[PATCH] Strict thread-stack isolation and thread-stack sharing.
Utkarsh Rai
utkarsh.rai60 at gmail.com
Thu Aug 13 15:06:10 UTC 2020
-This patch provides thread-stack isolation and thread-stack sharing
mechanism for a POSIX thread.
-The patches are based on sebastian's build-2 branch of sebastian's repo https://git.rtems.org/sebh
-Configurations options are provided by using the new-build system. Refer to https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf,
chapter 7,for basic setup and https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf(chapter 9) for the internals of the build system.
.../realview-pbx-a9/mmu/bsp-set-mmu-attr.c | 75 ++++++++++
bsps/shared/start/stackalloc.c | 12 +-
.../libbsp/arm/realview-pbx-a9/Makefile.am | 3 +
cpukit/Makefile.am | 1 +
cpukit/headers.am | 2 +
cpukit/include/rtems/score/memoryprotection.h | 91 ++++++++++++
cpukit/include/rtems/score/stack.h | 49 +++++++
cpukit/include/rtems/score/stackprotection.h | 80 +++++++++++
cpukit/include/rtems/score/thread.h | 1 +
cpukit/posix/src/mmap.c | 41 +++++-
cpukit/posix/src/shmwkspace.c | 46 +++++-
cpukit/score/cpu/arm/cpu_asm.S | 94 ++++++++++++
cpukit/score/src/stackprotection.c | 103 +++++++++++++
cpukit/score/src/threadhandler.c | 6 +
cpukit/score/src/threadinitialize.c | 9 ++
.../arm/realview-pbx-a9/bsprealviewpbxa9.yml | 1 +
spec/build/cpukit/cpuopts.yml | 2 +
spec/build/cpukit/librtemscpu.yml | 3 +
.../build/cpukit/optthreadstackprotection.yml | 16 +++
spec/build/testsuites/samples/grp.yml | 4 +
.../samples/threadstackprotection.yml | 19 +++
.../testsuites/samples/threadstacksharing.yml | 19 +++
testsuites/samples/Makefile.am | 16 +++
testsuites/samples/configure.ac | 2 +
.../samples/thread_stack_protection/init.c | 112 +++++++++++++++
.../thread_stack_protection.doc | 2 +
.../thread_stack_protection.scn | 20 +++
.../samples/thread_stack_sharing/init.c | 136 ++++++++++++++++++
28 files changed, 959 insertions(+), 6 deletions(-)
create mode 100644 bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
create mode 100644 cpukit/include/rtems/score/memoryprotection.h
create mode 100644 cpukit/include/rtems/score/stackprotection.h
create mode 100644 cpukit/score/src/stackprotection.c
create mode 100644 spec/build/cpukit/optthreadstackprotection.yml
create mode 100644 spec/build/testsuites/samples/threadstackprotection.yml
create mode 100644 spec/build/testsuites/samples/threadstacksharing.yml
create mode 100644 testsuites/samples/thread_stack_protection/init.c
create mode 100644 testsuites/samples/thread_stack_protection/thread_stack_protection.doc
create mode 100644 testsuites/samples/thread_stack_protection/thread_stack_protection.scn
create mode 100644 testsuites/samples/thread_stack_sharing/init.c
diff --git a/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
new file mode 100644
index 0000000000..c3b469dd2a
--- /dev/null
+++ b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
@@ -0,0 +1,75 @@
+#include <bsp/arm-cp15-start.h>
+#include <rtems/score/memoryprotection.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+static uint32_t translate_flags(uint32_t attr_flags)
+ uint32_t flags;
+ uint32_t memory_attribute;
+ switch (attr_flags)
+ case RTEMS_READ_WRITE:
+ flags = ARMV7_MMU_READ_WRITE;
+ break;
+ case RTEMS_READ_ONLY:
+ flags = ARMV7_MMU_READ_ONLY;
+ break;
+ case RTEMS_NO_ACCESS:
+ default:
+ flags = 0;
+ break;
+ * Check for memory-cache operation
+ if( attr_flags & RTEMS_MEMORY_CACHED ) {
+ flags |= ARM_MMU_SECT_TEX_0 | ARM_MMU_SECT_C | ARM_MMU_SECT_B;
+ return flags;
+void _Memory_protection_Set_entries(uintptr_t begin, size_t size, uint32_t flags)
+ uintptr_t end;
+ rtems_interrupt_level irq_level;
+ uint32_t access_flags;
+ if(begin != NULL ) {
+ end = begin + size;
+ access_flags = translate_flags(flags);
+ * The ARM reference manual instructs to disable all the interrupts before
+ * setting up page table entries.
