RTEMS 5 on the start page of RTEMS.org
Sat Aug 8 16:17:21 UTC 2020
On Sat, Aug 8, 2020, 10:56 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Joel,
> On 08/08/2020 17:51, Joel Sherrill wrote:
> > On Sat, Aug 8, 2020, 10:38 AM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> >     Hello,
> >     I noted that on the start page of www.rtems.org
> >     <http://www.rtems.org>, there are still a lot
> >     of outdated references to the last release. One of the most obvious
> is
> >     the Documentation section on the right and the "Release and Active
> >     Development" section.
> >     I don't think that our home page is in a git repo so that I could
> send a
> >     patch?
> > That would be nice but it isn't the way it is now. It is in Drupal now.
> > Personally I have decided an active CMS is too heavy for many websites.
> > Hugo looks like a decent way for us to go as best I can tell. It is a
> > static site generator with lots of themes. But it takes work.
> I worked a bit with Hugo on some other pages. It's a nice system.
As long as you have Go. :)
> >     Who would be able to update the links?
> > Me for one. Please file a ticket with specific changes and I will make
> > them. Please please please don't make me find everything and the right
> > destination. It is tedious enough executing the changes.
> I'll try to find most locations in the next days. What format would be
> the best one for you? A screenshot with marked locations?
You can do a text file if you want. Just name the box on the front page,
text and link to change and new destination.
Usually they are easy to locate.
Community > Mailing Lists should be new url
Probably will work for most.
If in text, just try. :)
--joel
> Best regards
> Christian
> > --joel
> >     Best regards
> >     Christian
> >     _______________________________________________
> >     devel mailing list
> >     devel at rtems.org <mailto:devel at rtems.org>
> >     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200808/17a3f720/attachment-0001.html>
