[PATCH] Move 5 build sets to 6
chrisj at rtems.org
chrisj at rtems.org
Thu Aug 13 01:53:59 UTC 2020
- Move 5/bsps/* to bsps/*
- Update package build references from 5 to 6
- Remove 5 build sets.
Update #4048
rtems/config/5/bsps/atsamv.bset | 10 ----------
rtems/config/5/bsps/imx7.bset | 10 ----------
rtems/config/5/bsps/qoriq_e500.bset | 10 ----------
rtems/config/5/bsps/qoriq_e6500_32.bset | 10 ----------
rtems/config/5/bsps/qoriq_e6500_64.bset | 10 ----------
rtems/config/6/rtems-default.bset | 3 +++
rtems/config/{5 => 6}/rtems-kernel.bset | 2 +-
rtems/config/{5 => 6}/rtems-libbsd.bset | 2 +-
rtems/config/{5 => 6}/rtems-llvm.bset | 0
rtems/config/{5 => 6}/rtems-packages.bset | 0
rtems/config/{5 => 6}/rtems-tools.bset | 4 ++--
rtems/config/bsps/atsamv.bset | 10 ++++++++++
rtems/config/{5 => }/bsps/beagleboneblack.bset | 10 +++++-----
rtems/config/{5 => }/bsps/erc32.bset | 10 +++++-----
rtems/config/{5 => }/bsps/gr712rc.bset | 6 +++---
rtems/config/{5 => }/bsps/gr740.bset | 6 +++---
rtems/config/bsps/imx7.bset | 10 ++++++++++
rtems/config/{5 => }/bsps/pc.bset | 10 +++++-----
rtems/config/bsps/qoriq_e500.bset | 10 ++++++++++
rtems/config/bsps/qoriq_e6500_32.bset | 10 ++++++++++
rtems/config/bsps/qoriq_e6500_64.bset | 10 ++++++++++
rtems/config/{5 => }/bsps/raspberrypi2.bset | 10 +++++-----
rtems/config/{5 => }/bsps/xilinx_zynq_zc702.bset | 10 +++++-----
rtems/config/{5 => }/bsps/xilinx_zynq_zc706.bset | 10 +++++-----
rtems/config/{5 => }/bsps/xilinx_zynq_zedboard.bset | 10 +++++-----
rtems/config/ftp/curl.bset | 5 -----
rtems/config/net-mgmt/net-snmp.bset | 5 -----
rtems/config/tools/rtems-kernel-5.cfg | 12 ------------
rtems/config/tools/rtems-kernel-6.cfg | 12 ++++++++++++
rtems/config/tools/rtems-kernel-common.cfg | 3 +--
.../tools/{rtems-libbsd-5.cfg => rtems-libbsd-6.cfg} | 7 ++++---
31 files changed, 115 insertions(+), 122 deletions(-)
delete mode 100644 rtems/config/5/bsps/atsamv.bset
delete mode 100644 rtems/config/5/bsps/imx7.bset
delete mode 100644 rtems/config/5/bsps/qoriq_e500.bset
delete mode 100644 rtems/config/5/bsps/qoriq_e6500_32.bset
delete mode 100644 rtems/config/5/bsps/qoriq_e6500_64.bset
rename rtems/config/{5 => 6}/rtems-kernel.bset (88%)
rename rtems/config/{5 => 6}/rtems-libbsd.bset (77%)
rename rtems/config/{5 => 6}/rtems-llvm.bset (100%)
rename rtems/config/{5 => 6}/rtems-packages.bset (100%)
rename rtems/config/{5 => 6}/rtems-tools.bset (74%)
create mode 100644 rtems/config/bsps/atsamv.bset
rename rtems/config/{5 => }/bsps/beagleboneblack.bset (68%)
rename rtems/config/{5 => }/bsps/erc32.bset (65%)
rename rtems/config/{5 => }/bsps/gr712rc.bset (55%)
rename rtems/config/{5 => }/bsps/gr740.bset (55%)
create mode 100644 rtems/config/bsps/imx7.bset
rename rtems/config/{5 => }/bsps/pc.bset (65%)
create mode 100644 rtems/config/bsps/qoriq_e500.bset
create mode 100644 rtems/config/bsps/qoriq_e6500_32.bset
create mode 100644 rtems/config/bsps/qoriq_e6500_64.bset
rename rtems/config/{5 => }/bsps/raspberrypi2.bset (67%)
rename rtems/config/{5 => }/bsps/xilinx_zynq_zc702.bset (68%)
rename rtems/config/{5 => }/bsps/xilinx_zynq_zc706.bset (68%)
rename rtems/config/{5 => }/bsps/xilinx_zynq_zedboard.bset (69%)
delete mode 100644 rtems/config/tools/rtems-kernel-5.cfg
create mode 100644 rtems/config/tools/rtems-kernel-6.cfg
rename rtems/config/tools/{rtems-libbsd-5.cfg => rtems-libbsd-6.cfg} (63%)
diff --git a/rtems/config/5/bsps/atsamv.bset b/rtems/config/5/bsps/atsamv.bset
deleted file mode 100644
index 4bde317..0000000
--- a/rtems/config/5/bsps/atsamv.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define mail_single_report 1
-%define with_rtems_bsp atsamv
-%define rtems_target arm-rtems5
-%define rtems_host %{rtems_target}
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/imx7.bset b/rtems/config/5/bsps/imx7.bset
index c48a526..0000000
