Need help in debugging a testsuite over qemu and gdb
Sebastian Huber
Tue Aug 11 10:30:09 UTC 2020
On 11/08/2020 11:40, Richi Dubey wrote:
> (gdb) continue
> Continuing.
> Thread 1 hit Breakpoint 2, _ARMV4_Exception_data_abort_default () at
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/cpu/arm/armv4-exception-default.S:70
If you hit this break point, try to use
bt
and then set a conditional break point to the offending function, reset
the target, and run again.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