+ rtems_interrupt_disable(irq_level);
+ arm_cp15_set_translation_table_entries(begin, end, access_flags);
+ rtems_interrupt_enable(irq_level);
+void _Memory_protection_Unset_entries(uintptr_t begin, size_t size)
+ uintptr_t end;
+ if( begin != NULL ) {
+ access_flags = translate_flags( RTEMS_NO_ACCESS );
\ No newline at end of file
diff --git a/bsps/shared/start/stackalloc.c b/bsps/shared/start/stackalloc.c
index f7cf7be0f1..6ebef4d6e5 100644
--- a/bsps/shared/start/stackalloc.c
+++ b/bsps/shared/start/stackalloc.c
@@ -44,6 +44,15 @@ void *bsp_stack_allocate(size_t size)
void *stack = NULL;
+#if defined (RTEMS_THREAD_STACK_PROTECTION)
+ * This is a temporary hack, we need to use _Heap_Allocate_aligned() but the heap
+ * intialization for bsp_stack_heap fails as bsp_section_stack_size is 0. See
+ * bsp_stack_allocate_init().
+ posix_memalign(&stack, 4096 , size);
+ _Memory_protection_Set_entries( stack, size, ( RTEMS_READ_ONLY | RTEMS_MEMORY_CACHED ) );
+#else
if (bsp_stack_heap.area_begin != 0) {
stack = _Heap_Allocate(&bsp_stack_heap, size);
@@ -51,6 +60,7 @@ void *bsp_stack_allocate(size_t size)
if (stack == NULL) {
stack = _Workspace_Allocate(size);
+#endif
return stack;
@@ -62,4 +72,4 @@ void bsp_stack_free(void *stack)
if (!ok) {
_Workspace_Free(stack);
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index d5549275be..24847c7b91 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -74,6 +74,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-a9mpcore.
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-v7ar-disable-data.S
+#MMU
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
# Start hooks
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/realview-pbx-a9/start/bspstarthooks.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 75e119ea3c..2d50d0fdce 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -929,6 +929,7 @@ librtemscpu_a_SOURCES += score/src/schedulercbsgetserverid.c
librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
+librtemscpu_a_SOURCES += score/src/stackprotection.c
librtemscpu_a_SOURCES += score/src/stackallocator.c
librtemscpu_a_SOURCES += score/src/pheapallocate.c
librtemscpu_a_SOURCES += score/src/pheapextend.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 0bba9674cd..211e17ddf8 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -352,6 +352,7 @@ include_rtems_score_HEADERS += include/rtems/score/isr.h
include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
include_rtems_score_HEADERS += include/rtems/score/isrlock.h
include_rtems_score_HEADERS += include/rtems/score/memory.h
+include_rtems_score_HEADERS += include/rtems/score/memoryprotection.h
include_rtems_score_HEADERS += include/rtems/score/mpci.h
include_rtems_score_HEADERS += include/rtems/score/mpciimpl.h
include_rtems_score_HEADERS += include/rtems/score/mppkt.h
@@ -405,6 +406,7 @@ include_rtems_score_HEADERS += include/rtems/score/smplockstats.h
include_rtems_score_HEADERS += include/rtems/score/smplockticket.h
include_rtems_score_HEADERS += include/rtems/score/stack.h
include_rtems_score_HEADERS += include/rtems/score/stackimpl.h
+include_rtems_score_HEADERS += include/rtems/score/stackprotection.h
include_rtems_score_HEADERS += include/rtems/score/states.h
include_rtems_score_HEADERS += include/rtems/score/statesimpl.h
include_rtems_score_HEADERS += include/rtems/score/status.h
diff --git a/cpukit/include/rtems/score/memoryprotection.h b/cpukit/include/rtems/score/memoryprotection.h
index 0000000000..245e50313c
--- /dev/null
+++ b/cpukit/include/rtems/score/memoryprotection.h
@@ -0,0 +1,91 @@
+ * @file
+ * @ingroup RTEMSScoreMemoryprotection
+ * @brief This file provodes APIs for high-level memory protection
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_SCORE_MEMORYPROTECTION_H
+#define _RTEMS_SCORE_MEMORYPROTECTION_H
+#if defined ( ASM )
+ #include <rtems/asm.h>
+#else
+ #include <rtems/score/basedefs.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+#if !defined ( ASM )
+#define RTEMS_NO_ACCESS 0x00
+#define RTEMS_READ_ONLY 0x01
+#define RTEMS_WRITE_ONLY 0x02
+#define RTEMS_READ_WRITE ( RTEMS_READ_ONLY | RTEMS_WRITE_ONLY )
+#define RTEMS_MEMORY_CACHED 0x04
+ * @brief Define the memory access permission for the specified memory region
+ * @param begin_addr Beginning of the memory region
+ * @param size Size of the memory region
+ * @param flag Memory access flag
+ uintptr_t begin_addr,
+ size_t size,
+ uint32_t flag
+ * @brief Unset the memory access permission for the specified memory region
+ * This operation implicitly sets the specified memory region with 'NO_ACCESS'
+ * flag.
