[PATCH v1 0/6] [libbsd] Fix e1000 driver for i386 in master and 5
Jan Sommer
jan.sommer at dlr.de
Fri Aug 14 19:57:47 UTC 2020
Hello,
I finally got around to port the e1000 driver fixes which are already
present in the 5-freebsd-12 branch of rtems-libbsd also for the master
(and 5) branch.
I created two corresponding tickets for it:
https://devel.rtems.org/ticket/4052 and
https://devel.rtems.org/ticket/4053.
Could someone please check and push them?
Best regards,
Jan
Jan Sommer (6):
e1000: Add missing files
waf: Add path-mappings feature
i386: Add missing files to build system
Callout: Redefine callout_reset_on for rtems
iflib.c: Deactivate use of ifc_cpus
i386: Delete old machine dependent files
freebsd/sys/dev/e1000/if_em.c | 6 +
freebsd/sys/i386/include/machine/bus.h | 6 -
freebsd/sys/i386/include/machine/legacyvar.h | 63 -
freebsd/sys/i386/include/machine/specialreg.h | 6 -
freebsd/sys/net/iflib.c | 6827 +++++++++++++++++
freebsd/sys/net/iflib_private.h | 70 +
freebsd/sys/net/mp_ring.c | 554 ++
freebsd/sys/net/mp_ring.h | 75 +
freebsd/sys/sys/callout.h | 6 +
freebsd/sys/x86/include/machine/specialreg.h | 1143 +++
freebsd/sys/x86/include/machine/x86_var.h | 145 +
libbsd.py | 18 +-
rtemsbsd/include/x86/x86_var.h | 146 +-
waf_libbsd.py | 13 +-
14 files changed, 8853 insertions(+), 225 deletions(-)
delete mode 100644 freebsd/sys/i386/include/machine/bus.h
delete mode 100644 freebsd/sys/i386/include/machine/legacyvar.h
delete mode 100644 freebsd/sys/i386/include/machine/specialreg.h
create mode 100644 freebsd/sys/net/iflib.c
create mode 100644 freebsd/sys/net/iflib_private.h
create mode 100644 freebsd/sys/net/mp_ring.c
create mode 100644 freebsd/sys/net/mp_ring.h
create mode 100644 freebsd/sys/x86/include/machine/specialreg.h
create mode 100644 freebsd/sys/x86/include/machine/x86_var.h
2.17.1
