Low level design description for _Scheduler_strong_APA_Get_lowest_scheduled
Richi Dubey
richidubey at gmail.com
Thu Aug 6 15:18:33 UTC 2020
The part 3 corresponding to the backtracking changes the filter_node
pointer (the original node pointer passed to the function) and calls the
Scheduler_SMP_Preempt, all of which is documented in the blog post. I feel
like this might mean that the file is taking a higher-level role that it is
supposed to and I cannot progress further without your views on this.
On Thu, Aug 6, 2020 at 8:45 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> Please find the blog post-
> https://rtemswithrichi.wordpress.com/strong-apa-low-level-design-in-rtems/ that
> explains the low-level design for get_lowest_function, importance of which
> was explained in the earlier high-level design description mail
> <https://lists.rtems.org/pipermail/devel/2020-August/061120.html>.
> I really need your help in figuring out part 3 of the explanation
> corresponding to backtracking part of the algorithm in the blog post.
> If it helps, Please find the latest pull request here
> <https://github.com/richidubey/rtems/pull/6> and the edited files
> schedulerstrongapa.c
> <https://github.com/richidubey/rtems/blob/Strong-APA-v1.2/cpukit/score/src/schedulerstrongapa.c>,
> schedulerstrongapa.h
> <https://github.com/richidubey/rtems/blob/Strong-APA-v1.2/cpukit/include/rtems/score/schedulerstrongapa.h>
> and scheduler.h
> <https://github.com/richidubey/rtems/blob/Strong-APA-v1.2/cpukit/include/rtems/scheduler.h>
> Thanks!
> Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200806/3aed375b/attachment.html>