+ * @param begin_addr Begining of the memory region
+ size_t size
+#endif /* !defined ( ASM ) */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index df1df74867..d561bf61c1 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -47,6 +47,47 @@ extern "C" {
#define STACK_MINIMUM_SIZE CPU_STACK_MINIMUM_SIZE
+ * The number of stacks that can be shared with a thread.
+#define SHARED_STACK_NUMBER 8
+#if defined ( RTEMS_THREAD_STACK_PROTECTION )
+ * The following defines the attributes of a protected stack
+typedef struct
+ /** The pointer to the page table base */
+ uintptr_t page_table_base;
+ /**Memory flag for the alllocated/shared stack */
+} Stack_Protection_attr;
+ * The following defines the control block of a shared stack. Each stack can have
+ * different sharing attributes.
+typedef struct
+ /** This is the attribute of a shared stack*/
+ Stack_Protection_attr Base;
+ /** This is the stack address of the sharing thread*/
+ void* shared_stack_area;
+ /** Stack size of the sharing thread*/
+ size_t shared_stack_size;
+ /** This is the stack address of the target stack. Maybe this area is not
+ * needed but this helps in selecting the target thread during stack sharing.
+ void* target_stack_area;
+ /** Error checking for valid target stack address. This is also used to
+ * distinguish between a normal mmap operation and a stack sharing operation.
+ bool stack_shared;
+} Stack_Shared_attr;
+#endif
* The following defines the control block used to manage each stack.
@@ -55,6 +96,14 @@ typedef struct {
size_t size;
/** This is the low memory address of stack. */
void *area;
+ /** The attribute of a protected stack */
+ Stack_Shared_attr *shared_stacks[SHARED_STACK_NUMBER];
+ uint32_t shared_stacks_count;
+#endif
} Stack_Control;
diff --git a/cpukit/include/rtems/score/stackprotection.h b/cpukit/include/rtems/score/stackprotection.h
index 0000000000..58ab5f8673
--- /dev/null
+++ b/cpukit/include/rtems/score/stackprotection.h
@@ -0,0 +1,80 @@
+ * @file
+ * @ingroup RTEMSScoreStackprotection
+ * @brief Stackprotection API
+ * This include file provides the API for the management of protected thread-
+ * stacks
+ * COPYRIGHT (c) 2020 Utkarsh Rai.
+ * are met:
+#ifndef _RTEMS_SCORE_STACKPROTECTION_H
+#define _RTEMS_SCORE_STACKPROTECTION_H
+#include <rtems/score/basedefs.h>
+#include <rtems/score/stack.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Share the stack address of a given thread with the target thread.
+ * @param target_stack Stack address of the target thread
+ * @param sharing_stack Stack address of the sharin thread
+int _Stackprotection_Share_stack(
+ void *target_stack,
+ void *sharing_stack,
+ size_t size,
+ uint32_t memory_flag
+ * @brief Swap the restored shared stacks in the page table during context
+ * restoration
+ * We set the entries of the restored stack and mark all the remainig stacks as
+ * 'NO-ACCESS'.