--- a/rtems/config/5/bsps/imx7.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp imx7
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/qoriq_e500.bset b/rtems/config/5/bsps/qoriq_e500.bset
index 4390e72..0000000
--- a/rtems/config/5/bsps/qoriq_e500.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp qoriq_e500
-%define rtems_target powerpc-rtems5
-5/rtems-powerpc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/qoriq_e6500_32.bset b/rtems/config/5/bsps/qoriq_e6500_32.bset
index ddd2055..0000000
--- a/rtems/config/5/bsps/qoriq_e6500_32.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp qoriq_e6500_32
-5/rtems-powerpc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/5/bsps/qoriq_e6500_64.bset b/rtems/config/5/bsps/qoriq_e6500_64.bset
index 9869b40..0000000
--- a/rtems/config/5/bsps/qoriq_e6500_64.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define with_rtems_bsp qoriq_e6500_64
-5/rtems-powerpc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 9b09e8e..0dc2e77 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -1,3 +1,6 @@
+# Default tools configuration.
%include 6/rtems-base.bset
6/rtems-autotools
diff --git a/rtems/config/5/rtems-kernel.bset b/rtems/config/6/rtems-kernel.bset
similarity index 88%
rename from rtems/config/5/rtems-kernel.bset
rename to rtems/config/6/rtems-kernel.bset
index 080af0b..e3402f6 100644
--- a/rtems/config/5/rtems-kernel.bset
+++ b/rtems/config/6/rtems-kernel.bset
@@ -12,4 +12,4 @@
# Build the kernel.
-tools/rtems-kernel-5
+tools/rtems-kernel-6
diff --git a/rtems/config/5/rtems-libbsd.bset b/rtems/config/6/rtems-libbsd.bset
similarity index 77%
rename from rtems/config/5/rtems-libbsd.bset
rename to rtems/config/6/rtems-libbsd.bset
index 2b84cf8..3d779bc 100644
--- a/rtems/config/5/rtems-libbsd.bset
+++ b/rtems/config/6/rtems-libbsd.bset
@@ -5,4 +5,4 @@
# Build the BSD library for RTEMS.
-tools/rtems-libbsd-5
+tools/rtems-libbsd-6
diff --git a/rtems/config/5/rtems-llvm.bset b/rtems/config/6/rtems-llvm.bset
similarity index 100%
rename from rtems/config/5/rtems-llvm.bset
rename to rtems/config/6/rtems-llvm.bset
diff --git a/rtems/config/5/rtems-packages.bset b/rtems/config/6/rtems-packages.bset
rename from rtems/config/5/rtems-packages.bset
rename to rtems/config/6/rtems-packages.bset
diff --git a/rtems/config/5/rtems-tools.bset b/rtems/config/6/rtems-tools.bset
similarity index 74%
rename from rtems/config/5/rtems-tools.bset
rename to rtems/config/6/rtems-tools.bset
index 12a3302..d0be01a 100644
--- a/rtems/config/5/rtems-tools.bset
+++ b/rtems/config/6/rtems-tools.bset
@@ -1,5 +1,5 @@
-# Tools Set for RTEMS 5 Tools Stable
+# Tools Set for RTEMS 6 Tools Stable
%define release 1
@@ -14,4 +14,4 @@
%include rtems-base.bset
-tools/rtems-tools-5-1
+tools/rtems-tools-6-1
diff --git a/rtems/config/bsps/atsamv.bset b/rtems/config/bsps/atsamv.bset
new file mode 100644
index 0000000..6b2dcf5
--- /dev/null
+++ b/rtems/config/bsps/atsamv.bset
@@ -0,0 +1,10 @@
+%define mail_single_report 1
+%define with_rtems_bsp atsamv
+%define rtems_target arm-rtems%{rtems_version}
+%define rtems_host %{rtems_target}
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/beagleboneblack.bset b/rtems/config/bsps/beagleboneblack.bset
similarity index 68%
rename from rtems/config/5/bsps/beagleboneblack.bset
rename to rtems/config/bsps/beagleboneblack.bset
index 41a06f6..33954d8 100644
--- a/rtems/config/5/bsps/beagleboneblack.bset
+++ b/rtems/config/bsps/beagleboneblack.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp beagleboneblack
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/erc32.bset b/rtems/config/bsps/erc32.bset
similarity index 65%
rename from rtems/config/5/bsps/erc32.bset
rename to rtems/config/bsps/erc32.bset
index 276b061..bd27833 100644
--- a/rtems/config/5/bsps/erc32.bset
+++ b/rtems/config/bsps/erc32.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp erc32
