[GSoC 2020] : BSP Buildset for EPICS (next steps)
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Aug 12 07:58:48 UTC 2020
I think you should not make a patch for these two changes but a
simple replacement with e.g. sed.
like
sed -i ’s/^RTEMS_BASE/RTEMS_BASE = \/home\/mritunjay\/development\/rtems/\$\(RTEMS_VERSION\)-arm\/g’ configure/os/CONFIG_SITE.Common.RTEMS
oder so ;-)
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 12. Aug 2020, at 02:13, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
> Hello Heinz and everyone!
> Thank you so much for this update. I started to work first by building EPICS by hand
> for "xilinx_zynq_a9_qemu". Till the time, you gave https://gitlab.fhi.mpg.de/junkes/epics-base.git,
> I had to struggle with lot of errors which cloning into this repo solved.
> So I started by building "xilinx_zynq_a9_qemu" BSP for RTEMS5 using my own blog with only difference being
> that  I used '--disable-networking' to use libbsd.
> After that, I used this blog https://rmeena840.github.io/Fourth-Post/ of a GSoC 19 Student to build and install rtems-libbsd
> Everything worked perfectly fine till now. Now I entered the 'epics-base' directory and made
> the changes in configure/os/CONFIG_SITE.Common.RTEMS as:
> # FHI:
> RTEMS_SERIES = 5
> RTEMS_VERSION = 5
> RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)-arm
> Also made the change in configure/CONFIG_SITE:
> CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu
> After this I used 'make' command and it worked fine.
> So, I can say that there were just two changes which I had to make then the previous one.
> The successful build by hand enabled me to work on the RSB recipe.
> I worked on them and it can be found here https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support-zynq.
> The patch I am applying can be found here: https://raw.githubusercontent.com/mritunjaysharma394/epics-mritunjay/master/patches/0001-Added-support-for-RTEMS-xilinx_zynq_a9_qemu.patch
> However, the problem I am facing is that while building the recipe using:
> ```.../source-builder/sb-builder --log=log_epics epics-7-1```,
> the build is failing because it seems that Patch setup in configure file is not getting applied there. I followed the same steps as done for pc
> but this time the patch is not getting applied.
> It will be really helpful if you can guide where did I went wrong thist time.
> I am attaching the log and report file for reference.
> Thanks
> Mritunjay
> On Mon, Aug 10, 2020 at 8:56 PM junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hello Mritunjay,
> I have now finished an EPICS variant that works with libbsd so far. DHCP and NFS work. NTP I added a primitive reader. This is sufficient for testing.
> You can find the development here:
> It's not perfect yet. The adaptation to the legacy stack and the processing of the environment variables from the flash (u-boot etc.) is still missing.
> [h1 at earth QtC-epics-base (7.0 *+)]$ ./startQemu softIoc
> Script name: ./startQemu
> qemu-system-aarch64: warning: nic cadence_gem.1 has no peer
> WARNING: OS Clock time was read before being set.
> Using 1990-01-02 00:00:00.000000 UTC
> initConsole --- Info ---
> stdin: fileno: 0, ttyname: /dev/ttyS1
> stdout: fileno: 1, ttyname: /dev/ttyS1
> stderr: fileno: 2, ttyname: /dev/ttyS1
> tcsetattr failed: I/O error
> time set to : 04/14/14 07:30:06.000055589 UTC
> Startup.
> epicsThreadSetPriority called by non epics thread
> ***** RTEMS Version: rtems-5.0.0-m2003 (ARM/ARMv4/xilinx_zynq_a9_qemu) *****
> ***** Initializing network (dhcp) *****
> nexus0: <RTEMS Nexus device>
> zy7_slcr0: <Zynq-7000 slcr block> on nexus0
> cgem0: <Cadence CGEM Gigabit Ethernet Interface> on nexus0
> miibus0: <MII bus> on cgem0
> e1000phy0: <Marvell 88E1111 Gigabit PHY> PHY 0 on miibus0
> e1000phy0:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, 1000baseT-FDX-master, auto
> e1000phy1: <Marvell 88E1111 Gigabit PHY> PHY 23 on miibus0
> e1000phy1:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, 1000baseT-FDX-master, auto
> info: cgem0: Ethernet address: 52:54:00:12:34:56
> info: lo0: link state changed to UP
> ---- Wait for DHCP done ...
> dhcpcd: unknown option -- pv4only
> info: version 6.2.1 starting
> cgem0: cgem_mediachange: could not set ref clk0 to 25000000.