+ * @param Control block of the restored stack
+void _Stackprotection_Context_restore(
+ Stack_Control *heir_stack
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index ee0aee5b79..0ad22feac4 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -34,6 +34,7 @@
#include <rtems/score/priority.h>
#include <rtems/score/schedulernode.h>
+#include <rtems/score/stackprotection.h>
#include <rtems/score/states.h>
#include <rtems/score/threadq.h>
#include <rtems/score/timestamp.h>
diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
index 176c6e4fe8..6587819c0f 100644
--- a/cpukit/posix/src/mmap.c
+++ b/cpukit/posix/src/mmap.c
@@ -28,7 +28,27 @@
#include <rtems/posix/mmanimpl.h>
#include <rtems/posix/shmimpl.h>
+static uint32_t mmap_flag_translate(int prot)
+ int prot_read;
+ int prot_write;
+ int memory_flag;
+ prot_read = (prot_read & PROT_READ) == PROT_READ;
+ prot_write = (prot_write & PROT_WRITE) == PROT_WRITE;
+ if(prot_read){
+ memory_flag |= ( RTEMS_READ_ONLY| RTEMS_MEMORY_CACHED );
+ if(prot_write) {
+ memory_flag |= ( RTEMS_READ_WRITE | RTEMS_MEMORY_CACHED );
+ return memory_flag;
* mmap chain of mappings.
@@ -50,6 +70,9 @@ void *mmap(
bool map_private;
bool is_shared_shm;
int err;
+ uint32_t memory_flags;
+ uintptr_t shared_stack_address;
+ int status;
map_fixed = (flags & MAP_FIXED) == MAP_FIXED;
map_anonymous = (flags & MAP_ANON) == MAP_ANON;
@@ -67,7 +90,10 @@ void *mmap(
* We can provide read, write and execute because the memory in RTEMS does
- * not normally have protections but we cannot hide access to memory.
+ * not normally have protections but we cannot hide access to memory. For
+ * thread-stack protection we can provide no-access option, but stacks are
+ * implicitly isolated and it makes no sense to specify no-access option for
+ * already isolated stacks.
if ( prot == PROT_NONE ) {
errno = ENOTSUP;
@@ -292,11 +318,18 @@ void *mmap(
free( mapping );
return MAP_FAILED;
+ * We share thread-stacks only when we have a shared memory object and map
+ * shared flag set
+ memory_flags = mmap_flag_translate( prot );
+ status = _Stackprotection_Share_stack( mapping->addr, addr, len,memory_flags );
+ if(status == RTEMS_INVALID_ADDRESS ) {
+ rtems_chain_append_unprotected( &mmap_mappings, &mapping->node );
- rtems_chain_append_unprotected( &mmap_mappings, &mapping->node );
mmap_mappings_lock_release( );
return mapping->addr;
diff --git a/cpukit/posix/src/shmwkspace.c b/cpukit/posix/src/shmwkspace.c
index 4fa4ec4771..e4e3c594d9 100644
--- a/cpukit/posix/src/shmwkspace.c
+++ b/cpukit/posix/src/shmwkspace.c
@@ -16,6 +16,7 @@
+#include <rtems/posix/pthread.h>
@@ -24,6 +25,49 @@ int _POSIX_Shm_Object_create_from_workspace(
size_t size
+#if defined(RTEMS_THREAD_STACK_PROTECTION)
+ POSIX_Shm_Control *shm;
+ Objects_Id id;
+ Objects_Name_or_id_lookup_errors err;
+ Thread_Control *Control;
+ ISR_lock_Context lock_context;
+ char *name;
+ shm = RTEMS_CONTAINER_OF(shm_obj, POSIX_Shm_Control, shm_object);
+ name = shm->Object.name.name_p;
+ /** We assign fixed pattern of naming for thread-stacks, and treat them
+ * accordingly.
+ if( strncmp( name, "/taskfs/", 8) == 0 ) {
+ * Obtain the object id of the thread and then get the thread control block
+ * corresponding to that id.
