Explanation about the high level design choices of Strong APA
Thu Aug 6 14:42:21 UTC 2020
Thanks for the detailed write-up. My only concern with your choice is
whether these two function pointers, get_highest_ready and
get_lowest_ready, will get called along other paths when there hasn't
been a task arrival/departure? This shouldn't cause a correctness
problem, but it may cause a performance problem.
 A bit relatedly, are there other task arrivals/departures that you
should understand to make sure you are covering things completely? Do
they all traverse the Scheduler_Unblock/Scheduler_Block? If not, then
it would be a correctness problem.
Gedare
On Tue, Aug 4, 2020 at 8:20 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> Implementing the Strong APA scheduler requires finding places to put the two most important algorithms (pages 5 and 6 from the paper) in the current RTEMS SMP scheduler framework.
> I have chosen get_highest_ready and get_lowest_ready to implement these function and my reasoning behind doing so is documented in the blog post-https://rtemswithrichi.wordpress.com/adding-strong-apa-to-rtems-identifying-relevant-functions/.
> I would love to hear your insights about the post.
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