> info: cgem0: link state changed to UP
> debug: cgem0: executing `ioc boot' PREINIT
> ***** Primary Network interface : cgem0 *****
> debug: cgem0: executing `ioc boot' CARRIER
> info: DUID 00:01:00:01:1a:de:4a:fe:52:54:00:12:34:56
> info: cgem0: IAID 00:12:34:56
> info: cgem0: soliciting an IPv6 router
> debug: cgem0: delaying Router Solicitation for LL address
> debug: cgem0: using ClientID 00:46:48:49:20:74:65:73:74:20:63:6c:69:65:6e:74
> info: cgem0: soliciting a DHCP lease
> debug: cgem0: sending DISCOVER (xid 0x86686938), next in %0.1f seconds
> info: cgem0: carrier lost
> debug: cgem0: executing `ioc boot' NOCARRIER
> info: cgem0: carrier acquired
> debug: cgem0: sending DISCOVER (xid 0x441a0d89), next in %0.1f seconds
> debug: cgem0: wrong xid 0x86686938 (expecting 0x441a0d89) from 10.1.0.1
> info: cgem0: offered 10.1.0.104 from 10.1.0.1
> debug: cgem0: sending REQUEST (xid 0x441a0d89), next in %0.1f seconds
> debug: cgem0: acknowledged 10.1.0.104 from 10.1.0.1
> debug: cgem0: checking for 10.1.0.104
> debug: cgem0: sending ARP probe (1 of 3), next in %0.1f seconds
> debug: cgem0: sending ARP probe (2 of 3), next in %0.1f seconds
> debug: cgem0: sending ARP probe (3 of 3), next in %0.1f seconds
> info: cgem0: leased 10.1.0.104 for 6000 seconds
> debug: cgem0: renew in 3000 seconds, rebind in 5250 seconds
> debug: cgem0: adding IP address 10.1.0.104/24
> info: cgem0: adding host route to 10.1.0.104 via 127.0.0.1
> err: cgem0: ipv4_addroute: File exists
> info: cgem0: adding route to 10.1.0.0/24
> info: cgem0: adding default route via 10.1.0.1
> debug: cgem0: writing lease `/var/db/dhcpcd-cgem0.lease'
> debug: cgem0: executing `ioc boot' BOUND
> Interface TGP bounded
> rtems_bsdnet_bootp_server_name : 1001.1001 at 10.1.0.1:/Volumes/Epics
> rtems_bsdnet_bootp_boot_file_name : /Volumes/Epics/myExample/bin/RTEMS-xilinx_zynq_a9_qemu/myExample.boot
> rtems_bsdnet_bootp_cmdline : /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
> debug: cgem0: sending ARP announce (1 of 2), next in 2.0 seconds
> -------------- IFCONFIG -----------------
> cgem0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>        options=80008<VLAN_MTU,LINKSTATE>
>        ether 52:54:00:12:34:56
>        inet6 fe80::5054:ff:fe12:3456%cgem0 prefixlen 64 scopeid 0x1
>        inet 10.1.0.104 netmask 0xffffff00 broadcast 10.1.0.255
>        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
>        media: Ethernet autoselect (100baseTX <full-duplex>)
>        status: active
> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
>        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
>        inet 127.0.0.1 netmask 0xffffff00
>        inet6 ::1 prefixlen 128
>        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
>        groups: lo
> -------------- NETSTAT ------------------
> Routing tables
> Internet:
> Destination        Gateway            Flags     Netif Expire
> default            10.1.0.1           UGS       cgem0
> 10.1.0.0/24        link#1             U         cgem0
> 10.1.0.104         link#1             UHS         lo0
> 127.0.0.1          link#2             UH          lo0
> Internet6:
> ::1                               link#2                        UH          lo0
> fe80::%cgem0/64                   link#1                        U         cgem0
> fe80::5054:ff:fe12:3456%cgem0     link#1                        UHS         lo0
> fe80::%lo0/64                     link#2                        U           lo0
> fe80::1%lo0                       link#2                        UHS         lo0
> ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
> ***** Ask ntp server once... *****
> time from ntp : 08/10/20 15:08:41.000055589 UTC
> ***** Setting up file system *****
> ***** Initializing NFS *****
> rtems_bootp_server_name: 1001.1001 at 10.1.0.1:/Volumes/Epics
> nfsMount("1001.1001 at 10.1.0.1", "/Volumes/Epics", "/Volumes/Epics")
> Mount 1001.1001 at 10.1.0.1:/Volumes/Epics on /Volumes/Epics
> Warning: EPICS_TIMEZONE (CST6CDT,M3.2.0/2,M11.1.0/2) unrecognizable -- times will be displayed as GMT.
> check for time registered , C++ initialization ...
> ***** Preparing EPICS application *****
> chdir("/Volumes/Epics/myExample/iocBoot/iocmyExample/")
> ***** Starting EPICS application *****
> dbLoadDatabase("../../dbd/softIoc.dbd")
> Can't register 'system' command -- no command interpreter available.