+ err = _Objects_Name_to_id_u32(
+ &_POSIX_Threads_Information.Objects,
+ _Objects_Build_name( name[8], name[9], name[10], name[11]),
+ RTEMS_LOCAL,
+ &id
+ Control = _Thread_Get( id, &lock_context );
+ if( Control != NULL ) {
+ shm_obj->handle = Control->Start.Initial_stack.area;
+ if( size != Control->Start.Initial_stack.size) {
+ return ENOMEM;
+ } else {
+ return ENOMEM;
+ } else {
+ shm_obj->handle = _Workspace_Allocate( size );
+ if ( shm_obj->handle == NULL ) {
+ return ENOMEM;
+ shm_obj->size = size;
+ return 0;
+#else
return ENOMEM;
@@ -32,6 +76,7 @@ int _POSIX_Shm_Object_create_from_workspace(
memset( shm_obj->handle, 0, size );
return 0;
+#endif
int _POSIX_Shm_Object_delete_from_workspace( POSIX_Shm_Object *shm_obj )
@@ -97,4 +142,3 @@ void * _POSIX_Shm_Object_mmap_from_workspace(
return (char*)shm_obj->handle + off;
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 66f8ba6032..8e9a4a9f88 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -66,6 +66,73 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
str r3, [r0, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+ * We make a function call to set the memory attributes of the heir
+ * stack and unset that of the executing stack (including shared stacks ).
+ * This will be a simple asm code when done by switching the translation
+ * table base.
+/* Save the registers modified during function call */
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+/* Load the parameters for function call */
+ mov r0, r1
+ sub r0, r0, #76
+ ldr r1, [r0]
+ ldr r0, [r0, #4]
+ mov r2, #3
+ bl _Memory_protection_Set_entries
+/* Restore the saved registers */
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+/* We load the stack-pointer of the heir thread pre-maturely, this is
+ * done as oherwise the *_unset_entries call will execute from the stack of the
+ * executing thread causing fatal exceptions.
+ ldr sp, [r1, #32]
+/* Load the parameters of the function call */
+ mov r1, r0
+ sub r0, r0, #76
+ ldr r1, [r0]
+ ldr r0, [r0, #4]
+ bl _Memory_protection_Unset_entries
+ * Restore the saved registers
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+/* Set the memory entries of the shared stack */
+ sub r0, r0, #76
+ add r6, r0, #16
+.L_shared_stack_restore:
+ ldr r1, [r6, #8]
+ ldr r0, [r6, #12]
+ add r6, #4
+ add r11, #1
+/* We compare with a hard-coded value, this is the number of shared stacks
+ * (SHARED_STACK_NUMBER)
+ cmp r11, #8
+ bne .L_shared_stack_restore
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+#endif
#ifdef RTEMS_SMP
* The executing thread no longer executes on this processor. Switch
@@ -95,6 +162,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
/* Start restoring context */
.L_restore:
#if !defined(RTEMS_SMP) && defined(ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
clrex
#endif
@@ -133,7 +201,33 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
DEFINE_FUNCTION_ARM(_CPU_Context_restore)
mov r1, r0
GET_SELF_CPU_CONTROL r2
+ /* Save the registers modified during function call */
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+ /* Load the parameters for function call */
+ mov r1, r0
+ sub r0, r0, #76
+ ldr r1, [r0]
+ ldr r0, [r0, #4]
+ mov r2, #3
+ /* Restore the saved registers */
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+ /* Set memory entries of the shared thread stacks */
+#endif
b .L_restore
#ifdef RTEMS_SMP
diff --git a/cpukit/score/src/stackprotection.c b/cpukit/score/src/stackprotection.c
index 0000000000..8427046aa0
--- /dev/null
+++ b/cpukit/score/src/stackprotection.c
@@ -0,0 +1,103 @@
+ * @file
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/threadimpl.h>
+Stack_Control *heir_stack
+ void* stack_address;
+ size_t stack_size;
+ uint32_t index;
+ for(index = 0;index < heir_stack->shared_stacks_count; index++) {
+ stack_address = heir_stack->shared_stacks[index]->shared_stack_area;
+ stack_size = heir_stack->shared_stacks[index]->shared_stack_size;
+ _Memory_protection_Set_entries( stack_address, stack_size, memory_flags );
+static bool get_target_thread( Thread_Control *Control, void *arg)
+ Stack_Shared_attr *shared_stack;
+ uint32_t count;
+ shared_stack = arg;
+ * Check for the target thread by comparing the stack address. Add the shared stack
+ * attribute structure to the array tracking all the shared stacks.
