Name of the primary network interface, how to find in bsp header files?
Mon Aug 10 04:32:09 UTC 2020
On 10/8/20 4:20 am, Heinz Junkes wrote:
> Hello, Chris,
> with libbsd I also realized this with the concept you suggested (still beta development):
>     sc = rtems_bsd_initialize();
>     assert(sc == RTEMS_SUCCESSFUL);
>     /* Let the callout timer allocate its resources */
>     sc = rtems_task_wake_after(2);
>     rtems_bsd_ifconfig_lo0();
> //  lookup available network interfaces
>     char ifnamebuf[IF_NAMESIZE];
>     char *ifname;
> // get primary network interface
>     ifname = if_indextoname(1, &ifnamebuf[0]);
>     assert(ifname != NULL);
>     printf("\n***** Primary Network interface : %s *****\n", ifname);
>     default_network_dhcpcd();
>     // implement DHCP hook  ... and wait for acknowledge
>     dhcpDone = epicsEventMustCreate(epicsEventEmpty);
>     rtems_dhcpcd_add_hook(&dhcpcd_hook);
Is it a requirement for EPICS systems to be DHCP?
>     // wait for dhcp done ... should be if SYNCDHCP is used
>     epicsEventWaitStatus stat;
>     int counter = 10;
>     do {
>         printf("\n ---- Wait for DHCP done ...\n");
>         stat = epicsEventWaitWithTimeout(dhcpDone, 5.0);
>     } while ((stat == epicsEventWaitTimeout) && (--counter > 0));
>     if (stat == epicsEventOK)
>         epicsEventDestroy(dhcpDone);
>     else
>         printf("\n ---- dhcpDone Event Unknown state %d\n", stat);
> static void
> default_network_dhcpcd(void)
>         static const char default_cfg[] = "clientid FHI test client\n";
>         rtems_status_code sc;
>         int fd;
>         int rv;
>         ssize_t n;
> fd = open("/etc/dhcpcd.conf", O_CREAT | O_WRONLY,
>     S_IRWXU | S_IRWXG | S_IRWXO);
> assert(fd >= 0);
> n = write(fd, default_cfg, sizeof(default_cfg) - 1);
> assert(n == (ssize_t) sizeof(default_cfg) - 1);
> static const char fhi_cfg[] = "nodhcp6\nipv4only\noption ntp_servers\noption rtems_cmdline\n";
What is `option rtems_cmdline? Is this a special EPICS option?
There is no `allowinterfaces` so it seems this is for a single interface machine.
While this may work for the qemu testrig we will need something more for the RSB
configuration.
> n = write(fd, fhi_cfg, sizeof(fhi_cfg) - 1);
> assert(n == (ssize_t) sizeof(fhi_cfg) - 1);
> rv = close(fd);
> assert(rv == 0);
> sc = rtems_dhcpcd_start(NULL);
> static void
> dhcpcd_hook_handler(rtems_dhcpcd_hook *hook, char *const *env)
> int bound = 0;
> char iName[16];
> char *name;
> char *value;
>         (void)hook;
>         while (*env != NULL) {
>                 name = strtok(*env,"=");
>                 value = strtok(NULL,"=");
>         printf("all out ---> %s = %s\n", name, value);
>                 if (!strncmp(name, "interface", 9) && !strcmp(value,  NET_CFG_INTERFACE_0))
>                          strncpy(iName, value, 16);
>                 if (!strncmp(name, "reason", 6) && !strncmp(value, "BOUND", 5)){
>                   printf ("Interface %s bounded\n", iName);
>                   bound = 1;
>                 if (bound) {
>                   // as there is no ntp-support in rtems-libbsd, we call our own client
>                   if(!strncmp(name, "new_ntp_servers", 15))
>                     strcpy(rtemsInit_NTP_server_ip,value);
>                   if(!strncmp(name, "new_host_name", 13))
>                     sethostname (value, strlen (value));
>                   if(!strncmp(name, "new_tftp_server_name", 20)){
>                     printf(" new_tftp_server_name : %s\n", value);
>                     strncpy(rtems_bsdnet_bootp_server_name,value, sizeof(bootp_server_name_init));
>                   printf("---> %s = %s\n", name, value);
>                 ++env;
> if (bound)
>   epicsEventSignal(dhcpDone);
> static rtems_dhcpcd_hook dhcpcd_hook = {
>         .name = "ioc boot",
>         .handler = dhcpcd_hook_handler
> But the biggest problem here is that on the test-CI-system (travis, appveyor, etc.) a dhcp-server,
> ntp-server, nfs-server and complex routing structures for e.g. qemu must be provided.
Yes I am sure it is complicated. Is your work just focused on this test set up?
> There it is easier to use environment variables.
In the hook I suspect it is the simplest.
> Many greetings
> Heinz
>> On 9. Aug 2020, at 02:44, Chris Johns <chrisj at rtems.org> wrote:
>>> nging configuration. And likely only one NIC.
>> Agreed and it works for a testsuite to some extent. Network tests are hard
>> because you need a very controlled network set up to make then work.
>>> It was used in the network demos for the legacy stack so if we want to
>>> eliminate it completely, it would be good to find a recommended way to
>>> look up the interface name and put it into the legacy configuration
>>> tables.
>>> https://git.rtems.org/network-demos/tree
>>> Yes... I know we all want to see it removed and everyone move to
>>> libbsd. But I don't think that is realistic to expect. The more realistic
>>> solution is to move it to its own build tree and freeze it. It is there
>>> and we encourage people to use libbsd. But it does offer a solution
>>> for older target boards. The old stack is also all that is supported by
>>> many EPICS boards. Outside of EPICS users, even the SPARC BSPs
>>> haven't been converted yet.
>> Yes we should move it out of the main tree and have it becomes an available
>> optional package. It can be maintained by those with an active interest in it.
>> It has some bugs ... we found one last year with the arp cache and Windows. The
>> solution was a hack to set the arp aging timer to a very large number.
>>> Anyway... I'd love to see RTEMS_BSP_NETWORK_DRIVER_NAME
>>> killed completely but we need to address filling in the legacy network
>>> stack table before the stack is initialized enough to even know the
>>> interface names.
>> Yes, but Heinz is working on libbsd support for EPICS or have I missed something?
>>> Perhaps this turns into an application provided method for the legacy
>>> stack? Just a thought.
>> Yes that works.
>> Chris
