Need help in figuring out how a node gets its afffinity when it is created
Richi Dubey
richidubey at gmail.com
Fri Aug 14 12:28:26 UTC 2020
Hi,
Follow up of my progress to this question:
I 'stepped inside' the important functions to make the observation that the
flow of code is actually:
_Scheduler_strong_APA_Node_initialize
_Scheduler_Node_initialize
_Thread_Initialize
rtems_task_create
_RTEMS_tasks_Initialize_user_task
rtems_initialize_executive
boot_card
bsp_start_hook_0_done
(So, the thread corresponding to the Init task gets created and assigned a
scheduler node which is then initialized and the Init task is started by
calling rtems_task_start on it)
So, is it okay if I set the Affinity (defined here
<https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/include/rtems/score/schedulerstrongapa.h#L75>)
of a node to all processors when it gets initialized (here
<https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/score/src/schedulerstrongapa.c#L739>
) because I remember Mr. Huber telling me earlier that by default a
node/task/thread is allowed to execute on all the processors?
On Fri, Aug 14, 2020 at 3:26 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> My code is failing because its logic assumed (code here
> <https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/score/src/schedulerstrongapa.c#L315>)
> that it would never get a node with an empty affinity (i.e. no affinity to
> any processor or a 0 affinity). This assumption proved wrong as I can see
> from the gdb and the current flow of code observed is:
> _Scheduler_strong_APA_Get_lowest_scheduled
> _Scheduler_SMP_Enqueue
> _Scheduler_strong_APA_Enqueue
> _Scheduler_SMP_Unblock
> _Scheduler_strong_APA_Unblock
> _Scheduler_Unblock
> _Thread_Clear_state_locked
> _Thread_Start
> rtems_task_start
> boot_card
> Why is this happening? The Affinity variable (defined here
> gets set whenever the Set affinity operation corresponding to Strong_APA
> scheduler (defined here
> <https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/score/src/schedulerstrongapa.c#L770>)
> gets called. So, why wasn't this function called before this happened? Any
> help would be appreciated.
> Thanks,
> Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200814/c0efc8e8/attachment.html>
