[PATCH] bsps/shared/ofw: Added and Documented RTEMS OFW interface
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Aug 13 06:39:18 UTC 2020
Hello Niteesh,
On 13/08/2020 07:05, Niteesh G. S. wrote:
> On Thu, Aug 13, 2020 at 12:36 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
>     I make a few comments below for you to consider. At a high level, I
>     think the interface looks reasonable, although plainly mimics the
>     freebsd naming conventions. I wonder if we should prefer our naming
>     conventions, which is to aim to use _ to separate different words, and
>     to limit use of abbreviations except as they help shorten very long
>     names?
>     I might suggest something along these lines:
>     rtems_ofw_get_prop_len() instead of rtems_ofw_getproplen() for example.
> I'll change them to RTEMS naming conventions.
>     It will make mapping to FreeBSD a little more annoying, but will make
>     the RTEMS interface more RTEMS-friendly.
>     Other small comments below.
>     On Wed, Aug 12, 2020 at 10:11 AM G S Niteesh Babu
>     <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>> wrote:
>     >  bsps/shared/dev/ofw/ofw.c |   0
>     >  bsps/shared/dev/ofw/ofw.h | 437
>     >  2 files changed, 437 insertions(+)
>     >  create mode 100644 bsps/shared/dev/ofw/ofw.c
>     >  create mode 100644 bsps/shared/dev/ofw/ofw.h
>     > diff --git a/bsps/shared/dev/ofw/ofw.c b/bsps/shared/dev/ofw/ofw.c
>     > new file mode 100644
>     > index 0000000000..e69de29bb2
>     > diff --git a/bsps/shared/dev/ofw/ofw.h b/bsps/shared/dev/ofw/ofw.h
>     > index 0000000000..5a8526c892
>     > --- /dev/null
>     > +++ b/bsps/shared/dev/ofw/ofw.h
>     > @@ -0,0 +1,437 @@
>     > +/* SPDX-License-Identifier: BSD-2-Clause */
>     > + * @file
>     > + * @ingroup ofw
>     > + * RTEMS FDT implementation of OpenFirmWare Interface.
Maybe a short notice that the intention is to be compatible with the
FreeBSD OpenFirmWare interface would be nice. So if someone changes
something he knows that he has to take a look at FreeBSD too.
>     > + * Copyright (C) <2020> Niteesh Babu G S <niteesh.gs at gmail.com
>     no <> around year
> Fixed.
>     > + * Redistribution and use in source and binary forms, with or without
>     > + * modification, are permitted provided that the following conditions
>     > + * are met:
>     > + * 1. Redistributions of source code must retain the above copyright
>     > + *    notice, this list of conditions and the following disclaimer.
>     > + * 2. Redistributions in binary form must reproduce the above
>     copyright
>     disclaimer in the
>     > + *    documentation and/or other materials provided with the
>     distribution.
>     > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>     CONTRIBUTORS "AS IS"
>     > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>     LIMITED TO, THE
>     > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>     PARTICULAR PURPOSE
>     > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>     CONTRIBUTORS BE
>     > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>     EXEMPLARY, OR
>     > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>     PROCUREMENT OF
>     > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
>     OR BUSINESS
>     > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>     WHETHER IN
>     > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>     OTHERWISE)
>     > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>     ADVISED OF THE
>     > + * POSSIBILITY OF SUCH DAMAGE.
>     > +#ifndef _OFW_H
>     > +#define _OFW_H
>     > +#ifdef __cplusplus
>     > +extern "C" {
>     > +#endif
>     > +#include <stdint.h>
>     > +#include <stddef.h>
>     > +typedef uint32_t  ihandle_t;
>     > +typedef uint32_t  pcell_t;
>     > +typedef uint32_t  phandle_t;
>     document the types?
> I'll document them. I should document their use right? Like what
> ihandle_t, phandle_t represent.
>     > + * @brief Gets the node that is next to @a node.
>     Somewhere the data structure should be explained. Maybe it will take a
>     new section in our doco to document the new interface.
> Once we finalize the interface. I'll add it to the doco.
> But I don't understand what you mean by data structures.
>     > + * @param[in] node Node offset
>     > + * @retval Peer node offset Successful operation.
>     > + * @retval 0 No peer node or invalid node handle
>     > +phandle_t rtems_ofw_peer(
>     > +  phandle_t   node
>     > + * @brief Gets the node that is the child of @a node.
>     > + * @retval child node offset Successful operation.
