[PATCH 1/3] rtems: Remove RTEMS 6 build sets.
chrisj at rtems.org
chrisj at rtems.org
Tue Aug 11 01:44:29 UTC 2020
Updates #4014
rtems/config/6/rtems-aarch64.bset | 4 ----
rtems/config/6/rtems-all.bset | 19 ---------------
rtems/config/6/rtems-arm.bset | 4 ----
rtems/config/6/rtems-autotools-base.bset | 9 -------
rtems/config/6/rtems-autotools-internal.bset | 11 ---------
rtems/config/6/rtems-autotools.bset | 25 --------------------
rtems/config/6/rtems-base.bset | 13 ----------
rtems/config/6/rtems-bfin.bset | 3 ---
rtems/config/6/rtems-default.bset | 15 ------------
rtems/config/6/rtems-epiphany.bset | 17 -------------
rtems/config/6/rtems-i386.bset | 4 ----
rtems/config/6/rtems-lm32.bset | 3 ---
rtems/config/6/rtems-m68k.bset | 3 ---
rtems/config/6/rtems-microblaze.bset | 3 ---
rtems/config/6/rtems-mips.bset | 6 -----
rtems/config/6/rtems-moxie.bset | 6 -----
rtems/config/6/rtems-nios2.bset | 3 ---
rtems/config/6/rtems-or1k.bset | 3 ---
rtems/config/6/rtems-powerpc.bset | 4 ----
rtems/config/6/rtems-riscv.bset | 4 ----
rtems/config/6/rtems-sh.bset | 3 ---
rtems/config/6/rtems-sparc.bset | 6 -----
rtems/config/6/rtems-sparc64.bset | 3 ---
rtems/config/6/rtems-v850.bset | 3 ---
rtems/config/6/rtems-x86_64.bset | 4 ----
25 files changed, 178 deletions(-)
delete mode 100644 rtems/config/6/rtems-aarch64.bset
delete mode 100644 rtems/config/6/rtems-all.bset
delete mode 100644 rtems/config/6/rtems-arm.bset
delete mode 100644 rtems/config/6/rtems-autotools-base.bset
delete mode 100644 rtems/config/6/rtems-autotools-internal.bset
delete mode 100644 rtems/config/6/rtems-autotools.bset
delete mode 100644 rtems/config/6/rtems-base.bset
delete mode 100644 rtems/config/6/rtems-bfin.bset
delete mode 100644 rtems/config/6/rtems-default.bset
delete mode 100644 rtems/config/6/rtems-epiphany.bset
delete mode 100644 rtems/config/6/rtems-i386.bset
delete mode 100644 rtems/config/6/rtems-lm32.bset
delete mode 100644 rtems/config/6/rtems-m68k.bset
delete mode 100644 rtems/config/6/rtems-microblaze.bset
delete mode 100644 rtems/config/6/rtems-mips.bset
delete mode 100644 rtems/config/6/rtems-moxie.bset
delete mode 100644 rtems/config/6/rtems-nios2.bset
delete mode 100644 rtems/config/6/rtems-or1k.bset
delete mode 100644 rtems/config/6/rtems-powerpc.bset
delete mode 100644 rtems/config/6/rtems-riscv.bset
delete mode 100644 rtems/config/6/rtems-sh.bset
delete mode 100644 rtems/config/6/rtems-sparc.bset
delete mode 100644 rtems/config/6/rtems-sparc64.bset
delete mode 100644 rtems/config/6/rtems-v850.bset
delete mode 100644 rtems/config/6/rtems-x86_64.bset
diff --git a/rtems/config/6/rtems-aarch64.bset b/rtems/config/6/rtems-aarch64.bset
deleted file mode 100644
index e3c91af..0000000
--- a/rtems/config/6/rtems-aarch64.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch aarch64
-%define with_libgomp
-%include 6/rtems-default.bset
diff --git a/rtems/config/6/rtems-all.bset b/rtems/config/6/rtems-all.bset
index 8f020f9..0000000
--- a/rtems/config/6/rtems-all.bset
+++ /dev/null
@@ -1,19 +0,0 @@
-6/rtems-aarch64
-6/rtems-arm
-6/rtems-bfin
-6/rtems-epiphany
-6/rtems-i386
-6/rtems-lm32
-6/rtems-m68k
-6/rtems-microblaze
