[PATCH] Psxtest : Fix String Turncation warning
Aschref Ben-Thabet
aschref.ben-thabet at embedded-brains.de
Wed Aug 12 14:43:36 UTC 2020
Hello joel, Gedare,
i think in this way , we may use Strdup/ Strrndup instead of memcpy to
guarantee the copy of null terminated String.
in this case we don't need to allocate memory, since Strdup do this one.
i m unconscious with the line #224 key.dsize = sizeof( test_strings )
then i have a doubt if it is correctly defined or we take in this case
the size of pointer instead of the size of an array.
Best regards,
Aschref
On 8/12/20 3:55 PM, Joel Sherrill wrote:
> On Wed, Aug 12, 2020 at 8:41 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Wed, Aug 12, 2020 at 7:03 AM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> > On Wed, Aug 12, 2020 at 7:07 AM Aschref Ben-Thabet
> <aschref.ben-thabet at embedded-brains.de
> <mailto:aschref.ben-thabet at embedded-brains.de>> wrote:
> >> From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de
> >> replace strncpy with memcpy to silence this warning and free the
> >> allocated memory block.
> > I don't see a call to strncpy being replaced. Maybe I need
> coffee. I see an
> > RTEMS test assert strcmp.
> > Silence what warning?
> > I do not think it is appropriate to replace str*cpy with memcpy.
> What is the warning?
> We had this discussion on a previous thread, start from
> https://lists.rtems.org/pipermail/devel/2020-July/061008.html
> I know and I didn't like it then but couldn't put my finger on it. Plus
> some of the warnings have been in psxhdr tests and my concern is
> lower because they never get executed.
> Using memcpy() violates the contract on how strings are to be processed.
> There is no assurance we end up with NULL terminated strings. We have
> seen string warnings with Coverity and other scanners before and addressed
> them without abandoning str*(). Why now?
> What is the warning and what is the proper fix? Eliminating use of string
> operations is heavy handed and introduces other risks.
> We haven't seen the actual warning and alternative solutions.
> FWIW I've had discussions with aviation safety reviewers and, to my
> surprise, strcpy() is actually OK to use sometimes. I asked because
> strncpy() is not in the FACE Technical Standard profiles because I don't
> think
> it was not in POSIX 2001 which is what the baseline API sets were based on.
> --joel
> >> testsuites/psxtests/psxndbm01/init.c | 3 ++-
> >> 1 file changed, 2 insertions(+), 1 deletion(-)
> >> diff --git a/testsuites/psxtests/psxndbm01/init.c
> b/testsuites/psxtests/psxndbm01/init.c
> >> index b524aff0df..658af58df3 100644
> >> --- a/testsuites/psxtests/psxndbm01/init.c
> >> +++ b/testsuites/psxtests/psxndbm01/init.c
> >> @@ -216,11 +216,12 @@ rtems_task Init(rtems_task_argument ignored)
> >> get_phone_no = dbm_fetch( db, name2 );
> >> rtems_test_assert( strcmp( (const char*)get_phone_no.dptr,
> PHONE_NO2 ) == 0 );
> >> - puts( "Fetch non-existing record and confirm error." );
> >> + puts( "Fetch non-existing record and confirm error." );
> > I don't see a change here.
> > And while you are here non-existing isn't a word. It should be
> "nonexistent"
> >> test_strings = (char*)malloc(6);
> >> memcpy( test_strings, "Hello", 5 );
> >> test_strings[5] = '\0';
> >> + free(test_strings);
> >> /* The data pointed by test_string is now pointed by key.dptr */
> >> key.dptr = test_strings;
> >> 2.26.2
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org <mailto:devel at rtems.org>
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