+ if( Control->Start.Initial_stack.area == shared_stack->target_stack_area) {
+ count = Control->Start.Initial_stack.shared_stacks_count + 1;
+ if(count >= SHARED_STACK_NUMBER) {
+ return false;
+ Control->Start.Initial_stack.shared_stacks_count = count;
+ Control->Start.Initial_stack.shared_stacks[count] = shared_stack;
+ shared_stack->stack_shared = true;
+ return true;
+ void* target_stack,
+ void* sharing_stack,
+ size_t size,
+ Thread_Control *target_thread;
+ Stack_Shared_attr shared_stack;
+ shared_stack.Base.access_flags= memory_flag;
+ shared_stack.shared_stack_area = sharing_stack;
+ shared_stack.target_stack_area = target_stack;
+ shared_stack.shared_stack_size = size;
+ _Thread_Iterate( get_target_thread, &shared_stack );
+ if( shared_stack.stack_shared == true ) {
+ return 0;
+ } else {
+ return -1;
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index 6742b0b391..c18e33f688 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -22,6 +22,7 @@
#include <rtems/score/interr.h>
#include <rtems/score/isrlevel.h>
#include <rtems/score/userextimpl.h>
@@ -94,6 +95,11 @@ void _Thread_Handler( void )
level = executing->Start.isr_level;
_ISR_Set_level( level );
+ * Switch-out the the shared thread-stacks
+ _Stackprotection_Context_restore( &executing->Start.Initial_stack );
* Initialize the floating point context because we do not come
* through _Thread_Dispatch on our first invocation. So the normal
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 691f56388e..96db4193bc 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -114,6 +114,15 @@ bool _Thread_Initialize(
stack_size
+ * Initialize the protected stack attributes. Initially we initialize the
+ * thread with no access attributes, on context switch/restore action the
+ * thread stacks are assigned READ/WRITE attribute.
+ the_thread->Start.Initial_stack.Base.access_flags = RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED;
+#endif
* Get thread queue heads
diff --git a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
index 2721152b93..f7d2187c66 100644
--- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
+++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
@@ -57,6 +57,7 @@ links:
source:
- bsps/arm/realview-pbx-a9/console/console-config.c
- bsps/arm/realview-pbx-a9/console/console-polled.c
+- bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
- bsps/arm/realview-pbx-a9/start/bspreset.c
- bsps/arm/realview-pbx-a9/start/bspstart.c
- bsps/arm/realview-pbx-a9/start/bspstarthooks.c
diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
index 1902e543ca..f7641a5e50 100644
--- a/spec/build/cpukit/cpuopts.yml
+++ b/spec/build/cpukit/cpuopts.yml
@@ -63,6 +63,8 @@ links:
uid: optszoff
- role: build-dependency
uid: optsztime
+- role: build-dependency
+ uid: optthreadstackprotection
uid: optversion
target: cpukit/include/rtems/score/cpuopts.h
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 63a0b7dca5..9855401665 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -353,6 +353,7 @@ install:
- cpukit/include/rtems/score/isrlevel.h
- cpukit/include/rtems/score/isrlock.h
- cpukit/include/rtems/score/memory.h
+ - cpukit/include/rtems/score/memoryprotection.h
- cpukit/include/rtems/score/mpci.h
- cpukit/include/rtems/score/mpciimpl.h
- cpukit/include/rtems/score/mppkt.h
@@ -405,6 +406,7 @@ install:
- cpukit/include/rtems/score/smplockstats.h
- cpukit/include/rtems/score/smplockticket.h
- cpukit/include/rtems/score/stack.h
+ - cpukit/include/rtems/score/stackprotection.h
- cpukit/include/rtems/score/stackimpl.h
- cpukit/include/rtems/score/states.h
- cpukit/include/rtems/score/statesimpl.h
@@ -1509,6 +1511,7 @@ source:
- cpukit/score/src/semaphore.c
- cpukit/score/src/smpbarrierwait.c
- cpukit/score/src/stackallocator.c
+- cpukit/score/src/stackprotection.c
- cpukit/score/src/threadallocateunlimited.c
- cpukit/score/src/thread.c
- cpukit/score/src/threadchangepriority.c
diff --git a/spec/build/cpukit/optthreadstackprotection.yml b/spec/build/cpukit/optthreadstackprotection.yml
index 0000000000..4722d9f0cb