-6/rtems-mips
-6/rtems-moxie
-6/rtems-nios2
-6/rtems-or1k
-6/rtems-powerpc
-6/rtems-riscv
-6/rtems-sh
-6/rtems-sparc
-6/rtems-sparc64
-6/rtems-v850
-6/rtems-x86_64
diff --git a/rtems/config/6/rtems-arm.bset b/rtems/config/6/rtems-arm.bset
index 425d66b..0000000
--- a/rtems/config/6/rtems-arm.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch arm
diff --git a/rtems/config/6/rtems-autotools-base.bset b/rtems/config/6/rtems-autotools-base.bset
index c6819c1..0000000
--- a/rtems/config/6/rtems-autotools-base.bset
+++ /dev/null
@@ -1,9 +0,0 @@
-%define release 1
-%define rtems_arch none
-%include 6/rtems-base.bset
-package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
-tools/rtems-autoconf-2.69-1
-tools/rtems-automake-1.12.6-1
diff --git a/rtems/config/6/rtems-autotools-internal.bset b/rtems/config/6/rtems-autotools-internal.bset
index 19d2f19..0000000
--- a/rtems/config/6/rtems-autotools-internal.bset
+++ /dev/null
@@ -1,11 +0,0 @@
-# Do not use via the command line.
-%define _internal_autotools yes
-%define _disable_collecting yes
-%define _disable_packaging yes
-%define _disable_reporting yes
-%define _disable_installing yes
-%include 6/rtems-autotools-base.bset
diff --git a/rtems/config/6/rtems-autotools.bset b/rtems/config/6/rtems-autotools.bset
index e57d25d..0000000
--- a/rtems/config/6/rtems-autotools.bset
+++ /dev/null
@@ -1,25 +0,0 @@
-# Autoconf and automake are not relocatable and cannot be cross-compiled.
-# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
-# bootstrapping and this requires a current autoconf and automake. The RSB
-# provides to support by:
-# 1. Building and installing autoconf and automake with a prefix to a
-# temporary internal path.
-# 2. Using the temporary internal build, build and install another copy
-# using the final prefix location.
-# A magic internal path that would break if changes in the defaults.mc
-# macro file are made.
-%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
-# Disable emailing reports of this building for RTEMS.
-%define mail_disable
-6/rtems-autotools-internal
-6/rtems-autotools-base
diff --git a/rtems/config/6/rtems-base.bset b/rtems/config/6/rtems-base.bset
index ba394ef..0000000
--- a/rtems/config/6/rtems-base.bset
+++ /dev/null
@@ -1,13 +0,0 @@
-%define rtems_version 6
-%define _target %{rtems_arch}-rtems%{rtems_version}
-%define gcc_version_message RTEMS %{rtems_version}, RSB %{_sbgit_id}, Newlib %{newlib_version}
-%include rtems-urls.bset
-%ifos win32 mingw ming32
- %define rtems_waf_build_root_suffix %{waf_build_root_suffix}
-%else
- %define rtems_waf_build_root_suffix %{nil}
-%endif
-package: rtems-%{rtems_version}-%{_target}-%{_host}-%{release}
diff --git a/rtems/config/6/rtems-bfin.bset b/rtems/config/6/rtems-bfin.bset
index 12a215e..0000000
--- a/rtems/config/6/rtems-bfin.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch bfin
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 31ce3aa..0000000
--- a/rtems/config/6/rtems-default.bset
+++ /dev/null
@@ -1,15 +0,0 @@
-6/rtems-autotools
-# Build gdb first to raise the Python install error as early as possible.
-# GDB needs expat so it needs to be built before.