-%define rtems_target sparc-rtems5
+%define rtems_target sparc-rtems%{rtems_version}
-5/rtems-sparc
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-sparc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/gr712rc.bset b/rtems/config/bsps/gr712rc.bset
similarity index 55%
rename from rtems/config/5/bsps/gr712rc.bset
rename to rtems/config/bsps/gr712rc.bset
index e997905..e74a984 100644
--- a/rtems/config/5/bsps/gr712rc.bset
+++ b/rtems/config/bsps/gr712rc.bset
@@ -1,8 +1,8 @@
%define with_rtems_bsp gr712rc
-5/rtems-sparc
-5/rtems-kernel
+6/rtems-sparc
+6/rtems-kernel
diff --git a/rtems/config/5/bsps/gr740.bset b/rtems/config/bsps/gr740.bset
rename from rtems/config/5/bsps/gr740.bset
rename to rtems/config/bsps/gr740.bset
index 2e02c54..79b8ef1 100644
--- a/rtems/config/5/bsps/gr740.bset
+++ b/rtems/config/bsps/gr740.bset
@@ -1,8 +1,8 @@
%define with_rtems_bsp gr740
-5/rtems-sparc
-5/rtems-kernel
+6/rtems-sparc
+6/rtems-kernel
diff --git a/rtems/config/bsps/imx7.bset b/rtems/config/bsps/imx7.bset
index 0000000..e49e979
--- /dev/null
+++ b/rtems/config/bsps/imx7.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp imx7
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/pc.bset b/rtems/config/bsps/pc.bset
rename from rtems/config/5/bsps/pc.bset
rename to rtems/config/bsps/pc.bset
index e096fc9..57212f6 100644
--- a/rtems/config/5/bsps/pc.bset
+++ b/rtems/config/bsps/pc.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp pc686
-%define rtems_target i386-rtems5
+%define rtems_target i386-rtems%{rtems_version}
-5/rtems-i386
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-i386
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/bsps/qoriq_e500.bset b/rtems/config/bsps/qoriq_e500.bset
index 0000000..2011d75
--- /dev/null
+++ b/rtems/config/bsps/qoriq_e500.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp qoriq_e500
+%define rtems_target powerpc-rtems%{rtems_version}
+6/rtems-powerpc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/bsps/qoriq_e6500_32.bset b/rtems/config/bsps/qoriq_e6500_32.bset
index 0000000..419f334
--- /dev/null
+++ b/rtems/config/bsps/qoriq_e6500_32.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp qoriq_e6500_32
+6/rtems-powerpc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/bsps/qoriq_e6500_64.bset b/rtems/config/bsps/qoriq_e6500_64.bset
index 0000000..2d02b26
--- /dev/null
+++ b/rtems/config/bsps/qoriq_e6500_64.bset
@@ -0,0 +1,10 @@
+%define with_rtems_bsp qoriq_e6500_64
+6/rtems-powerpc
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/raspberrypi2.bset b/rtems/config/bsps/raspberrypi2.bset
similarity index 67%
rename from rtems/config/5/bsps/raspberrypi2.bset
rename to rtems/config/bsps/raspberrypi2.bset
index a7e51a3..83b12ea 100644
--- a/rtems/config/5/bsps/raspberrypi2.bset
+++ b/rtems/config/bsps/raspberrypi2.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp raspberrypi2
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/xilinx_zynq_zc702.bset b/rtems/config/bsps/xilinx_zynq_zc702.bset
rename from rtems/config/5/bsps/xilinx_zynq_zc702.bset
rename to rtems/config/bsps/xilinx_zynq_zc702.bset
index 01177d7..295c841 100644
--- a/rtems/config/5/bsps/xilinx_zynq_zc702.bset
+++ b/rtems/config/bsps/xilinx_zynq_zc702.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp xilinx_zynq_zc702
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/xilinx_zynq_zc706.bset b/rtems/config/bsps/xilinx_zynq_zc706.bset
rename from rtems/config/5/bsps/xilinx_zynq_zc706.bset
rename to rtems/config/bsps/xilinx_zynq_zc706.bset
index 1865b09..8b493cf 100644
--- a/rtems/config/5/bsps/xilinx_zynq_zc706.bset
+++ b/rtems/config/bsps/xilinx_zynq_zc706.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp xilinx_zynq_zc706
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/5/bsps/xilinx_zynq_zedboard.bset b/rtems/config/bsps/xilinx_zynq_zedboard.bset
