[PATCH] Psxtest : Fix String Turncation warning
Wed Aug 12 13:41:36 UTC 2020
On Wed, Aug 12, 2020 at 7:03 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Aug 12, 2020 at 7:07 AM Aschref Ben-Thabet <aschref.ben-thabet at embedded-brains.de> wrote:
>> From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
>> replace strncpy with memcpy to silence this warning and free the
>> allocated memory block.
> I don't see a call to strncpy being replaced. Maybe I need coffee. I see an
> RTEMS test assert strcmp.
> Silence what warning?
> I do not  think it is appropriate to replace str*cpy with memcpy. What is the warning?
We had this discussion on a previous thread, start from
https://lists.rtems.org/pipermail/devel/2020-July/061008.html
>>  testsuites/psxtests/psxndbm01/init.c | 3 ++-
>>  1 file changed, 2 insertions(+), 1 deletion(-)
>> diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
>> index b524aff0df..658af58df3 100644
>> --- a/testsuites/psxtests/psxndbm01/init.c
>> +++ b/testsuites/psxtests/psxndbm01/init.c
>> @@ -216,11 +216,12 @@ rtems_task Init(rtems_task_argument ignored)
>>    get_phone_no = dbm_fetch( db, name2 );
>>    rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2 ) == 0 );
>> -  puts( "Fetch non-existing record and confirm error." );
>> +  puts( "Fetch non-existing record and confirm error." );
> I don't see a change here.
> And while you are here non-existing isn't a word. It should be "nonexistent"
>>    test_strings = (char*)malloc(6);
>>    memcpy( test_strings, "Hello", 5 );
>>    test_strings[5] = '\0';
>> +  free(test_strings);
>>  /* The data pointed by test_string is now pointed by key.dptr */
>>    key.dptr = test_strings;
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
