Need help understand how the scheduler table entries work
Gedare Bloom
gedare at rtems.org
Tue Aug 11 13:09:24 UTC 2020
On Tue, Aug 11, 2020 at 12:42 AM Richi Dubey <richidubey at gmail.com> wrote:
> This really helped. Thank you.
>> There is not really anything to change about it. You specialize the
>> scheduler by the Scheduler_Context and Scheduler_Operations
>> structures. You still just pass through the context base to the
>> scheduler table.
> I understand. The Ready queue per priority that was used earlier (link) has to be removed. Hence the question.
Hopefully, you have got to know that is just to find the maximum
priority in setting up the table entry.
> Thank you.
> On Mon, Aug 10, 2020 at 9:04 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Aug 10, 2020 at 9:10 AM Richi Dubey <richidubey at gmail.com> wrote:
>> > Hi,
>> > I want your help to figure out how the table entries for a scheduler work.
>> > For STRONG_APA scheduler, the flow is :
>> > link
>> > #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
>> > &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
>> > SCHEDULER_STRONG_APA_ENTRY_POINTS, \
>> > RTEMS_ARRAY_SIZE( \
>> > SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
>> > ) - 1, \
>> > ( obj_name ) \
>> > SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
>> > which is used for:
>> > link
>> > #ifdef CONFIGURE_SCHEDULER_STRONG_APA
>> > #ifndef CONFIGURE_SCHEDULER_NAME
>> > #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'A', 'P', 'A' )
>> > #endif
>> > #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
>> > #define CONFIGURE_SCHEDULER \
>> > RTEMS_SCHEDULER_STRONG_APA( \
>> > dflt, \
>> > CONFIGURE_MAXIMUM_PRIORITY + 1 \
>> > #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
>> > RTEMS_SCHEDULER_TABLE_STRONG_APA( dflt, CONFIGURE_SCHEDULER_NAME )
>> > #endif
>> > #endif
>> > which is eventually used for:
>> > link
>> > const Scheduler_Control _Scheduler_Table[] = {
>> > I do not understand what the Scheduler_Table[] or the SCHEDULER_TABLE_ENTRIES should contain.
>> The type definition of the _Scheduler_Table[] is Scheduler_Control.
>> This structure is defined in
>> cpukit/include/rtems/score/scheduler.h:269
>> > I need help with this because I have to change the RTEMS_SCHEDULER_TABLE_STRONG_APA since I am changing some of the variables in the Scheduler_strong_APA_Context.
>> scheduler table.
>> > Thank you,
>> > Richi.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