>     > + * @retval 0 No child node or invalid node handle
>     > +phandle_t rtems_ofw_child(
>     > +  phandle_t   node
>     > + * @brief Gets the node that is the parent of @a node.
>     > +phandle_t rtems_ofw_parent(
>     > +  phandle_t   node
>     > + * @brief Gets the length of the property mentioned in @a propname.
>     > + * @param[in] prop Property name
>     > + * @retval -1 Invalid node or property
>     > + * @retval  Length of property on successful operation
>     > +size_t rtems_ofw_getproplen(
>     > +  phandle_t   node,
>     > +  const char *propname
>     1 blank
> Fixed.
>     > + * @brief Gets the value of property mentioned in @a propname.
>     > + * @param[out] buf The property value gets stored in this buffer
>     (Pre-allocated)
>     > + * @param[in] len Length of the buffer
>     > +size_t rtems_ofw_getprop(
>     > +  phandle_t    node,
>     > +  const char  *propname,
>     > +  void        *buf,
>     > +  size_t       len
>     prop
> Fixed.
>     > + * Gets the value of property of @a node and converts the value
>     into the host's
>     > + * endiannes.
>     buffer(Pre-allocated)
>     > + * after converted to the host's endiannes
>     typo: endianness
>     more misspelled below
> Sorry for the typo. I fixed them all.
>     > +size_t rtems_ofw_getencprop(
>     > +  phandle_t    node,
>     > +  const char  *prop,
>     > +  pcell_t     *buf,
>     > +  size_t       len
>     > + * @brief Checks if the property @a propname is present in @a node.
>     > + * @param[in] propname Property name
>     > + *  @retval  0 Property not present.
>     > + *  @retval  1 Property is present.
>     > +int rtems_ofw_hasprop(
>     > +  phandle_t    node,
>     > + * @brief Searches for property @a propname in @a node.
>     > + * Searches the node and its parent recursively for the property
>     and fills the
>     > + * buffer with the first found value.
>     (Pre-allocated)
>     > + * @retval  Length of the property if property is found.
>     > + * @retval  -1 Property is not found.
>     > +size_t rtems_ofw_searchprop(
>     > +  phandle_t    node,
>     > +  void        *buf,
>     > +  size_t       len
>     and fills the
>     > + * buffer with the first value found after converting it to the
>     endiannes of the
>     > + * host.
>     > +size_t rtems_ofw_searchencprop(
>     > +  phandle_t    node,
>     > +  pcell_t     *buf,
>     > +  size_t       len
>     > + * Same as rtems_ofw_getprop, but the @a buf is allocated in this
>     routine and
>     > + * the user is responsible for freeing it.
>     > + * @param[out] buf The buffer is allocated in this routine and
>     user is
>     > + * responsible for freeing.
>     > +size_t rtems_ofw_getprop_alloc(
>     > +  phandle_t    node,
>     > +  void       **buf
>     > + * @brief Gets multiple values of the property @a propname.
>     > + * Same as rtems_ofw_getprop_alloc but it can read properties
>     with multiple
>     > + * values.
>     > + * For eg: reg = <0x1000 0x10 0x2000 0x20>
>     > + * @param[in] elsz Size of the single value
>     user is
>     > + * @retval   Number of values read.
>     > +size_t rtems_ofw_getprop_alloc_multi(
>     > +  phandle_t    node,
>     > +  int          elsz,
>     > +  void       **buf
>     > + * Same as rtems_ofw_getprop_alloc but the value stored in the
>     buffer is
>     > + * converted into the host's endiannes.
>     user is
>     > +size_t rtems_ofw_getencprop_alloc(
>     > +  phandle_t    node,
>     > +  void       **buf
>     > + * Same as rtems_ofw_getprop_alloc_multi but the values stored in
>     the buffer
>     > + * are converted to the host's endiannes.
>     user is
>     must they call rtems_ofw_prop_free?
> FreeBSD has an OF_free which call's free with proper flags.
> In RTEMS we decided to ignore the flags and I blindly copied the
> whole interface. So I don't think a separate function for free is
> needed but it will make the API uniform.
That will also make the API future proof. If someone somewhen decides to
change the implementation, the user already uses "rtems_ofw_prop_free"
instead of a plain "free" everywhere.
>     > +size_t rtems_ofw_getencprop_alloc_multi(
>     > +  phandle_t     node,
>     > +  int           elsz,
>     > +  void        **buf
>     > + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc
>     functions.
