[PATCH v1 4/6] Callout: Redefine callout_reset_on for rtems
Jan Sommer
jan.sommer at dlr.de
Fri Aug 14 19:57:51 UTC 2020
- callout_reset_on takes a cpu which is ignored by the subsequent call
to callout_reset_sbt_on in RTEMS.
- The macro is redefined to discard the cpu argument directly which
enables uses of it with cpu-dependent variables (disabled in
RETMS) without further changes, e.g. in iflib.c.
freebsd/sys/sys/callout.h | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/freebsd/sys/sys/callout.h b/freebsd/sys/sys/callout.h
index e5e5df85..d7b9965a 100644
--- a/freebsd/sys/sys/callout.h
+++ b/freebsd/sys/sys/callout.h
@@ -112,9 +112,15 @@ int callout_reset_sbt_on(struct callout *, sbintime_t, sbintime_t,
#define callout_reset_sbt_curcpu(c, sbt, pr, fn, arg, flags) \
callout_reset_sbt_on((c), (sbt), (pr), (fn), (arg), PCPU_GET(cpuid),\
(flags))
+#ifndef __rtems__
#define callout_reset_on(c, to_ticks, fn, arg, cpu) \
callout_reset_sbt_on((c), tick_sbt * (to_ticks), 0, (fn), (arg), \
(cpu), C_HARDCLOCK)
+#else /* __rtems__ */
+#define callout_reset_on(c, to_ticks, fn, arg, cpu) \
+ callout_reset_sbt_on((c), tick_sbt * (to_ticks), 0, (fn), (arg), \
+ -1, C_HARDCLOCK)
+#endif /* __rtems__ */
#define callout_reset(c, on_tick, fn, arg) \
callout_reset_on((c), (on_tick), (fn), (arg), -1)
#define callout_reset_curcpu(c, on_tick, fn, arg) \
2.17.1
