[PATCH v2] cpukit: Edit String Warninng
Aschref Ben-Thabet
aschref.ben-thabet at embedded-brains.de
Thu Aug 13 15:38:11 UTC 2020
Sorry it was not against master !
i send then V3 for this patch.
On 8/13/20 5:19 PM, Aschref Ben-Thabet wrote:
> From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
> Using FILENAME_MAX as a parameter in strncpy function can gererate
> warnings of type: -Wstringop-truncation. Replacing it with sizeof
> (distination_buffer) can avoid this warning.
> cpukit/libmisc/shell/main_edit.c | 11 ++++++-----
> 1 file changed, 6 insertions(+), 5 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
> index 6e88916ad0..feefd6bff1 100644
> --- a/cpukit/libmisc/shell/main_edit.c
> +++ b/cpukit/libmisc/shell/main_edit.c
> @@ -286,7 +286,7 @@ static struct editor *find_editor(struct env *env, char *filename) {
> struct editor *ed = env->current;
> struct editor *start = ed;
> - if (!realpath(filename, fn)) memcpy(fn, filename, FILENAME_MAX);
> + if (!realpath(filename, fn)) strncpy(fn, filename, sizeof(fn)-1);
> do {
> if (strcmp(fn, ed->filename) == 0) return ed;
> @@ -297,8 +297,9 @@ static struct editor *find_editor(struct env *env, char *filename) {
> static int new_file(struct editor *ed, char *filename) {
> if (*filename) {
> - memcpy(ed->filename, filename, FILENAME_MAX);
> - } else {
> + strncpy(ed->filename, filename, sizeof(ed->filename)-1);
> + else {
> sprintf(ed->filename, "Untitled-%d", ++ed->env->untitled);
> ed->newfile = 1;
> @@ -1775,8 +1776,8 @@ static void save_editor(struct editor *ed) {
> return;
> - memcpy(
> - ed->filename, (const char*) ed->env->linebuf, FILENAME_MAX);
> + strncpy(
> + ed->filename, (const char*)ed->env->linebuf, sizeof(ed->filename)-1);
> ed->newfile = 0;
