[PATCH v2 0/1] Generate application configuration option documentation
Sebastian Huber
Thu Aug 6 17:57:46 UTC 2020
On 06/08/2020 17:17, Gedare Bloom wrote:
> On Thu, Aug 6, 2020 at 7:16 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> This patch adds the application configuration option documentation generated
>> from specification items:
>> https://git.rtems.org/rtems-central.git/tree/spec/if/acfg
>> The header file is generated by the following script and module:
>> https://git.rtems.org/rtems-central.git/tree/spec2doc.py
>> https://git.rtems.org/rtems-central.git/tree/rtemsqual/applconfig.py
> The generated file should be identified explicitly as a generated
> file, and perhaps embed the methodology for (re)generating it as well.
What about this:
/* SPDX-License-Identifier: BSD-2-Clause */
* Copyright (C) 2019, 2020 embedded brains GmbH
(http://www.embedded-brains.de)
* Copyright (C) 2010 Gedare Bloom
* Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
OF THE
* POSSIBILITY OF SUCH DAMAGE.
* This file was automatically generated. Do not edit it manually.
* Please have a look at
* https://docs.rtems.org/branches/master/eng/req/howto.html
* for information how to maintain and re-generate this file.
* @defgroup RTEMSApplConfig Application Configuration Options
* @ingroup RTEMSAPI
>> The module uses currently a hack to resolve references external to specification
>> items, e.g. sections in the RTEMS Classic API Guide or URLs. I think we need
>> specialized specification items for these external references.
>> This patch is huge and contains all application configuration options of
>> RTEMS. The review objectives for this patch should be:
>> 1. The header file name and location.
> I don't mind the location cpukit/doxygen
> Should/could we also move cpukit/doxygen.h into that directory?
Yes, I would like to move this stuff to a common directory.
>> 2. The general Doxygen markup.
> Can you share a generated doxygen html? (I'm being a little lazy not
> to do it myself.)
> I skimmed the patch and the markup/content looks fine, but it would be
> good to skim the output also.
https://ftp.rtems.org/pub/rtems/people/sebh/doc/html/index.html
