Need help in debugging a testsuite over qemu and gdb
Sebastian Huber
Tue Aug 11 07:59:33 UTC 2020
On 11/08/2020 09:51, Richi Dubey wrote:
> Hi,
> I have been trying to debug a test suite (this patch
> <https://lists.rtems.org/pipermail/devel/2020-July/060945.html>) with
> qemu and gdb by running the following commands:
> ./arm-rtems5-gdb
> ~/quick-start/build/b3-realview/arm-rtems5/c/realview_pbx_a9_qemu/testsuites/smptests/smpstrongapa01.exe
> > target remote localhost:1234
> > b Init
> > continue
> Continuing.
> [Inferior 1 (process 1) exited normally]
> ./qemu-system-arm -net none -nographic -M realview-pbx-a9 -m 256M
> -kernel
> -smp 3 -no-reboot -S -s
If you want to debug the target via GDB, then I would drop the "-no-reboot".
Please have a look at the attached GDB initialization script. You can
use it via:
arm-rtems6-gdb --arm.gdb app.exe
To start the application use the "continue" command.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
set print elements 0
set print pretty on
set pagination off
set confirm off
tar remote :1234
load
info threads
def reset
monitor system_reset
load
end
def new
make
load
end
b _ARM_Exception_default
b _ARMV4_Exception_data_abort_default
b bsp_interrupt_handler_default
b bsp_reset
b _Terminate
reset