--- /dev/null
+++ b/spec/build/cpukit/optthreadstackprotection.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- env-enable: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 Utkarsh Rai (utkarsh.rai60 at gmail.com)
+default: false
+default-by-variant: []
+description: |
+ Enable the thread stack protection support
+enabled-by: true
+links: []
+name: RTEMS_THREAD_STACK_PROTECTION
+type: build
diff --git a/spec/build/testsuites/samples/grp.yml b/spec/build/testsuites/samples/grp.yml
index c7591dc551..f0367b0f9b 100644
--- a/spec/build/testsuites/samples/grp.yml
+++ b/spec/build/testsuites/samples/grp.yml
@@ -40,6 +40,10 @@ links:
uid: pppd
uid: ticker
+ uid: threadstackprotection
+ uid: threadstacksharing
uid: unlimited
type: build
diff --git a/spec/build/testsuites/samples/threadstackprotection.yml b/spec/build/testsuites/samples/threadstackprotection.yml
index 0000000000..a33c53d392
--- /dev/null
+++ b/spec/build/testsuites/samples/threadstackprotection.yml
@@ -0,0 +1,19 @@
+build-type: test-program
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/samples/thread_stack_protection/init.c
+stlib: []
+target: testsuites/samples/thread_stack_protection.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/samples/threadstacksharing.yml b/spec/build/testsuites/samples/threadstacksharing.yml
index 0000000000..bbe99af189
--- /dev/null
+++ b/spec/build/testsuites/samples/threadstacksharing.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/samples/thread_stack_sharing/init.c
+stlib: []
+target: testsuites/samples/thread_stack_sharing.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index 1944d90ccc..4d76bcb167 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -146,6 +146,22 @@ ticker_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_ticker) \
$(support_includes)
endif
+if TEST_thread_stack_protection
+samples += thread_stack_protection
+sample_screens += thread_stack_protection/thread_stack_protection.scn
+sample_docs += thread_stack_protection/thread_stack_protection.doc
+thread_stack_protection_SOURCES = thread_stack_protection/init.c
+thread_stack_protection_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_thread_stack_protection) \
+ $(support_includes)
+endif
+if TEST_thread_stack_sharing
+samples += thread_stack_sharing
+thread_stack_sharing_SOURCES = thread_stack_sharing/init.c
+thread_stack_sharing_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_thread_stack_sharing) \
+endif
if TEST_unlimited
samples += unlimited
sample_screens += unlimited/unlimited.scn
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/configure.ac
index 9721ea4f26..6460f8f2c9 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -50,6 +50,8 @@ RTEMS_TEST_CHECK([nsecs])
RTEMS_TEST_CHECK([paranoia])
RTEMS_TEST_CHECK([pppd])
RTEMS_TEST_CHECK([ticker])
+RTEMS_TEST_CHECK([thread_stack_protection])
+RTEMS_TEST_CHECK([thread_stack_sharing])
RTEMS_TEST_CHECK([unlimited])
AC_CONFIG_FILES([Makefile])
diff --git a/testsuites/samples/thread_stack_protection/init.c b/testsuites/samples/thread_stack_protection/init.c
index 0000000000..a9359b459d
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/init.c
@@ -0,0 +1,112 @@
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <pthread.h>
+#include <rtems/score/thread.h>
+const char rtems_test_name[] = " THREAD STACK PROTECTION ";
+static void fatal_extension(
+ rtems_fatal_source source,
+ bool is_internal,
+ rtems_fatal_code error
+ if (source == RTEMS_FATAL_SOURCE_EXCEPTION)
+ printk("Internal Exception Occured \n");
+ exit(0);
+void* Test_routine( void* arg )
+void *POSIX_Init( void *argument )
+ void *stack_addr1;
+ void *stack_addr2;
+ size_t stack_size1;
+ size_t stack_size2;
+ pthread_t id1;
+ pthread_t id2;
+ pthread_attr_t attr1;
+ pthread_attr_t attr2;
+ Thread_Control Control;
+ TEST_BEGIN();
+ * We set the stack size as 8Kb.
+ stack_size1 = 8192;
+ stack_size2 = 8192;
+ printf("%d %d \n",sizeof(Control.Post_switch_actions), sizeof(Control.Start.tls_area));
+ * We allocate page-aligned memory of the stack from the application.