>     > + * @param[in] buf Buffer to be freed
>     > +void rtems_ofw_prop_free(
>     > +  void   *buf
>     > + * @brief Finds the next property of @a node.
>     > + * Finds the next property of the node and when @a propname is
>     NULL it returns
>     > + * the value in the first property.
>     > + * @param[out] buf The value of the next property gets stored in
>     this buffer
>     > + * (Pre-allocated)
>     > + * @retval  -1 node or previous property does not exist
>     > + * @retval   0 no more properties
>     > + * @retval   1 success
>     > +int rtems_ofw_nextprop(
>     > +  phandle_t    node,
>     > +  char        *buf,
>     > +  size_t       len
>     > + * @brief Sets the property @name of @a node to @a buf.
>     > + * @param[in] name Property name
>     > + * @param[in] buf Buffer containes the value to be set.
>     typo; contains
> Fixed.
>     > + * @retval  -1 node does not exist
>     > + * @retval   0 on success
>     > + * @retval   libFDT error codes on unsuccessful setting operation
>     > +int rtems_ofw_setprop(
>     > +  phandle_t    node,
>     > +  const char  *name,
>     > +  const void  *buf,
>     > +  size_t       len
>     > + * @brief Converts a device specifier to a fully qualified path name.
>     > + * @param[in] dev device specifier
>     > + * @param[out] buf The path is filled into the buffer(Pre-allocated)
>     > + * @param[in] length of the buffer
>     > + * @retval  -1 always. Unimplemented.
>     > +size_t rtems_ofw_canon(
>     > +  const char  *dev,
>     > +  char        *buf,
>     > +  size_t       len
>     > + * @brief Finds the node at the given path
>     > + * @param[in] path to the node from root
>     > + * @retval   node handle on success
>     > +phandle_t rtems_ofw_finddevice(
>     > +  const char  *path
>     > + * @brief This routine converts effective phandle of @a node to
>     node offset.
>     @a xref?
> Fixed.
>     > + * @param[in] xref Node phandle
>     > + * @retval Node offset on success
>     > + * @retval Node phandle on failure
>     > +phandle_t rtems_ofw_node_from_xref(
>     > +  phandle_t   xref
>     > + * @brief This routine converts node offset to effective phandle
>     of @a node.
>     > + * @retval Node phandle on success
>     > + * @retval Node offset on failure
>     > +phandle_t rtems_ofw_xref_from_node(
>     > +  phandle_t   node
>     > + * instance handles(ihandle_t) as same as phandles in the FDT
>     implementation
>     > + * of OF interface.
>     stray comments?
> I'll add these comments to the type's documentation above.
> I also wanted to add a few other functions that are nor part
> of the OF interface but would be really beneficial for RTEMS.
Maybe make clear in the description that these don't have a mapping that
matches FreeBSD's OFW interface.
> Can I add the following functions?
> 1) rtems_ofw_get_reg
> 2) rtems_ofw_status_okay
> 3) rtems_ofw_get_interrupts
> Since these functions are not part of OFW should I use FDT
> instead of OFW in the function names?
> eg: rtems_fdt_get_reg
Be carefull with "rtems_fdt". There is already a wrapper for libfdt with
these prefixes in cpukit/libmisc/rtems-fdt/rtems-fdt.c. And if you use
the types from this file, you should keep the prefix as "rtems_ofw".
Best regards
Christian
>     > + * @brief Converts @a instance handle to phandle.
>     > + * instance are same as node offsets in FDT.
>     > + * @param[in] instance Node offset
>     > + * @retval phandle of node on success.
>     > + * @retval instance of node on failure.
>     > +phandle_t rtems_ofw_instance_to_package(
>     > +  ihandle_t   instance
>     > + * @brief Find the node's path from phandle.
>     > + * @param[out] buf Path is filled into this buffer(Pre-allocated).
>     > + * @param[in] len Length of the buffer.
>     > +size_t rtems_ofw_package_to_path(
>     > +  phandle_t   node,
>     > +  char       *buf,
>     > +  size_t      len
>     > + * @brief Find the node's path from ihandle.
>     > +size_t rtems_ofw_instance_to_path(
>     > +  ihandle_t  instance,
>     > +  char      *buf,
>     > +  size_t     len
>     > +#ifdef __cplusplus
>     > +#endif
>     > +#endif /* _OFW_H */
>     > \ No newline at end of file
>     > 2.17.1
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