-devel/expat-2.1.0-1
-tools/rtems-gdb-head
-tools/rtems-binutils-head
-tools/rtems-gcc-head-newlib-head
-tools/rtems-tools-5-1
diff --git a/rtems/config/6/rtems-epiphany.bset b/rtems/config/6/rtems-epiphany.bset
index c0a6f16..0000000
--- a/rtems/config/6/rtems-epiphany.bset
+++ /dev/null
@@ -1,17 +0,0 @@
-%define release 1
-%define rtems_arch epiphany
-# Custom GDB
-%define gdb_external 1
-%define gdb_expand_name epiphany-binutils-gdb-f05996c7c42e6b2781946acbab153a481ce3fd0b
-%source set gdb https://github.com/adapteva/epiphany-binutils-gdb/archive/f05996c7c42e6b2781946acbab153a481ce3fd0b.zip
-%hash sha256 f05996c7c42e6b2781946acbab153a481ce3fd0b.zip 2b2034fd12f2fd5108205ade66400c175ede8cef8141a38ae03fc78bf2d65325
-6/rtems-autotools
-tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/6/rtems-i386.bset b/rtems/config/6/rtems-i386.bset
index a27319d..0000000
--- a/rtems/config/6/rtems-i386.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch i386
diff --git a/rtems/config/6/rtems-lm32.bset b/rtems/config/6/rtems-lm32.bset
index b5afad1..0000000
--- a/rtems/config/6/rtems-lm32.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch lm32
diff --git a/rtems/config/6/rtems-m68k.bset b/rtems/config/6/rtems-m68k.bset
index 0932d20..0000000
--- a/rtems/config/6/rtems-m68k.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch m68k
diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
index 0e35a65..0000000
--- a/rtems/config/6/rtems-microblaze.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch microblaze
diff --git a/rtems/config/6/rtems-mips.bset b/rtems/config/6/rtems-mips.bset
index 370e5ea..0000000
--- a/rtems/config/6/rtems-mips.bset
+++ /dev/null
@@ -1,6 +0,0 @@
-%define release 1
-%define rtems_arch mips
-%define gdb-sim-options --enable-sim-hardware
-%define win32-gdb-disable-sim
-tools/rtems-mipstx39-gdb-head
diff --git a/rtems/config/6/rtems-moxie.bset b/rtems/config/6/rtems-moxie.bset
index be00950..0000000
--- a/rtems/config/6/rtems-moxie.bset
+++ /dev/null
@@ -1,6 +0,0 @@
-%define release 1
-%define rtems_arch moxie
-devel/dtc-1.4.1-1
diff --git a/rtems/config/6/rtems-nios2.bset b/rtems/config/6/rtems-nios2.bset
index 522eff5..0000000
--- a/rtems/config/6/rtems-nios2.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch nios2
diff --git a/rtems/config/6/rtems-or1k.bset b/rtems/config/6/rtems-or1k.bset
index c299c25..0000000
--- a/rtems/config/6/rtems-or1k.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch or1k
diff --git a/rtems/config/6/rtems-powerpc.bset b/rtems/config/6/rtems-powerpc.bset
index c19327a..0000000
--- a/rtems/config/6/rtems-powerpc.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch powerpc
diff --git a/rtems/config/6/rtems-riscv.bset b/rtems/config/6/rtems-riscv.bset
index 42a4ebd..0000000
--- a/rtems/config/6/rtems-riscv.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch riscv
diff --git a/rtems/config/6/rtems-sh.bset b/rtems/config/6/rtems-sh.bset
index f867962..0000000
--- a/rtems/config/6/rtems-sh.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch sh
diff --git a/rtems/config/6/rtems-sparc.bset b/rtems/config/6/rtems-sparc.bset
index 48d152d..0000000
--- a/rtems/config/6/rtems-sparc.bset
+++ /dev/null
@@ -1,6 +0,0 @@
-%define release 1
-%define rtems_arch sparc
-%define gdb-disable-sim 1
-devel/sis-2-1
diff --git a/rtems/config/6/rtems-sparc64.bset b/rtems/config/6/rtems-sparc64.bset
index 8da80a6..0000000
--- a/rtems/config/6/rtems-sparc64.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch sparc64
diff --git a/rtems/config/6/rtems-v850.bset b/rtems/config/6/rtems-v850.bset
index dd68147..0000000
--- a/rtems/config/6/rtems-v850.bset
+++ /dev/null
@@ -1,3 +0,0 @@
-%define release 1
-%define rtems_arch v850
diff --git a/rtems/config/6/rtems-x86_64.bset b/rtems/config/6/rtems-x86_64.bset
index dbfc9e6..0000000
--- a/rtems/config/6/rtems-x86_64.bset
+++ /dev/null
@@ -1,4 +0,0 @@
-%define release 1
-%define rtems_arch x86_64
2.27.0