> softIoc_registerRecordDeviceDriver(pdbbase)
> # Begin /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
> iocInit()
> Starting iocInit
> ## EPICS R7.0.3.2-DEV
> ## Rev. R7.0.3.1-105-ge597f8104c18ec7b9fc5-dirty
> debug: cgem0: sending ARP announce (2 of 2)
> Warning: RSRV has empty beacon address list
> epicsThreadRealtimeLock Warning: Unable to lock the virtual address space.
> VM page faults may harm real-time performance. errno=22
> iocRun: All initialization complete
> # End /Volumes/Epics/myExample/iocBoot/iocmyExample/st.cmd
> On 2020-08-08 21:58, Mritunjay Sharma wrote:
>> On Sat, Aug 8, 2020 at 11:10 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Sat, Aug 8, 2020 at 11:08 AM Mritunjay Sharma
>> > On Sat, Aug 8, 2020 at 9:46 PM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>> >> Hallo Mritunjay,
>> >> everything looks pretty good. I'm commenting on the text. I also send this mail
>> >> to two EPICS experts (Andrew Johnson and Michael Davidsaver). Maybe they also have some ideas.
>> > Thank you so much Heinz! It will be really a great help!
>> >> > Current Status:
>> >> > 1) Successfully built EPICS7 with RTEMS5 by hand for pc-386
>> >> > 2) Worked for RSB recipe.
>> >> >    In its due process, I Wrote:
>> >> >     i) rsb/rtems/config/epics/epics-7-1.cfg
>> >> >     ii)rsb/rtems/config/epics/epics-base.bset
>> >> >     iii)rsb/source-builder/config/epics-7-1.cfg
>> >> > 3) Added Patch for RTEMS-pc-386 support which made the above recipe work successfully.
>> >> > 4) Therefore, Successully built EPICS7 with RTEMS5 by using RSB recipe as well for pc-386 as of now.
>> >> > 5) Sent 4 Patches for review of the same.
>> >> > What problems are in the next steps?
>> >> > 1) How to make it work across different architectures?
>> >> > 2) Exisiting EPICS works on the old legacy network stack.
>> >> > 3) I am not using EPICS upstream branch. It is being built
>> >> > by Heinz's epics playground.
>> >> > 4) Doubts in how to start with testing.
>> >> > My Resarch work for the Problem no: 1
>> >> > I have gone through the EPICS developer guide from here
>> >> > exhaustively in the past couple of day and here are few interesting things
>> >> > that I found which can help:
>> >> > 1) "The main ingredients of the build system are:
>> >> > • A set of configuration files and tools provided in the EPICS base/configure directory
>> >> > • A corresponding set of configuration files in the <top>/configure directory of a non-base <top> directory
>> >> > structure to be built. The makeBaseApp.pl and makeBaseExt.pl scripts create these configuration files. Many of
>> >> > these files just include a file of the same name from the base/configure directory.
>> >> > • Makefiles in each directory of the <top> directory structure to be built
>> >> > • User created configuration files in build created $(INSTALL_LOCATION)/cfg directories.
>> >> > Remarks: Now since it is also mentioned in the guide that "makeBaseApp.pl
>> >> > creates directories and then copies template files into the newly created directories
>> >> > while expanding macros in the template files. EPICS base provides two sets of template files: simple and example."
>> >> > Can we think of using makeBaseApp.pl to that end? Making the user allow
>> >> > to change the configurations from the terminal?
>> >> I don't think that makeBaseApp.pl will help you. This is intended to build an example IOC. It takes the settings from the above mentioned configuration files.
>> >> You "only" need to specify the location of the RTEMS installation in configure/os/CONFIG_SITE.Common.RTEMS.
>> >> RTEMS_VERSION =
>> >> RTEMS_BASE =
>> >> Then you have to define the target in configure/CONFIG_SITE:
>> >> # Which target architectures to cross-compile for.
>> >> #  Definitions in configure/os/CONFIG_SITE.<host>.Common
>> >> #  may override this setting.
>> >> e.g. "CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu"
>> >> And for each target there must be a file in configure/os:
>> >> e.g. CONFIG_Common.RTEMS-xilinx_zynq_a9_qemu
>> >> If it is not provided by EPICS, the RSB should install it there (adapted to the target to be used by epics make).
>> Probably they should be provided by EPICS for known-to-work
>> configurations. If they are not, we should push upstream.
>> > Yes, Heinz. I followed the above steps and created a patch which I applied in the configuration files of RSB recipe.
>> > The problem with it is that it's made only for pc-386 and I have to hardcode there about location of the RTEMS installation in
>> > configure/os/CONFIG_SITE.Common.RTEMS. My doubt is how to modify the patch that can it offer user-specific location of the RTEMS
>> > installation and bsp?