+ posix_memalign(&stack_addr1, sysconf( _SC_PAGESIZE ), stack_size1 );
+ posix_memalign(&stack_addr2, sysconf( _SC_PAGESIZE ), stack_size2 );
+ pthread_attr_init( &attr1 );
+ pthread_attr_init( &attr2 );
+ * We set the stack size and address of the thread from the application itself
+ pthread_attr_setstack( &attr1, stack_addr1, stack_size1 );
+ pthread_attr_setstack( &attr2, stack_addr2, stack_size2 );
+ pthread_create( &id1, &attr1, Test_routine, NULL );
+ pthread_create( &id2, &attr2, Test_routine, NULL );
+ * We set the memory attributes of the stack from the application.
+ _Memory_protection_Set_entries( stack_addr1, stack_size1, RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED );
+ _Memory_protection_Set_entries( stack_addr2, stack_size2, RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED );
+ pthread_join( id1, NULL );
+ * Write to the stack address of thread1 after it has been switched out.
+ printf("Writing to the stack of thread1 \n");
+ memset(stack_addr1, 0, stack_size1);
+ pthread_join( id2, NULL );
+ * Write to the stack address of thread2 after it has been switched out.
+ TEST_END();
+ rtems_test_exit( 0 );
+/* configuration information */
+#define CONFIGURE_INIT
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
+#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT bsp_stack_allocate_init
+#define CONFIGURE_TASK_STACK_ALLOCATOR bsp_stack_allocate
+#define CONFIGURE_TASK_STACK_DEALLOCATOR bsp_stack_free
+#include <bsp/stackalloc.h>
+#include <rtems/confdefs.h>
diff --git a/testsuites/samples/thread_stack_protection/thread_stack_protection.doc b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
index 0000000000..c5c9cdfa81
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
@@ -0,0 +1,2 @@
+This test sample demonstrates the thread stack protection functionality. We try
+to write to the stack of a switched-out thread.
diff --git a/testsuites/samples/thread_stack_protection/thread_stack_protection.scn b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
index 0000000000..1d36d0dfaf
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
@@ -0,0 +1,20 @@
+*** BEGIN OF TEST THREAD STACK PROTECTION ***
+*** TEST VERSION: 5.0.0.a3b39c9e567f3f1ef5ab01de78b113e61b11853b-modified
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
+*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (3bd11fd4898b), Newlib 7947581)
+Creating thread1
+Creating thread2
+Joining thread1
+Writing to the stack of thread1
+Internal Exception Occured
diff --git a/testsuites/samples/thread_stack_sharing/init.c b/testsuites/samples/thread_stack_sharing/init.c
index 0000000000..5bb7d01418
--- /dev/null
+++ b/testsuites/samples/thread_stack_sharing/init.c
@@ -0,0 +1,136 @@
+#endif
+#include <rtems.h>
+#include <sys/mman.h>
+#include <sys/fcntl.h>
+const char rtems_test_name[] = " THREAD STACK SHARING ";
+ void* addr;
+ pthread_t id1;
+ pthread_t id2;
+ int fd;
+ char name[4] = "0x01";
+ char thread_name[13] = "/taskfs/0x01";
+ TEST_BEGIN();
+ _Memory_protection_Set_entries( stack_addr1, stack_size1, RTEMS_READ_ONLY | RTEMS_MEMORY_CACHED );
+ _Memory_protection_Set_entries( stack_addr2, stack_size2, RTEMS_READ_ONLY | RTEMS_MEMORY_CACHED );
+ * Add leading "/taskfs/" to denote thread-stack name.
+ strlcat( thread_name, name, 4);
+ * Set the name of the thread object same as that of the shared memory object name
+ rtems_object_set_name( id1, name);
+ * Create a shared memory object of the stack we want to share with
+ * appropraite permissions. We share the stack with read and write permission
+ fd = shm_open( thread_name, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR );
+ * Truncate the size of the file to the size of the stack.
+ ftruncate( fd, stack_size1 );
+ * For sharing the stack we specify the address of the
+ * thread-stack we want to share with, the size of the shared stack,
+ * protection and access flags, file descriptor of the shared memory objcet
+ addr = mmap( stack_addr2, stack_size1, PROT_READ | PROT_WRITE, O_RDWR, fd, 0 );
+ rtems_test_assert( addr != NULL );
+ memset( stack_addr1, 0, stack_size1 );
+ memset( stack_addr2, 0, stack_size2 );
+ TEST_END();
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 4
+#define CONFIGURE_MAXIMUM_POSIX_SHMS 2
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
2.17.1
