crypt and POSIX
Sebastian Huber
Fri Aug 14 04:49:03 UTC 2020
On 13/08/2020 21:52, Chris Johns wrote:
> On 13/8/20 11:47 pm, Joel Sherrill wrote:
>> On Thu, Aug 13, 2020 at 7:52 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
>> wrote:
>> On 13/08/2020 14:49, Joel Sherrill wrote:
>> > Why was crypt() removed? It is in the FreeBSD version at the bottom of
>> > the file.
>> > https://github.com/freebsd/freebsd/blob/master/lib/libcrypt/crypt.c
>> It is not thread-safe.
>> But it is standards compliant.
> Could it be added and just return NULL or even generate an internal error? The
> lack of crypt stopped me from using and it made me consider the issues. It is
> easy to forget these things when adding passwords to the console or telnet
> server and really hard to see an issue.
If you prefer a run time error to a link time error you can add
something like this:
char *
crypt(const char *passwd, const char *salt)
errno = ENOSYS;
return NULL;
The ready to use shell function to do a login check is:
extern bool rtems_shell_login_check(
const char *user,
const char *passphrase
>> And this would seem to violate the rules of source transparency in the
>> way the code was removed. If you wanted to disable it, it should have
>> been wrapped in ifndef __rtems__.
> I am confused, the code in cpukit/libcrypt is not from FreeBSD?
The file "cpukit/libcrypt/crypt.c" is not from FreeBSD, so there is no
point of having #ifndef __rtems__ stuff in it. Other files in the
libcrypt are from FreeBSD.
