing code. Here is an example
+how a broken Telnet shell can be fixed:
+. code-block:: c
+ static void
+ telnet_shell( char *name, void *arg )
+ rtems_shell_env_t env;
+ /* Previous WRONG approach: memset( &env, 0, sizeof( env) ); */
+ /* Correct way to initialize the shell environment */
+ rtems_shell_dup_current_env( &env );
+ env.devname = name;
+ env.taskname = "TLNT";
+ env.login_check = NULL;
+ env.forever = false;
+ rtems_shell_main_loop( &env );
2.26.2
