Need help in figuring out how to allocate sizes to the array
Sebastian Huber
Thu Aug 13 12:47:44 UTC 2020
On 13/08/2020 14:42, Richi Dubey wrote:
> I want to use arrays with size _CONFIGURE_MAXIMUM_PROCESSORS. Is it
> okay if I define the arrays with this size while writing the scheduler
> strong APA header file? I am asking this because the value of this
> header gets defined at the time the test case runs while the scheduler
> gets linked to the test case at the time of linking. So how would it
> work?
Do NOT use _CONFIGURE_MAXIMUM_PROCESSORS.
In <rtems/scheduler.h> please use something similar to the EDF scheduler
instantiation:
#ifdef CONFIGURE_SCHEDULER_EDF_SMP
#include <rtems/score/scheduleredfsmp.h>
#ifndef CONFIGURE_MAXIMUM_PROCESSORS
#error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure
the EDF SMP scheduler"
#endif
#define SCHEDULER_EDF_SMP_CONTEXT_NAME( name ) \
SCHEDULER_CONTEXT_NAME( EDF_SMP_ ## name )
#define RTEMS_SCHEDULER_EDF_SMP( name ) \
static struct { \
Scheduler_EDF_SMP_Context Base; \
Scheduler_EDF_SMP_Ready_queue Ready[ CONFIGURE_MAXIMUM_PROCESSORS
+ 1 ]; \
} SCHEDULER_EDF_SMP_CONTEXT_NAME( name )
#define RTEMS_SCHEDULER_TABLE_EDF_SMP( name, obj_name ) \
&SCHEDULER_EDF_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
SCHEDULER_EDF_SMP_ENTRY_POINTS, \
SCHEDULER_EDF_MAXIMUM_PRIORITY, \
( obj_name ) \
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
/* Provided for backward compatibility */
#define RTEMS_SCHEDULER_CONTEXT_EDF_SMP( name, max_cpu_count ) \
#define RTEMS_SCHEDULER_CONTROL_EDF_SMP( name, obj_name ) \
#endif