>> I still think this should be done through some kind of pre-processing
>> (scripting) over these configuration files for a given target, using
>> some fixed pattern, rather than by patching. A patch is fine for
>> proof-of-concept, but I don't think we want to have x patches for x
>> BSP targets of EPICS.  Maybe it is fine, there aren't that many BSP
>> targets right now, but I can see this kind of patch-based
>> configuration getting a little unwieldy.
>> If you proceed with the patch-based approach, you need to figure out
>> how to pick the right patch to apply based on the target/bsp build. So
>> that would be your next step. Create a patch for the zynq, and see if
>> you can dynamically determine which one to apply (zynq or pc386) based
>> on RSB internal state/variables.
>> Thank you for the suggestions. I will start working on creating the patch for zynq and will see if
>> something can be done to dynamically determine them.
>> >> > 2) "The startup directory in EPICS base contains a perl script, EpicsHostArch.pl, which can be used to define
>> >> > EPICS_HOST_ARCH. This script can be invoked with a command line parameter defining the alternate compiler (e.g.
>> >> > if invoking EpicsHostArch.pl yields solaris-sparc, then invoking EpicsHostArch.pl gnu will yield
>> >> > solaris-sparc-gnu).
>> >> > The startup directory also contains scripts to help users set the path and other environment variables"
>> >> This has nothing to do with 2)
>> > I am sorry for the misunderstanding. All the 4 points mentioned here are my observations only for the Problem No.1
>> > `1) How to make it work across different architectures?`
>> >> There's no need to adjust anything here. The EPICS make recognizes the architecture on which it is started.
>> >> > Remarks: As EPICS_HOST_ARCH, can we do something similar for CROSS_COMPILER_TARGET_ARCHS?
>> >> > 3) ") The following is a summary of targets that can be specified for gnumake:
>> >> > • <action>
>> >> > • <arch>
>> >> > • <action>.<arch>
>> >> > • <dir>
>> >> > • <dir>.<action>
>> >> > • <dir>.<arch>
>> >> > • <dir>.<action>.<arch>
>> >> > where:
>> >> > <arch> is an architecture such as solaris-sparc, vxWorks-68040, win32-x86, etc.
>> >> > <action> is help, clean, realclean, distclean, inc, install, build, rebuild, buildInstall, realuninstall, or uninstall"
>> >> > Remarks: Now similar to the above stated, can we work for Cross Compiler target Architecture?
>> >> But this does not refer to 3) ?
>> > No no, this remark is also for the problem 1 only as told above. Slight misunderstanding here :)
>> >> 3) You have to take "my" repo at the moment, because the adaptations to RTEMS5 are not yet included in the official epics-base. This is a hen-and-egg problem because RTEMS is only now in the release phase, so my changes have not been implemented yet.
>> > Ok, I hope Dr. Gedare and Chris can help you with that.
>> We just need to be ready for when RTEMS 5.1 is officially released.
>> Hopefully soon, but I don't have a timeline. Releases are mostly
>> volunteer time, so they happen when they happen. We're trying to get
>> better about that, but it is hard (due to lack of incentives).
>> I think that makes it clear, Heinz.
>> >> 2) I'm just about to figure out in the Epics Makefiles whether the target was built with the legacy-stack or libbsd-stack. It's working already.
>> >> Now I also have to adjust the rtems_init.c accordingly. Here I have to clean up a little bit. But I hope to have this finished by the middle of the week.
>> > Thank you so much for the update!
>> > So I would like to ask my other mentors - what can I do for the time being? What should be the next steps for this week?
>> Prepare the zynq patch and try to work out the logic of how to select
>> the right patch to apply.
>> Then similar logic might be usable to script the configuration changes
>> of EPICS so we don't need patches.
>> Sure, I will do and update soon.
>> > And yes how to begin the testing part?
>> This was suggested by Heinz earlier to look at the CI test scripts
>> that EPICS maintainers use.
>> Yes, it slipped out of my mind. Will check and revert.
>> Thanks
>> Mritunjay Sharma
>> > I have tried to find some resources but I think it will be
>> > better if you can help somewhere to look at.
>> > Thanks
>> > Mritunjay Sharma
>> >> > These were the little doubts that originated from the research work I did.
>> >> > I will like the opinion of mentors that what can be the optimal way now to approach the
>> >> > project after this? What can be some resources for better research work of the
>> >> > above problems?
>> >> > Also, for the reference:
>> >> > Link to the changes in commits of rsb can be found here: https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support
>> >> > The patch for epics can be found here: https://github.com/mritunjaysharma394/epics-mritunjay/tree/master/patches
>> >> > Thanks
>> >> > Mritunjay Sharma
>> >> Heinz
> <rsb-report-epics-base-7.0-x86_64-linux-gnu-1.txt><log_epics>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200812/afda8d8d/attachment-0001.bin>