similarity index 69%
rename from rtems/config/5/bsps/xilinx_zynq_zedboard.bset
rename to rtems/config/bsps/xilinx_zynq_zedboard.bset
index b1fc65c..801c6c9 100644
--- a/rtems/config/5/bsps/xilinx_zynq_zedboard.bset
+++ b/rtems/config/bsps/xilinx_zynq_zedboard.bset
@@ -12,10 +12,10 @@
%define with_rtems_bsp xilinx_zynq_zedboard
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
+6/rtems-arm
+6/rtems-kernel
+6/rtems-libbsd
+6/rtems-packages
diff --git a/rtems/config/ftp/curl.bset b/rtems/config/ftp/curl.bset
index 84cac39..e0c58e4 100644
--- a/rtems/config/ftp/curl.bset
+++ b/rtems/config/ftp/curl.bset
@@ -4,11 +4,6 @@
%define release 1
-# RTEMS Version
-%define rtems_version 5
# The RTEMS URL paths.
diff --git a/rtems/config/net-mgmt/net-snmp.bset b/rtems/config/net-mgmt/net-snmp.bset
index 667acaa..07c2721 100644
--- a/rtems/config/net-mgmt/net-snmp.bset
+++ b/rtems/config/net-mgmt/net-snmp.bset
@@ -4,11 +4,6 @@
%define release 1
-# RTEMS Version
-%define rtems_version 4.11
diff --git a/rtems/config/tools/rtems-kernel-5.cfg b/rtems/config/tools/rtems-kernel-5.cfg
index ef63205..0000000
--- a/rtems/config/tools/rtems-kernel-5.cfg
+++ /dev/null
@@ -1,12 +0,0 @@
-# RTEMS 5
-%define rtems_kernel_version 46c23871813618e7a16050068041b3d33551cd0d
-%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
- CoTpxkjoEXVITsFBDFJReE4AbOYdgXFI1U3eCazd3dzi3B8R0n4L2qx5wSbzxajN7RzzTJZkbRMttRcB7Xh0lg==
-# The RTEMS build instructions.
-%include tools/rtems-kernel-common.cfg
diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
index 0000000..f1d0990
--- /dev/null
+++ b/rtems/config/tools/rtems-kernel-6.cfg
@@ -0,0 +1,12 @@
+# RTEMS 5
+%define rtems_kernel_version 3ec5f20484cc4201e1d7b87844505644533b6148
+%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
+ BjMKrf5n1YR6IpiZrY5TUEzKATPRJxA2/6m6f833DdRu+RyLxccXqA4gHRdVUqFelFNQ3o0XdG4o1naBKYfhkQ==
+# The RTEMS build instructions.
+%include tools/rtems-kernel-common.cfg
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 3a17a28..157c7a4 100644
--- a/rtems/config/tools/rtems-kernel-common.cfg
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -214,8 +214,7 @@ URL: https://www.rtems.org/
export PATH="%{_internal_autotools_path}/bin:${PATH}"
%endif
./bootstrap -c
- %{_sbdir}/sb-bootstrap --preinstall
+ ./rtems-bootstrap
%endif
cd ..
diff --git a/rtems/config/tools/rtems-libbsd-5.cfg b/rtems/config/tools/rtems-libbsd-6.cfg
similarity index 63%
rename from rtems/config/tools/rtems-libbsd-5.cfg
rename to rtems/config/tools/rtems-libbsd-6.cfg
index f2c0e3d..1657096 100644
--- a/rtems/config/tools/rtems-libbsd-5.cfg
+++ b/rtems/config/tools/rtems-libbsd-6.cfg
@@ -1,10 +1,11 @@
-# RTEMS 5 LibBSD
+# RTEMS 6 LibBSD
-%define rtems_libbsd_version b96abfd647154f10ea8f7fac68e25676636eded5
+# branch: 6-freebsd-12
+%define rtems_libbsd_version d964a6703c705cc92fd053bcefc08bb3b6baa0e2
%hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 \
- /v2tsVlOL/ggpH8GMQib21tgEWaGKpjXdp44Ss/dDBgxxgbuc5mZ3DTlkjpOA72HeQ8HujGCdSX7QP9tjDkfMQ==
+ wEy8HtzSezKJtA3Vob7wM/D5qaG3ZVTDoNkK1yeTju04ov4IfL6IXWEtrNkOFsu9LdV1OPAOKSSYyAQ13sQqvg==
%define rtems_waf_version ad08908c452c6a9bbb3bf7bbbcc9fc03fe46cc7f
%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
EyuEit0DsAR1gK9Ki1sjl416PFgFe7dcggH3H/hmdAPmMjEIIdX7TVOTDgOIK1Pt0DW6lZ9NcW7O87GZFyy8hg==
2.24.1
